Forum: Analoge Elektronik und Schaltungstechnik LTC SWCadIII Fehler nach Erstellung einer Library
Autor: Klaus (Gast)
Hallo !
Ich habe Probleme ein PSPICE Model in LTC Switcher CAD III einzubinden.
Es geht um den OPA561 von Burr-Brown/TI.
Ich habe ein Symbol erstellt und die .MOD Datei dort eingebunden, aber
beim simulieren bekomme ich immer den Fehler:
"Too many parameters for subcircuit type "OPA561" (instance: xu1).
Woran kann das liegen ?
Hier die beiden Beschrebingen:
MODEL
* OPA561 SPICE Macro-model
*   Rev. A    12 August 2003, by W.K. Sands
*   Rev. B    13 August 2003 By Neil Albaugh: ADDED HEADER TEXT & EDITED
TEXT
*  This macromodel has been optimized to model the AC, DC, and transient
response performance within
*     the device data sheet specified limits.
*     Correct operation of this macromodel has been verified on MicroSim
P-Spice ver. 8.0 and on
*     PENZAR Development TopSPICE ver. 6.82d. For help with other analog
simulation software,
*     please consult your software supplier.
*   Copyright 2003 by Texas Instruments Corporation
* BEGIN MODEL OPA561
* PINOUT ORDER IS +IN -IN ILIM V- V+ OUT E/S CLS
* PINOUT ORDER IS  2   3    4   5  6  7   8   9
.SUBCKT OPA561 2 3 4 5 6 7 8 9
* BEGIN MODEL PROGRAMMING
* RESISITORS R144 AND R158 BELOW ARE THE THERMAL RESISTANCE
* IN DEGREES C PER WATT FROM CASE TO AMBIENT. THESE VALUES
* MAY BE CHANGED TO REPRESENT DIFFERENT HEAT SINKING OF THE
* CASE. THE GIVEN VALUES ARE THE LOWEST PRACTICAL. FOR THE
* THERMAL RESISTANCE OF DIFFERENT HEAT SINKING SCENARIOS
* SEE THE DATA SHEET. !!! BOTH VALUES MUST BE THE SAME !!!
R144 123 124 32
R158 127 124 32
* THE TWO COMPUTATION LINES BELOW HAVE DIFFERENT SYNTAX
* FOR PSPICE AND PSPICE- DERIVED SIMULATORS THAN FOR
* BERKELEY SPICE3 AND BERKELEY- DERIVED SPICE3 SIMULATORS
* SUCH AS THE HSPICE SIMULATOR
* PSPICE SYNTAX
E53 119 0 VALUE={V(33)*V(34)}
E56 120 0 VALUE={V(35)*V(36)}
E75 96 0 VALUE={V(37)*V(38)}
* BERKELEY SYNTAX
*B53 119 0 V = V(33) * V(34)
*B56 120 0 V = V(35) * V(36)
*B75 96 0 V = V(37) * V(38)
* HSPICE SYNTAX
*E53 119 0 VOL='V(33)*V(34)'
*E56 120 0 VOL='V(35)*V(36)'
*E75 96 0 VOL='V(37)*V(38)'
* END MODEL PROGRAMMING
* BEGIN SIMULATION NOTES
* FOR AID IN DC CONVERGENCE SET ITL1 FROM 400 TO 4000
* FOR AID IN TRANSIENT ANALYSIS SET ITL4 FROM 50 TO 500
* MODEL TEMPERATURE RANGE IS -40 C TO +125 C, NOT ALL PARAMETERS
ACCURATELY TRACK THOSE OF AN ACTUAL OPA561
