1 | // working on a MSP430 F2013 (eZ430 Development Tool)
2 | //----------------------------------------------------------------------
3 | #include <io430x20x3.h> // Specific device
4 | #include <intrinsics.h> // Intrinsic functions
5 | #include <stdint.h> // Integers of defined sizes
6 | //----------------------------------------------------------------------
7 | void main (void)
8 | {
9 | WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer
10 | // Select clocks
11 | BCSCTL1 = CALBC1_8MHZ; // Set range for calibrated DCO at 8MHz
12 | DCOCTL = CALDCO_8MHZ; // Set DCO tap and modulation
13 | BCSCTL3 = LFXT1S_2; // ACLK from VLO (12KHz)
14 | BCSCTL2 = DIVS_3; // SMCLK = DCO/8 = 1Mhz
15 | // Set up Timer_A for PWM on active high LED, channel 1
16 | TACCR0 = 200; // should be 200us
17 | TACCR1 = 100; // Duty cycle D = 0.5 initially (will be variable in the future)
18 | TACCTL0 = CCIE; // Interrupts on compare to update PWM
19 | TACCTL1 = OUTMOD_7 | CCIE; // Reset/set (positive PWM), interrupts
20 | // Configure ports 1 and 2 with pull resistors on unused pins
21 | P1OUT = 0; // Preclear output buffer
22 | P1DIR = BIT0; // Set P1.0 to output, others input
23 | P1REN = 0xFF & ~BIT0; // Pull resistors on P1[7:1]
24 | P2SEL = 0; // Digital i/o rather than crystal
25 | P2REN = BIT6 | BIT7; // Pull resistors on pins that exist
26 | // Start timer from ACLK, no division, Up mode, clear, with interrupts
27 | TACTL = TASSEL_2 | ID_0 | MC_1 | TACLR | TAIE;
28 | for (;;) { // Loop forever
29 | __low_power_mode_3(); // Enter LPM3 between interrupts
30 | }
31 | }
32 | //----------------------------------------------------------------------
33 | // Interrupt service routine for CCIFG1 and TAIFG; share vector
34 | //----------------------------------------------------------------------
35 | #pragma vector = TIMERA1_VECTOR
36 | __interrupt void TIMERA1_ISR (void) // ISR for CCIFG1 and TAIFG
37 | {
38 | switch (__even_in_range(TAIV, 10)) {
39 | case 0: // No interrupt pending
40 | break; // No action
41 | case 2: // Vector 2: CCIFG1
42 | P1OUT_bit.P1OUT_0 = 0; // End of duty cycle: Turn off LED
43 | break;
44 | case 10: // Vector A: TAIFG, last value possible
45 | P1OUT_bit.P1OUT_0 = 1; // Start of PWM cycle: Turn on LED
46 | break;
47 | default: // Should not be possible
48 | for (;;) { // Loop here for ever
49 | }
50 | }
51 | }
