Hallo, Ich hab noch ein Problem mit meinem DSP TMS320F28335. Beim linken erscheint die Fehlermeldung Use -heap option to change the default size. >> error: can't allocate .text, size 00009b3f (page 0) in FLASHA (avail: 00007f80) >> error: can't allocate .ebss, size 000011c8 (page 1) in RAML4 (avail: 00001000) Die Speicheraufteilung sieht wie folgt aus: MEMORY { PAGE 0: /* Program Memory */ /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */ ZONE0 : origin = 0x004000, length = 0x001000 /* XINTF zone 0 */ RAML0 : origin = 0x008000, length = 0x001000 /* on-chip RAM block L0 */ RAML1 : origin = 0x009000, length = 0x001000 /* on-chip RAM block L1 */ RAML2 : origin = 0x00A000, length = 0x001000 /* on-chip RAM block L2 */ RAML3 : origin = 0x00B000, length = 0x001000 /* on-chip RAM block L3 */ ZONE6 : origin = 0x0100000, length = 0x100000 /* XINTF zone 6 */ ZONE7A: origin = 0x0200000, length = 0x00FC00 /* XINTF zone 7 - program space */ FLASHH: origin = 0x300000, length = 0x008000 /* on-chip FLASH */ FLASHG: origin = 0x308000, length = 0x008000 /* on-chip FLASH */ FLASHF: origin = 0x310000, length = 0x008000 /* on-chip FLASH */ FLASHE: origin = 0x318000, length = 0x008000 /* on-chip FLASH */ FLASHD: origin = 0x320000, length = 0x008000 /* on-chip FLASH */ FLASHC: origin = 0x328000, length = 0x008000 /* on-chip FLASH */ FLASHA: origin = 0x338000, length = 0x007F80 /* on-chip FLASH */ CSM_RSVD : origin = 0x33FF80, length = 0x000076 /* Part of FLASHA. Program with all 0x0000 when CSM is in use. */ BEGIN : origin = 0x33FFF6, length = 0x000002 /* Part of FLASHA. Used for "boot to Flash" bootloader mode. */ CSM_PWL : origin = 0x33FFF8, length = 0x000008 /* Part of FLASHA. CSM password locations in FLASHA */ OTP : origin = 0x380400, length = 0x000400 /* on-chip OTP */ ADC_CAL : origin = 0x380080, length = 0x000009 /* ADC_cal function in Reserved memory */ IQTABLES: origin = 0x3FE000, length = 0x000b50 /* IQ Math Tables in Boot ROM */ IQTABLES2: origin = 0x3FEB50, length = 0x00008c /* IQ Math Tables in Boot ROM */ FPUTABLES : origin = 0x3FEBDC, length = 0x0006A0 /* FPU Tables in Boot ROM */ ROM : origin = 0x3FF27C, length = 0x000D44 /* Boot ROM */ RESET : origin = 0x3FFFC0, length = 0x000002 /* part of boot ROM */ VECTORS : origin = 0x3FFFC2, length = 0x00003E /* part of boot ROM */ PAGE 1 : /* Data Memory */ /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */ /* Registers remain on PAGE1 */ BOOT_RSVD : origin = 0x000000, length = 0x000050 /* Part of M0, BOOT rom will use this for stack */ RAMM0 : origin = 0x000050, length = 0x0003B0 /* on-chip RAM block M0 */ RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */ RAML4 : origin = 0x00C000, length = 0x001000 /* on-chip RAM block L1 */ RAML5 : origin = 0x00D000, length = 0x001000 /* on-chip RAM block L1 */ RAML6 : origin = 0x00E000, length = 0x001000 /* on-chip RAM block L1 */ RAML7 : origin = 0x00F000, length = 0x001000 /* on-chip RAM block L1 */ ZONE7B : origin = 0x20FC00, length = 0x000400 /* XINTF zone 7 - data space */ FLASHB : origin = 0x330000, length = 0x008000 /* on-chip FLASH */ } Kann mir jemand nen Tipp geben, wie ich die Speicheraufteilung bearbeiten kann? mfg Marco
Du kannst es doch selbst verändern wie du es brauchst, also statt FLASHC: origin = 0x328000, length = 0x008000 /* on-chip FLASH */ FLASHA: origin = 0x338000, length = 0x007F80 /* on-chip FLASH */ z.B. sowas schreiben FLASHA: origin = 0x328000, length = 0x00FF80 /* on-chip FLASH */ Damit sollte es egtl. gehen solange FLASHC nicht irgendwo verändert wird, ansonsten kannst du die Bereiche einfach etwas verschieben. Origin ist die Startadresse und length die Länge der Sektion.
> Damit sollte es egtl. gehen solange FLASHC nicht irgendwo verändert > wird, ansonsten kannst du die Bereiche einfach etwas verschieben. Origin > ist die Startadresse und length die Länge der Sektion. Sollte egtl. verwendet statt verändert heißen, aber da es geklappt hat ist das ja egal... ;)