* OVER THE FULL TEMPERATURE RANGE BUT ARE AS CLOSE AS PRACTICAL
* END SIMULATION NOTES
* BEGIN MODEL FEATURES
* OPEN LOOP GAIN AND PHASE
* INPUT VOLTAGE NOISE WITH 1/F
* INPUT CURRENT NOISE
* INPUT BIAS CURRENT
* INPUT CAPACITANCE
* INPUT COMMON MODE VOLTAGE RANGE
* INPUT CLAMPS TO RAILS
* CMRR WITH FREQUENCY EFFECTS
* PSRR WITH FREQUENCY EFFECTS
* SLEW RATE
* SLEW RATE VS RL
* QUIESCENT CURRENT
* RAIL TO RAIL OUTPUT STAGE
* HIGH CLOAD EFFECTS
* CLASS AB BIAS IN OUTPUT STAGE
* OUTPUT CURRENT THROUGH SUPPLIES
* OUTPUT CURRENT LIMITING
* REALISTIC CURRENT LIMIT SET
* OUTPUT CLAMPS TO RAILS
* OUTPUT SWING VS OUTPUT CURRENT
* SHUTDOWN
* QUIESCENT CURRENT IN SHUTDOWN
* CURRENT LIMIT FLAG OUTPUT
* E/S PIN FUNCTION INCLUDING PART
* WILL NOT ENABLE IF IN THERMAL
* SHUTDOWN EVEN IF E/S PULLED HIGH
* END MODEL FEATURES
Q20 39 40 41 QNL
R3 42 43 250
R4 44 43 250
R10 40 45 1E3
R11 46 47 1E3
R12 48 6 100E-3
R13 5 49 100E-3
R16 50 51 3E3
R17 52 53 100E-3
R18 41 54 100E-3
D5 55 6 DD
D6 5 55 DD
D7 56 0 DIN
D8 57 0 DIN
I8 0 56 0.1E-3
I9 0 57 0.1E-3
E2 41 0 5 0 1
E3 53 0 6 0 1
D9 58 0 DVN
D10 59 0 DVN
I10 0 58 0.1E-3
I11 0 59 0.1E-3
E4 60 3 58 59 3.3
G2 61 3 56 57 5E-7
R22 5 6 100E6
E5 62 0 53 0 1
E6 63 0 41 0 1
E7 64 0 65 0 1
R30 62 66 1E6
R31 63 67 1E6
R32 64 68 1E6
R33 0 66 100
R34 0 67 100
R35 0 68 100
E10 69 2 68 0 0.48
R36 70 65 1E3
R37 65 71 1E3
C6 62 66 2E-12
C7 63 67 2E-12
C8 64 68 100E-12
E11 72 69 67 0 0.2
E12 61 72 66 0 0.2
E14 73 41 53 41 0.5
D11 50 53 DD
D12 41 50 DD
M1 74 75 49 49 NOUT L=3U W=40000U
M2 76 77 48 48 POUT L=3U W=40000U
M3 78 78 52 52 POUT L=3U W=40000U
M4 79 80 42 42 PIN L=3U W=40U
M5 81 60 44 44 PIN L=3U W=40U
M8 82 82 54 54 NOUT L=3U W=40000U
R43 83 77 100
R44 84 75 100
G3 50 73 85 73 0.2E-3
R45 73 50 30E6
C12 51 55 2E-12
R46 41 79 3E3
R47 41 81 3E3
C13 79 81 1E-12
C14 61 0 9E-12
C15 60 0 9E-12
C16 55 0 140E-12
D13 75 39 DD
D14 86 77 DD
Q15 86 46 53 QPL
V18 61 80 0
M19 87 88 53 53 PIN L=6U W=500U
E17 71 0 61 0 1
E18 70 0 3 0 1
M23 88 88 53 53 PIN L=6U W=500U
V21 87 43 2.2
R59 55 76 10E-3
R60 74 55 10E-3
J1 89 61 89 JC
J2 89 60 89 JC
J3 60 90 60 JC
J4 61 90 61 JC
C21 61 60 7E-12
E20 91 73 81 79 1
R62 91 85 1E4
C23 85 73 0.3E-12
G7 92 73 50 73 -1E-3
G8 73 93 50 73 1E-3
G9 73 94 82 41 1E-3
G10 95 73 53 78 1E-3
D17 95 92 DD
D18 93 94 DD
R66 92 95 100E6
R67 94 93 100E6
R68 95 53 1E3
R69 41 94 1E3
E23 53 83 53 95 1
