Ich versuche mir eine Toolchain zu installieren, um mit mica2 motes arbeiten zu können. Weder mit crossdev -t avr, noch manuell will cross-avr/avr-libc-1.2.6 sich kompilieren, es bringt nur diesen Fehler: checking for avr-gcc... avr-gcc -mmcu=avr6 checking for a BSD compatible install... /usr/bin/install -c checking for doxygen... no checking for pngtopnm... no checking for pngtopnm... no configure: error: unexpected value 'avr6' for with_multisubdir !!! Please attach the following file when seeking support: !!! /var/tmp/portage/cross-avr/avr-libc-1.2.6/work/avr-libc-1.2.6/obj-avr/co nfig.log * * ERROR: cross-avr/avr-libc-1.2.6 failed. * Call stack: * ebuild.sh, line 49: Called src_compile * environment, line 2447: Called econf 'src_compile' * ebuild.sh, line 513: Called die * The specific snippet of code: * die "econf failed" * The die message: * econf failed * * If you need support, post the topmost build error, and the call stack if relevant. * A complete build log is located at '/var/tmp/portage/cross-avr/avr-libc-1.2.6/temp/build.log'. * The ebuild environment file is located at '/var/tmp/portage/cross-avr/avr-libc-1.2.6/temp/environment'. * This ebuild is from an overlay: '/usr/local/portage/' * * Messages for package cross-avr/binutils-2.18-r3: * Sorry, but binutils does not support the LINGUAs: en en_GB * Messages for package cross-avr/avr-libc-1.2.6: * * ERROR: cross-avr/avr-libc-1.2.6 failed. * Call stack: * ebuild.sh, line 49: Called src_compile * environment, line 2447: Called econf 'src_compile' * ebuild.sh, line 513: Called die * The specific snippet of code: * die "econf failed" * The die message: * econf failed * * If you need support, post the topmost build error, and the call stack if relevant. * A complete build log is located at '/var/tmp/portage/cross-avr/avr-libc-1.2.6/temp/build.log'. * The ebuild environment file is located at '/var/tmp/portage/cross-avr/avr-libc-1.2.6/temp/environment'. * This ebuild is from an overlay: '/usr/local/portage/' * * GNU info directory index is up-to-date. Hat jemand eine Idee?
avr-libc-1.2.6 ist uralt und schon Jahre lang nicht mehr gepflegt. Aktuell sind wir bei 1.6.2, und selbst die stammt schon vom April des Jahres.
Ich weiß, dass das alles uralt ist. Mein Problem ist, das ich auf Arbeit mit einem Programm arbeiten soll, das nur in tinyos-1 enthalten ist. Und genau das probiere ich eigentlich gerade, auf meinem Gentoo das tinyos ans laufen zu kriegen.
