Forum: PC Hard- und Software externe Seagate-Festplatte, Test mit smartmontools
Autor: Guest (Gast)
Ich habe meine externe Platte (FreeAgent, an USB) mit smartctl unter
Linux getestet.
Sind folgende Meldungen problematisch?
# smartctl -d sat,12 -i -T permissive /dev/sdb
smartctl version 5.38 [i686-pc-linux-gnu] Copyright (C) 2002-8 Bruce
Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Model Family:     Seagate Barracuda 7200.11
Device Model:     ST3750330AS
Serial Number:    xxxxx
Firmware Version: SD35
User Capacity:    750.156.374.016 bytes
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 4
Local Time is:    Mon Jan 19 04:16:44 2009 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Error SMART Status command failed
Please get assistance from http://smartmontools.sourceforge.net/
Values from ATA Return Descriptor are:
 00     09 0c 00 00 00 00 00 00  00 4f 00 00 00 00
# smartctl -d sat,12 -A -T permissive /dev/sdb
Allen
=== START OF READ SMART DATA SECTION ===
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE
UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   113   100   006    Pre-fail  Always
-       50772626
  3 Spin_Up_Time            0x0003   089   089   000    Pre-fail  Always
-       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always
-       16
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always
-       0
  7 Seek_Error_Rate         0x000f   100   253   030    Pre-fail  Always
-       674115
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always
-       12
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always
-       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always
-       10
184 Unknown_Attribute       0x0032   100   100   099    Old_age   Always
-       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always
-       0
188 Unknown_Attribute       0x0032   100   100   000    Old_age   Always
-       0
189 High_Fly_Writes         0x003a   099   099   000    Old_age   Always
-       1
190 Airflow_Temperature_Cel 0x0022   055   046   045    Old_age   Always
-       45 (Lifetime Min/Max 20/45)
194 Temperature_Celsius     0x0022   045   054   000    Old_age   Always
-       45 (0 18 0 0)
195 Hardware_ECC_Recovered  0x001a   038   037   000    Old_age   Always
-       50772626
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always
-       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age
Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always
-       0
Autor: Guest (Gast)
Auch bei meiner internen Platte gibt es unberuhigende Meldungen:
# smartctl -iAH /dev/sda
Allen
Model Family:     Seagate Barracuda 7200.10 family
Device Model:     ST3250410AS
Serial Number:    yyyyyy
Firmware Version: 3.AAC
User Capacity:    250.058.268.160 bytes
ATA Version is:   7
ATA Standard is:  Exact ATA specification draft version not indicated
Local Time is:    Mon Jan 19 04:27:32 2009 CET
SMART overall-health self-assessment test result: PASSED
  1 Raw_Read_Error_Rate     0x000f   109   096   006    Pre-fail  Always
-       189733137
  3 Spin_Up_Time            0x0003   097   097   000    Pre-fail  Always
-       0
-       438
-       0
  7 Seek_Error_Rate         0x000f   075   060   030    Pre-fail  Always
-       34707754
  9 Power_On_Hours          0x0032   097   097   000    Old_age   Always
-       3019
-       0
-       438
-       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always
-       0
190 Airflow_Temperature_Cel 0x0022   063   057   045    Old_age   Always
-       37 (Lifetime Min/Max 21/38)
194 Temperature_Celsius     0x0022   037   043   000    Old_age   Always
-       37 (0 16 0 0)
195 Hardware_ECC_Recovered  0x001a   059   051   000    Old_age   Always
-       162438296
-       0
Offline      -       0
-       0
200 Multi_Zone_Error_Rate   0x0000   100   253   000    Old_age
Offline      -       0
202 TA_Increase_Count       0x0032   100   253   000    Old_age   Always
-       0
Sollte ich die Platten ersetzen?
Autor: Ich (Gast)
Die externe ist in Ordnung (zur Temp.: Hersteller läßt 60°C zu, unter
40°C ist besser für längere Lebensdauer)
Die Interne ist auch in Ordnung, wobei es so aussieht, daß Du Probleme
mit Vibrationen in Deinem Rechner hast. Entweder Festplatte mechanisch
entkoppeln oder Störenfried beseitigen.
Autor: ... ... (docean) Benutzerseite
Aus welchem Wert liest du das ab?
Autor: Ich (Gast)
-       189733137
Diese Fehler entstehen u.A. durch mechanische Einflüsse auf die
Festplatte, wenn der Lesekopf die Spur verliert und er noch mal die
Sektoren lesen muß.
Das ist jetzt nichts kritisches, bei meiner Seagate sind
01  Raw Read Error Rate  41689226
04  Start/Stop Count  1243
09  Power-On Time Count  11217
und rund 3*so lange in Betrieb wie Deine.
