versuche mit AVRDUDE ein Programm auf einen 644P zu brennen, jedoch
kommt hier die Meldung "AVR Device not responding".
-V gibt folgendes aus:
1 | avrdude: Version 5.5, compiled on Jun 9 2008 at 14:32:04
2 | Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
3 |
4 | System wide configuration file is "C:\WinAVR-20080610\bin\avrdude.conf"
5 |
6 |
7 | Using Port : lpt1
8 | Using Programmer : sp12
9 | AVR Part : ATMEGA644P
10 | Chip Erase delay : 9000 us
11 | PAGEL : PD7
12 | BS2 : PA0
13 | RESET disposition : dedicated
14 | RETRY pulse : SCK
15 | serial program mode : yes
16 | parallel program mode : yes
17 | Timeout : 200
18 | StabDelay : 100
19 | CmdexeDelay : 25
20 | SyncLoops : 32
21 | ByteDelay : 0
22 | PollIndex : 3
23 | PollValue : 0x53
24 | Memory Detail :
25 |
26 | Block Poll Page
27 | Polled
28 | Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW Max
29 | W ReadBack
30 | ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ---
31 | -- ---------
32 | eeprom 65 10 128 0 no 2048 8 0 9000 90
33 | 00 0xff 0xff
34 | flash 33 6 256 0 yes 65536 256 256 4500 45
35 | 00 0xff 0xff
36 | lock 0 0 0 0 no 1 0 0 9000 90
37 | 00 0x00 0x00
38 | lfuse 0 0 0 0 no 1 0 0 9000 90
39 | 00 0x00 0x00
40 | hfuse 0 0 0 0 no 1 0 0 9000 90
41 | 00 0x00 0x00
42 | efuse 0 0 0 0 no 1 0 0 9000 90
43 | 00 0x00 0x00
44 | signature 0 0 0 0 no 3 0 0 0
45 | 0 0x00 0x00
46 | calibration 0 0 0 0 no 1 0 0 0
47 | 0 0x00 0x00
48 |
49 | Programmer Type : PPI
50 | Description : Steve Bolt's Programmer
51 | VCC = 4,5,6,7,8
52 | BUFF = (not used)
53 | RESET = 3
54 | SCK = 2
55 | MOSI = 9
56 | MISO = 11
57 | ERR LED = 0
58 | RDY LED = 0
59 | PGM LED = 0
60 | VFY LED = 0
61 |
62 | avrdude: AVR device not responding
63 | avrdude: initialization failed, rc=-1
64 | Double check connections and try again, or use -F to override
65 | this check.
66 |
67 |
68 | avrdude done. Thank you.
Was kann das nur sein???
Kalle
