1 | #ifndef _I2C_MASTER_H
2 | #define _I2C_MASTER_H
3 |
4 | /*****************************************************************************
5 | ******************************************************************************
6 | **** ****
7 | **** I²C Groundroutinen für AVR Prozessoren mit hardwareseitigem ****
8 | **** I²C Bus. Start, Stop, read und Send Routinen ****
9 | **** ****
10 | **** Autor: Robert Schilling robert.schilling@gmx.at ****
11 | **** Stefan Tschiggerl stefan.tschiggerl@gmx.net ****
12 | **** Datum: 26.09.2006 ****
13 | **** ****
14 | **** Hardware: Ein Avr Mikrocontroller mit hardwareseitigem ****
15 | **** I²C Bus. ****
16 | **** ****
17 | **** Software: i2c_master Library: I²C Basic Routinen ****
18 | **** ****
19 | ******************************************************************************
20 | *****************************************************************************/
21 |
22 | #include <avr/io.h>
23 | #include <stdlib.h>
24 |
25 | #define SOFTWARE 0x00
26 | #define HARDWARE 0x01
27 |
28 | #define I2C_MODE SOFTWARE
29 |
30 |
31 | #if I2C_MODE == SOFTWARE
32 | #define I2C_PORT PORTC
33 | #define I2C_PIN PINC
34 | #define I2C_SCL PC3
35 | #define I2C_SDA PC2
36 |
37 | #define set_output(port, pin) port |= (1 << pin)
38 | #define set_input(port, pin) port &= ~(1 << pin)
39 |
40 | #define SDA_LOW() I2C_PORT &= ~(1 << I2C_SDA)
41 | #define SDA_HIGH() I2C_PORT |= (1 << I2C_SDA)
42 |
43 | #define SCL_LOW() I2C_PORT &= ~(1 << I2C_SCL)
44 | #define SCL_HIGH() I2C_PORT |= (1 << I2C_SCL)
45 |
46 | #endif
47 |
48 | #define ACK 0x01
49 | #define NACK 0x00
50 |
51 | /**************************************************************
52 | Initialisiert den I²C Bus des AVR
53 |
54 | Parameter: NONE
55 |
56 |
57 | Rückgabewert: NONE
58 | **************************************************************/
59 | void i2c_init(void);
60 |
61 | /**************************************************************
62 | Sendet ein Startkommando
63 |
64 | Parameter: adress Adresse des I²C Telnehmers
65 | r_w Lesen oder schreiben
66 |
67 | Rückgabewert: NONE
68 | **************************************************************/
69 |
70 | void i2c_start(unsigned char adress, uint8_t r_w);
71 |
72 | /**************************************************************
73 | Sendet ein Stopkommando
74 |
75 | Parameter: NONE
76 |
77 | Rückgabewert: NONE
78 | **************************************************************/
79 |
80 | void i2c_stop(void);
81 |
82 | /**************************************************************
83 | Sendet ein Byte über den I²C Bus
84 |
85 | Parameter: data Datenbyte das gesendet werden soll
86 |
87 | Rückgabewert: NONE
88 | **************************************************************/
89 |
90 | void i2c_send(unsigned char data);
91 |
92 | /**************************************************************
93 | Empfängt ein Byte über den I²C Bus
94 |
95 | Parameter: NONE
96 |
97 | Rückgabewert: Das Byte das ausgelsesn wurde
98 | **************************************************************/
99 |
100 | unsigned char i2c_read(uint8_t ackflag);
101 |
102 | #endif
