Hallo, ich habe ein Problem mit AVR-GCC. Ich hatte schon einen Forums-Beitrag für die AVR-Freaks-Seite erstellt, aber die ist nicht erreichbar. Darum seht es mir nach, wenn es jetzt angelsächsisch wird: I got a problem concerning GCC. I think there may be a compiler error. I am not good in AVR-assembler, so some help would be fine. I try to give all necessary information. I try to write a little unix like device system. I will provide it as freeware when I get it to run. In it is some code with these definitions: ---------------------- struct dirs { char *path; uint8_t major; uint8_t minor; }; struct dirs dir[NO_DIRE] = { { "tty" , 0, 0 }, // UART 0 { "ram" , 1, 0 }, // PCF8570, address 0 { "par1", 2, 0 }, // PCF8574, address 0 { "par2", 2, 1 }, // PCF8574, address 1 { "ad0" , 3, 0 }, // PCF8591, address 0, 1. A/D-converter { "ad1" , 3, 1 }, // PCF8591, address 0, 2. A/D-converter { "ad2" , 3, 2 }, // PCF8591, address 0, 3. A/D-converter { "ad3" , 3, 3 }, // PCF8591, address 0, 4. A/D-converter { "da0" , 3,32 }, // PCF8591, address 0, D/A-converter }; ... some other code ... for(j=0; j<NO_DIRE; j++) { if(! strcmp(path, dir[j].path) ) { filetable[i].major = dir[j].major; filetable[i].minor = dir[j].minor; cdev[filetable[i].major].pdopen( filetable[i].minor, mode); return i; } } .. even more code ... The problem is at the call of strcmp. "path" is a pointer to the string "tty". I execute this code in the AVR-Studio 3.53 simulator. At the call of strcmp not the address of the string value dir[j].path is transferred, but part of the string itself! With optimization -O2 the assembler code near the strcmp looks like this (I provide the listing instead of the disassembly code in AVR studio for better readability): 166 006a C091 0000 lds r28,dir 167 006e D091 0000 lds r29,(dir)+1 168 .L17: 169 .stabn 68,0,60,.LM11-open 170 .LM11: 171 0072 6881 ld r22,Y 172 0074 7981 ldd r23,Y+1 173 0076 9B2D mov r25,r11 174 0078 8A2D mov r24,r10 175 007a 00D0 rcall strcmp 176 007c 892B or r24,r25 177 007e 51F0 breq .L24 178 .stabn 68,0,59,.LM12-open 179 .LM12: 180 0080 2496 adiw r28,4 181 0082 1F5F subi r17,lo8(-(1)) 182 0084 1930 cpi r17,lo8(9) 183 0086 A8F3 brlo .L17 After line 166, Y does not contain the address of dir, but the address of the first string. So the load operations at lines 171 and 172 do not load the address of the string, but part of the string itself. At line 175, r22=r23=0x74='tt' instead of 0x006e, what would be the address of the string. So what can I do? With -O0 it is just the same. The compiler installed is avrgcc_freaks20011214a.exe Bye Mario