E24 84 41 94 41 1
R70 93 73 1E6
R71 94 73 1E6
R72 73 95 1E6
R73 73 92 1E6
G11 6 5 96 0 56E-3
I19 0 97 1E-3
D19 97 98 DD
V23 97 99 0.4
R74 0 38 1E6
R75 72 61 1E9
R76 69 72 1E9
R77 2 69 1E9
R78 3 60 1E9
R79 73 85 1E9
R81 83 53 1E9
R82 41 84 1E9
R83 65 0 1E9
V24 100 5 1.2
F1 53 101 V24 -1
F2 102 41 V24 -1
R87 103 101 93
R88 102 103 93
E25 103 0 55 0 1
G12 104 53 76 101 1
G13 41 105 102 74 1
D20 104 53 DD
D21 41 105 DD
G14 88 41 37 0 192E-6
G15 78 82 37 0 400E-6
E48 106 50 37 0 30
E49 107 73 37 0 -30
V49 108 107 15
V50 109 106 -15
R127 106 0 1E12
R128 107 0 1E12
M41 73 109 50 110 PSW L=1.5U W=150U
M42 50 108 73 111 NSW L=1.5U
R129 110 0 1E12
R130 111 0 1E12
M43 112 113 41 41 NEN L=3U W=300U
M44 114 112 41 41 NEN L=3U W=3000U
R131 112 53 1E4
R132 114 115 1E6
V51 115 41 1
M45 116 116 53 53 PEN L=6U W=60U
M46 113 116 53 53 PEN L=6U W=60U
I20 116 41 0.2E-6
C26 113 0 0.1E-12
E50 37 0 117 41 1
V52 114 117 1.111E-6
R133 41 117 1E12
V53 47 104 0
V54 105 45 0
F3 118 41 V53 1
F4 118 41 V54 1
R134 118 53 22E3
M47 9 118 53 53 PIN L=6U W=0.4U
M48 9 118 41 41 NIN L=3U W=0.2U
E51 34 0 76 55 100
E52 33 0 48 76 1
R136 0 33 1E6
R137 0 34 1E6
R138 0 119 1E6
E54 36 0 55 74 100
E55 35 0 5 55 -1
R139 0 35 1E6
R140 0 36 1E6
R141 0 120 1E6
G16 121 0 119 0 -1
C27 121 0 0.2E-4
C28 122 0 1.2E-4
R142 121 122 0.7
R143 122 123 0.7
C29 123 0 2E-4
C32 53 112 25E-12
C33 115 114 9E-12
G17 125 0 120 0 -1
C34 125 0 0.2E-4
C35 126 0 1.2E-4
R156 125 126 0.7
R157 126 127 0.7
C36 127 0 2E-4
E63 128 41 129 0 10
R165 41 128 1E6
V63 130 0 300
M57 131 132 53 53 PIN L=6U W=0.4U
M58 131 132 41 41 NIN L=3U W=0.2U
R166 0 131 8400E3
M59 133 128 41 41 NIN L=3U W=125U
R167 133 53 100E3
R169 41 132 1E6
D24 133 132 DD
C37 132 41 3E-12
R172 134 135 1E6
R173 130 134 1E6
E64 136 0 134 121 10
D25 129 137 DD
D26 138 129 DD
R174 136 129 1E4
V66 138 0 -15
V67 137 0 15
E65 139 0 131 0 6
R175 113 131 1E8
D27 135 137 DD
D28 138 135 DD
R176 135 139 1E4
E66 140 41 141 0 1
R177 41 140 1E6
M64 142 140 41 41 NIN L=3U W=125U
R178 142 53 100E3
D29 142 132 DD
R180 143 144 1E6
R181 130 143 1E6
E67 145 0 143 125 10
D30 141 146 DD
D31 147 141 DD
R182 145 141 1E4
V70 147 0 -15
V71 146 0 15
E68 148 0 131 0 6
D32 144 146 DD
D33 147 144 DD
R183 144 148 1E4
R184 132 131 100E6
I21 6 5 250E-6
I22 0 149 1E-3
D34 149 0 DD
V72 149 150 0.702
R185 0 150 1E6
E69 124 0 150 0 -560
R186 0 124 1E6
R187 0 148 1E9
R188 145 0 1E9
R189 0 139 1E9
