Nabend zusammen,
folgendes Programm:
1 | $regfile = "m8def.dat"
2 | $framesize = 48
3 | $swstack = 64
4 | $hwstack = 64
5 | $crystal = 8000000
6 | $baud = 9600
7 |
8 |
9 | Dim Empfangen As String * 3
10 | Dim X As Bit , Y As Bit , Z As Bit
11 | Dim Ansteuerung As Byte , Wecksound As Byte
12 | Dim Ansteuerung2 As Integer
13 |
14 | X = 0
15 | Y = 0
16 | Z = 0
17 | Wecker = 0
18 |
19 | Config Portb = Output
20 |
21 | Config Portc = Output
22 |
23 | Config Portd.4 = Output
24 | Config Portd.3 = Output
25 | Summer Alias Portd.4
26 | Pc Alias Portd.3
27 |
28 | On Urxc Onrxd
29 | Enable Urxc
30 | Enable Interrupts
31 |
32 |
33 |
34 |
35 |
36 | Do
37 | If Len(empfangen) > 2 Then
38 | Ansteuerung2 = Val(empfangen)
39 | Select Case Ansteuerung2
40 | Case 400
41 | Pc = 1
42 | Empfangen = ""
43 | Case 401
44 | Pc = 0
45 | Empfangen = ""
46 | Case Is < 256
47 | Gosub Ansteuern
48 | End Select
49 | End If
50 | Loop
51 | End
52 |
53 | Ansteuern:
54 | Ansteuerung = Ansteuerung2
55 | Portb = Ansteuerung
56 | Gosub Stehlampe
57 | Gosub Leuchtkugel
58 | Gosub Lichterkette
59 | Empfangen = ""
60 | Return
61 |
62 | Lichterkette:
63 | If Portb.4 = 1 Then : If X = 0 Then : Portc = &B00000000 : Portc.1 = 1 : X = 1 : Waitms 500 : Portc = &B00000000 : End If : End If
64 | If Portb.4 = 0 Then : If X = 1 Then : Portc = &B00000000 : Portc.0 = 1 : X = 0 : Waitms 500 : Portc = &B00000000 : End If : End If
65 | Return
66 |
67 | Stehlampe:
68 | If Portb.6 = 1 Then : If Y = 0 Then : Portc = &B00000000 : Portc.3 = 1 : Y = 1 : Waitms 500 : Portc = &B00000000 : End If : End If
69 | If Portb.6 = 0 Then : If Y = 1 Then : Portc = &B00000000 : Portc.2 = 1 : Y = 0 : Waitms 500 : Portc = &B00000000 : End If : End If
70 | Return
71 |
72 | Leuchtkugel:
73 | If Portb.7 = 1 Then : If Z = 0 Then : Portc = &B00000000 : Portc.5 = 1 : Z = 1 : Waitms 500 : Portc = &B00000000 : End If : End If
74 | If Portb.7 = 0 Then : If Z = 1 Then : Portc = &B00000000 : Portc.4 = 1 : Z = 0 : Waitms 500 : Portc = &B00000000 : End If : End If
75 | Return
76 |
77 | Onrxd:
78 | Empfangen = Empfangen + Chr(udr)
79 | Return
Problem ist: Der Portb wird nicht richtig gesetzt. Nachdem die
"Ansteuern" Schleife ausgeführt wurde, messe ich jeden Port von b durch
aber keiner ist "1". Deshalb funktionieren auch die Schleifen
Lichterkette, Leuchtkugel und Stehlampe nicht. Ist da irgendwas falsch?
(Der µC läuft über (Mhz Interner Takt)
