Forum: Mikrocontroller und Digitale Elektronik C515C und CAN = Problem
von nic (Gast)
Hallo miteinander,
ich versuche gerade eine Kommunikation zwischen 2 identischen Controller
(C515c) zu programmieren. Mein einer Controller sendet mir
kontinuierlich ein Byte.
Auf der Empfangsseite habe ich folgenden Code:
#include "regc515c.h"
#include "intc515c.h"
#include "canreg.h"
#include <stdio.h>
void can_init (void);
void send_1 (void);
void def_1 (void);
void main(void) {
 can_init();
 EAL=1;
 def_1();
 while(1) {
unsigned char IE = 1; // all CAN interrupts enabled
unsigned char SIE = 0; // status interrupts disabled
unsigned char EIE = 0; // error interrupts disabled
void can_init (void) {
SYSCON &= 0xFC; // XMAP0=0, XMAP1=0
XPAGE = 0xF7; // CAN memory space in XRAM
GMS0 = 0x20; GMS1 = 0x11; // global mask short
UGML0 = 0x20; UGML1 = 0x11; // global mask long
LGML0 = 0xFF; LGML1 = 0xFF;
UMLM0 = 0xFF; UMLM1 = 0xFF; // last message mask
LMLM0 = 0xFF; LMLM1 = 0xFF;
CR = 0x41; // INIT=1 and CCE=1 (enable access baudrate)
BTR0 = 0xC1; BTR1 = 0x6B; // access bit timing registers: 10 MHz,250
kBaud
CR = 0x01; // CCE=0 (disable access baudrate)
SR = 0xE7; // clear TXOK and RXOK
MCR0_M1 = 0x55; // message 1 not valid
MCR0_M15 = 0x55; // message 15 not valid
IEN2 = 2; // enable CAN interrupt (ECAN=1)
CR = 0; // INIT=0
if ( IE) CR |= 0x02; // enable global can_int
if (SIE) CR |= 0x04; // enable can_status_int
if (EIE) CR |= 0x08; // enable can_error_int
// definition message 1, standard transmission frame
void def_1 (void)
MCR1_M1 = 0xFB; // CPUUPD=1
UAR0_M1 = 0x11; UAR1_M1 = 0x20;// identifier 00010001 001
MCFG_M1 = 0x10; // frame definition
MCR0_M1 = 0x99; // MSGVAL=1, TXIE=0, RXIE=1, INTPND=0
MCR1_M1 = 0x55; // RMTPND=0, TXRQ=0, CPUUPD=0, NEWDAT=0
// CAN interrupt
void int_can (void) interrupt CANI
  unsigned char status, intreg;
while (intreg = IR)
{status = SR; SR = 0; // read and reset CAN status
  switch (intreg)
  {case 1: // status and error interrupt
  if (SIE) // status interrupts
  {if (status & 0x08) {}// transmit interrupt
  if (status & 0x10) {}// receive interrupt
  if (status & 0x07) {}// erroneous transfer
  if (EIE) // error interrupts
  {if (status & 0x40) {}// EWRN has changed
  if (status & 0x80) {}// BUSOFF has changed
  break;
  case 3: // message 1 interrupt
  MCR0_M1 = 0xFD; // reset INTPND
  if (status & 0x08) {} // transmit interrupt
  if (status & 0x10) {} // receive interrupt
  break;
  case 4: // message 2 interrupt
  P5=DB0_M1;
  break;
Nun habe ich folgendes Problem. Wenn der Controller in die IR springt,
bekomme ich als Status im SR ein ReceiveOK. Soweit so gut. Aber
irgendwie
bekomme ich im intreg(IR) ein Interrupt bei Message2 und nicht bei
Message1. An was kann das liegen?
mfG nic