R190 136 0 1E9
V74 53 89 0
V75 90 41 0.15
I23 61 0 10E-12
I24 60 0 10E-12
R195 0 37 1E9
R196 38 0 1E6
R197 5 100 1E9
R198 4 100 1E4
M65 8 132 41 41 NIN L=3U W=0.4U
R201 8 113 100E3
M66 113 132 41 41 NIN L=3U W=2U
C38 8 0 2E-12
R302 55 7 1
D35 98 0 DD
E76 38 151 6 5 0.019
V76 99 151 0.29
R304 0 99 1E6
R305 0 151 1E6
R308 0 96 1E9
R309 0 96 1E9
R310 78 53 1E9
R311 41 82 1E9
R312 77 53 1E9
R313 75 41 1E9
R314 88 53 1E9
R315 53 116 1E9
.MODEL DD D
.MODEL DVN D KF=3E-14 IS=1E-16
.MODEL DIN D
.MODEL JC NJF
.MODEL QNL NPN
.MODEL QPL PNP
.MODEL POUT PMOS KP=200U VTO=-0.7
.MODEL NOUT NMOS KP=200U VTO=0.7
.MODEL PMON PMOS KP=195U VTO=-0.7
.MODEL NMON NMOS KP=195U VTO=0.7
.MODEL PIN PMOS KP=200U VTO=-0.7
.MODEL NIN NMOS KP=200U VTO=0.7
.MODEL NEN NMOS KP=200U VTO=0.5 IS=1E-18
.MODEL PEN PMOS KP=200U VTO=-0.7 IS=1E-18
.MODEL PSW PMOS KP=200U VTO=-7.5 IS=1E-18
.MODEL NSW NMOS KP=200U VTO=7.5 IS=1E-18
.ENDS
* END MODEL OPA561
SYMBOL
Version 4
SymbolType BLOCK
LINE Normal -48 81 -48 -80
LINE Normal 144 0 -48 81
LINE Normal -48 -80 144 0
LINE Normal -94 -48 -48 -48
LINE Normal -96 48 -48 48
LINE Normal 48 -81 48 -40
LINE Normal 0 61 0 112
LINE Normal 32 47 32 97
LINE Normal 225 0 144 0
LINE Normal 0 -59 0 -112
LINE Normal 96 -64 96 -20
TEXT -36 -39 Left 0 +
TEXT -36 37 Left 0 -
TEXT -4 -42 Left 0 V+
TEXT -6 43 Left 0 V-
TEXT 63 -5 Left 0 CLS
TEXT 28 -24 Left 0 EN
TEXT 33 24 Left 0 IL
SYMATTR Prefix X
SYMATTR SpiceModel C:\Programme\LTC\SwCADIII\lib\sym\Opamps\OPA561.mod
SYMATTR Value OPA561
SYMATTR Value2 OPA561
PIN -96 -48 TOP 2
PINATTR PinName IN+
PINATTR SpiceOrder 2
PIN -96 48 BOTTOM 2
PINATTR PinName IN-
PINATTR SpiceOrder 3
PIN 32 96 TOP 2
PINATTR PinName IL
PINATTR SpiceOrder 4
PIN 0 112 TOP 2
PINATTR PinName V-
PINATTR SpiceOrder 5
PIN 0 -112 BOTTOM 2
PINATTR PinName V+
PINATTR SpiceOrder 6
PIN 224 0 LEFT 2
PINATTR PinName OUT
PINATTR SpiceOrder 7
PIN 48 -80 BOTTOM 2
PINATTR PinName EN
PINATTR SpiceOrder 8
PIN 96 -64 BOTTOM 2
PINATTR PinName CLS
PINATTR SpiceOrder 9
Vielleicht kennt sich ja jemand damit aus und kann mir helfen.
Danke !
Klaus
Autor: Klaus (Gast)
Weiß das wirklich niemand ?
Das kann doch nicht sein...
Autor: Hannes Jaeger (pnuebergang)
Jammer nicht (immer diese verwöhnten Blagen, die sofort ein Eis haben
wollen wenn sie den Eiswagen sehen ...)
Macht acht Pins.
Das wäre der nicht vorhandene neunte Pin.
Autor: Klaus (Gast)
Geht jetzt !
Danke.
