1 | #include "s1d13700.h"
2 |
3 |
4 | #define S1D13700_DATA_PORT LATE
5 | #define S1D13700_DATA_PORT_IN PORTE
6 | #define S1D13700_DATA_DIR TRISE
7 |
8 | #define S1D13700_CONTROL_DIR TRISH
9 |
10 | #define S1D13700_A0 LATHbits.LATH0
11 | #define S1D13700_WR LATHbits.LATH1
12 | #define S1D13700_RD LATHbits.LATH2
13 | #define S1D13700_CS LATHbits.LATH3
14 | #define S1D13700_RES LATHbits.LATH4
15 |
16 | void GLCD_Initialize(void);
17 | void GLCD_WriteCommand(unsigned char);
18 | void GLCD_WriteData(unsigned char);
19 | void GLCD_InitPorts(void);
20 | void GLCD_SetCursorAddress(unsigned int);
21 | void GLCD_SetPixel(unsigned int,unsigned int, int);
22 | //-------------------------------------------------------------------------------------------------
23 | //-------------------------------------------------------------------------------------------------
24 | void GLCD_Initialize(void)
25 | {
26 | GLCD_InitPorts();
27 | S1D13700_RES = 0;
28 | Delay10KTCYx( 500 );
29 | S1D13700_RES = 1;
30 |
31 | GLCD_WriteCommand(S1D13700_SYSTEM_SET);
32 | GLCD_WriteData(S1D13700_SYS_P1);
33 | GLCD_WriteData(S1D13700_SYS_P2);
34 | GLCD_WriteData(S1D13700_FY);
35 | GLCD_WriteData(S1D13700_CR);
36 | GLCD_WriteData(S1D13700_TCR);
37 | GLCD_WriteData(S1D13700_LF);
38 | GLCD_WriteData(S1D13700_APL);
39 | GLCD_WriteData(S1D13700_APH);
40 |
41 | GLCD_WriteCommand(S1D13700_SCROLL);
42 | GLCD_WriteData(S1D13700_SAD1L);
43 | GLCD_WriteData(S1D13700_SAD1H);
44 | GLCD_WriteData(S1D13700_SL1);
45 | GLCD_WriteData(S1D13700_SAD2L);
46 | GLCD_WriteData(S1D13700_SAD2H);
47 | GLCD_WriteData(S1D13700_SL2);
48 | GLCD_WriteData(S1D13700_SAD3L);
49 | GLCD_WriteData(S1D13700_SAD3H);
50 | GLCD_WriteData(S1D13700_SAD4L);
51 | GLCD_WriteData(S1D13700_SAD4H);
52 |
53 | GLCD_WriteCommand(S1D13700_CSRFORM);
54 | GLCD_WriteData(S1D13700_CRX);
55 | GLCD_WriteData(S1D13700_CSRF_P2);
56 |
57 | GLCD_WriteCommand(S1D13700_CGRAM_ADR);
58 | GLCD_WriteData(S1D13700_SAGL);
59 | GLCD_WriteData(S1D13700_SAGH);
60 |
61 | GLCD_WriteCommand(S1D13700_CSRDIR_R);
62 |
63 | GLCD_WriteCommand(S1D13700_HDOT_SCR);
64 | GLCD_WriteData(S1D13700_SCRD);
65 |
66 | GLCD_WriteCommand(S1D13700_OVLAY);
67 | GLCD_WriteData(S1D13700_OVLAY_P1);
68 |
69 | GLCD_WriteCommand(S1D13700_DISP_ON);
70 | GLCD_WriteData(S1D13700_FLASH);
71 | }
72 | //-------------------------------------------------------------------------------------------------
73 | //-------------------------------------------------------------------------------------------------
74 | void GLCD_InitPorts(void)
75 | {
76 | S1D13700_DATA_DIR = 0x00;
77 | S1D13700_CONTROL_DIR = 0x00;
78 | S1D13700_RES = 1;
79 | }
80 | //-------------------------------------------------------------------------------------------------
81 | //-------------------------------------------------------------------------------------------------
82 | void GLCD_WriteData(unsigned char dataToWrite)
83 | {
84 | // M6800 Family
85 | S1D13700_CS = 0;
86 |
87 | S1D13700_DATA_PORT = dataToWrite;
88 | S1D13700_DATA_DIR = 0x00;
89 |
90 | S1D13700_A0 = 0;
91 | S1D13700_WR = 0;
92 | S1D13700_RD = 1;
93 |
94 | Delay10TCYx(1);
95 | S1D13700_A0 = 0;
96 | S1D13700_WR = 0;
97 | S1D13700_RD = 0;
98 | S1D13700_CS = 1;
99 | Delay10TCYx(1);
100 | }
101 | //-------------------------------------------------------------------------------------------------
102 | //-------------------------------------------------------------------------------------------------
103 | void GLCD_WriteCommand(unsigned char commandToWrite)
104 | {
105 | S1D13700_CS = 0;
106 | S1D13700_DATA_PORT = commandToWrite;
107 | S1D13700_DATA_DIR = 0x00;
108 |
109 | S1D13700_A0 = 1;
110 | S1D13700_WR = 0;
111 | S1D13700_RD = 1;
112 |
113 | Delay10TCYx(1);
114 | S1D13700_A0 = 0;
115 | S1D13700_WR = 0;
116 | S1D13700_RD = 0;
117 | S1D13700_CS = 1;
118 | Delay10TCYx(1);
119 | }
120 | //-------------------------------------------------------------------------------------------------
121 | //-------------------------------------------------------------------------------------------------
122 | unsigned char GLCD_ReadData(void)
123 | {
124 | unsigned char tmp;
125 | S1D13700_CS = 0;
126 | S1D13700_A0 = 1;
127 | S1D13700_WR = 1;
128 | S1D13700_RD = 1;
129 |
130 | NOP();
131 | S1D13700_DATA_DIR = 0xFF;
132 | NOP();
133 |
134 | tmp = S1D13700_DATA_PORT_IN;
135 |
136 | Delay10TCYx(1);
137 | S1D13700_A0 = 0;
138 | S1D13700_WR = 0;
139 | S1D13700_RD = 0;
140 | S1D13700_CS = 1;
141 | Delay10TCYx(1);
142 |
143 | return tmp;
144 | }
145 | //-------------------------------------------------------------------------------------------------
146 | //-------------------------------------------------------------------------------------------------
147 | void GLCD_SetPixel(unsigned int x,unsigned int y, int color)
148 | {
149 | unsigned char tmp = 0;
150 | unsigned int address = S1D13700_GRAPHICSTART + (40 * y) + (x/8);
151 | GLCD_SetCursorAddress(address);
152 |
153 | GLCD_WriteCommand(S1D13700_MREAD);
154 | tmp = GLCD_ReadData();
155 |
156 | if(color)
157 | tmp |= (1 << (S1D13700_FX - (x % 8)));
158 | else
159 | tmp &= ~(1 << (S1D13700_FX - (x % 8)));
160 |
161 | GLCD_SetCursorAddress(address);
162 | GLCD_WriteCommand(S1D13700_MWRITE);
163 |
164 | GLCD_WriteData(tmp);
165 | // GLCD_WriteData(0xFF);
166 | }
167 | //-------------------------------------------------------------------------------------------------
168 | //-------------------------------------------------------------------------------------------------
169 | void GLCD_SetCursorAddress(unsigned int address)
170 | {
171 | GLCD_WriteCommand(S1D13700_CSRW);
172 | GLCD_WriteData((unsigned char)(address & 0xFF));
173 | GLCD_WriteData((unsigned char)(address >> 8));
174 | }
