Input capture changing...
Gast #72239
Hi to all of you...
I am using a ATmega128 at 16Mhz. And I want to measure the time
duration of each logiclevel (1 and 0). At speeds of max 2500Hz.
To keep my problem simple for you, I want to make a pulse on evvery
edge of the input signal, so my input is on "IC1, portD,4 of the
mega128".
I want to use input capture because I need to measure the time as
aqurate as possible. (Not using INt0 and INT1 !!).
After each capture I want to change the edge detection, some fist time
rising, then falling, then rising again etc..
But the problem is that this changing of edge is not working.
please take a look at my test programm, and try to find why it's not
working.
thanks for taking you time to read me...
qyuip
Gast #72241
thanks Crazy horse,
using the "simulate" part of my bascom I found out that cbi and sbi
for the TCCR1B register is NOT working.
NOT WORKING: ( but why not ??)
 cbi   TCCR1B,ICES1
 sbi   TCCR1B,ICES1
therefore I found also a other way of doing the job. (in attach)
I will also try your sollution !
Thanks dear horse  :-)
