Hi, ich bin halt neu hier und hoffe ich kann mein Problem gut beschreiben . ich benutze Atmaga8 und versuche durch ein USBprog das Programm auf dem Atmaga8 zu laufen zu bringen . wenn ich aber WinAVR[programm] drücke . bekomme ich diese fehlermeldung. hat jemand Idee was dass sein soll ?? Danke > "make.exe" program avrdude -p atmega8 -P usb -c avrispv2 -v -v -B 10 -U flash:w:main.hex avrdude: Version 5.5, compiled on Jun 9 2008 at 14:32:04 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ System wide configuration file is "C:\WinAVR-20080610\bin\avrdude.conf" Using Port : usb Using Programmer : avrispv2 Setting bit clk period: 10.0 avrdude: usbdev_open(): Found AVRISP mk2 Clone, serno: 0000A00128255 AVR Part : ATMEGA8 Chip Erase delay : 10000 us PAGEL : PD7 BS2 : PC2 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 4 20 128 0 no 512 0 0 9000 9000 0xff 0xff flash 33 10 64 0 yes 8192 64 128 4500 4500 0xff 0x00 lfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00 lock 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00 calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 Programmer Type : STK500V2 Description : Atmel AVR ISP V2 Programmer Model: AVRISP mkII Hardware Version: 0 Firmware Version: 9.09 Vtarget : 5.0 V SCK period : 10.37 us avrdude: stk500v2_command(): command failed avrdude: initialization failed, rc=-1 Double check connections and try again, or use -F to override this check. avrdude done. Thank you. make.exe: *** [program] Error 1 > Process Exit Code: 2 > Time Taken: 00:01
Double check connections and try again, or use -F to override this check. Ist der Atmega frisch? Wie gesagt, verbindungen überprüfen: Kabellänge?
mit avtstudio hat auch nicht geklaupt!! ich mache leber gerne mit WinAVR also jetzt bekomme ich dem fehlermeldung unten wie kann ich dem device einstelen von USbprog avrdude -p atmega8 -P usb -c avrispv2 -v -v -B 10 -U flash:w:main.hex avrdude: Version 5.5, compiled on Jun 9 2008 at 14:32:04 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ System wide configuration file is "C:\WinAVR-20080610\bin\avrdude.conf" Using Port : usb Using Programmer : avrispv2 Setting bit clk period: 10.0 avrdude: usbdev_open(): did not find any USB device "usb" make.exe: *** [program] Error 1
seufz RTFM Usbprog verhält sich bei korrekter Firmware (ggf. neuflashen) (ist überhaupt der Bootloader drauf) wie ein avrispmkII (avrdude -c?). PS: -p atmega8 funzt so net (avrdude -p ?) muss m8 heißen
ich benutzte halt dem online Pool und er hat ein divice Uplodet dem TestLib Usb sieht dann so aus ist das in ordnung wenn nicht was fehlt bitte hier genau DLL version: 0.1.12.1 Driver version: 0.1.12.1 bus/device idVendor/idProduct bus-0/\\.\libusb0-0002--0x03eb-0x2104 03EB/2104 - Manufacturer : B.Sauter - Product : AVRISP mk2 Clone - Serial Number: 0000A00128255 wTotalLength: 32 bNumInterfaces: 1 bConfigurationValue: 1 iConfiguration: 0 bmAttributes: 80h MaxPower: 25 bInterfaceNumber: 0 bAlternateSetting: 0 bNumEndpoints: 2 bInterfaceClass: 0 bInterfaceSubClass: 0 bInterfaceProtocol: 0 iInterface: 0 bEndpointAddress: 82h bmAttributes: 02h wMaxPacketSize: 64 bInterval: 0 bRefresh: 0 bSynchAddress: 0 bEndpointAddress: 02h bmAttributes: 02h wMaxPacketSize: 64 bInterval: 0 bRefresh: 0 bSynchAddress: 0 bus-0/\\.\libusb0-0003--0x062a-0x0000 062A/0000 wTotalLength: 34 bNumInterfaces: 1 bConfigurationValue: 1 iConfiguration: 0 bmAttributes: a0h MaxPower: 50 bInterfaceNumber: 0 bAlternateSetting: 0 bNumEndpoints: 1 bInterfaceClass: 3 bInterfaceSubClass: 1 bInterfaceProtocol: 2 iInterface: 0 bEndpointAddress: 81h bmAttributes: 03h wMaxPacketSize: 4 bInterval: 10 bRefresh: 0 bSynchAddress: 0
HMM, passt schon. avrdude -c avrispmkII -p m8 -P usb ggf -i 10 oder -B 10 anhängen PS: Dein Deutsch ist grausam :(
vesuche jetzt anzuhängen. hoffe ich werde es schafen wegen die sprache gut dass du das bemerk hast ich kann halt 50:50 deutsch :)
entschuldige wider das gleiche Problem auch mit -B 10 ich weiß nix was ich machen soll AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER) AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY) AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE) AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER) AVRDUDE_FLAGS += -B 10
Was ging denn an avrstudio nicht? Libusb nicht mitinstalliert? http://embedded-projects.net/index.php?page_id=148
