1 | #include <avr/io.h>
2 | #include <avr/interrupt.h>
3 | #include <stdio.h>
4 |
5 | #include <util/delay.h> // F_CPU und -Os nicht vergessen!
6 | #define DEBUG 0 // steuert print Ausgabe
7 | #define DUMMY 1 // weil em4095.h und em4095_read_tag() fehlen
8 |
9 | #if DUMMY
10 | uint8_t em4095_read_tag(uint8_t *k)
11 | {
12 | return 1;
13 | }
14 | #else
15 | #include "em4095.h"
16 | #endif
17 |
18 | #define KEYS 2
19 | #define BAUD 9600UL
20 |
21 | /*EEPROM schreiben*/
22 | void EEPROM_write(unsigned int uiAddress, uint8_t ucData)
23 | {
24 | /* Wait for completion of previous write */
25 | while(EECR & (1<<EEPE))
26 | ;
27 |
28 | /* Set up address and data registers */
29 | EEAR = uiAddress;
30 | EEDR = ucData;
31 | /* Write logical one to EEMPE */
32 | EECR |= (1<<EEMPE);
33 | /* Start eeprom write by setting EEPE */
34 | EECR |= (1<<EEPE);
35 |
36 | /* Wait for completion of previous write */
37 | while(EECR & (1<<EEPE))
38 | ;
39 | }
40 |
41 |
42 | /*EEPROM lesen*/
43 | uint8_t EEPROM_read(unsigned int uiAddress)
44 | {
45 | /* Wait for completion of previous write */
46 | while(EECR & (1<<EEPE))
47 | ;
48 |
49 | /* Set up address register */
50 | EEAR = uiAddress;
51 | /* Start eeprom read by writing EERE */
52 | EECR |= (1<<EERE);
53 | /* Return data from data register */
54 |
55 | return EEDR;
56 | }
57 |
58 |
59 | void uart_putc(uint8_t c)
60 | {
61 | loop_until_bit_is_set(UCSRA, UDRE);
62 | UDR = c;
63 | }
64 |
65 |
66 | /*Funktion zum Bitweisen-Vergleichen der TAG IDs*/
67 | uint8_t cmp_tag(uint8_t *a, uint8_t *b)
68 | {
69 | int i;
70 | for (i=0;i<5;i++)
71 | {
72 | if(*a++ != *b++)
73 | return 0;
74 | }
75 | return 1;
76 | }
77 |
78 |
79 | /*RS232-Ausgabe */
80 | void print(char *text)
81 | {
82 | while (*text)
83 | uart_putc(*text++);
84 | }
85 |
86 | void nibbleout(uint8_t wert)
87 | {
88 | if(wert < 10)
89 | uart_putc(wert+'0');
90 | else
91 | uart_putc(wert+'A'-10);
92 | }
93 |
94 |
95 | void hexout(uint8_t wert)
96 | {
97 | nibbleout((wert&0xf0)>>4);
98 | nibbleout(wert&0xf);
99 | }
100 |
101 |
102 | void tagout(uint8_t *a)
103 | {
104 | int i;
105 | for (i=0;i<5;i++)
106 | {
107 | hexout(*a++);
108 | }
109 | print("\n\r");
110 | }
111 |
112 |
113 | int main(void)
114 | {
115 | // Lokale Variablen
116 | uint8_t tag[5]; // eingelesener Tag
117 | uint8_t key[5]; // Schlüssel (= gespeicherter Tag)
118 | unsigned char EEPROM_Inhalt;
119 | #if 0
120 | volatile uint32_t d;
121 | #else
122 | uint8_t d;
123 | #endif
124 |
125 | // Ports initialisieren
126 | DDRD = 1<<PD2;
127 | PORTD = 1<<PD2;
128 | //Leuchtdiodenport
129 | DDRB = 1<<PB6|1<<PB7;
130 |
131 | // UART initialisieren
132 | UCSRB = 1<<TXEN;
133 | UCSRC = 1<<UCSZ1 | 1<<UCSZ0;
134 | UBRRH = (uint8_t) (F_CPU / (BAUD * 16) - 1) / 256;
135 | UBRRL = (uint8_t) (F_CPU / (BAUD * 16) - 1);
136 |
137 | // Timer0 initialisieren
138 | TCCR0B = 1<<CS01 | 1<<CS00; //Timer/Counter0 prescaler 64
139 | MCUCR |= 1<<ISC10; //Any logical change on INT1 generates an interrupt request
140 | GIMSK |= 1<<INT1; //External interrupt request 1 enable (demod_out from RFID chip)
141 | sei();
142 |
143 | while (1)
144 | {
145 | /*
146 | Erstes Byte aus dem EEPROM einlesen
147 | Wenn 1. byte aus EEPROM UNGLEICH 0x1F
148 | ist, dann key mit em4095_read_tag()
149 | einlesen und in EEPROM speichern
150 | */
151 | EEPROM_Inhalt = EEPROM_read(0);
152 |
153 | if (EEPROM_Inhalt != 0x1F)
154 | {
155 | uint8_t KeyEingelesen = 0;
156 | while (!KeyEingelesen)
157 | {
158 | if (em4095_read_tag(key))
159 | {
160 | #if DEBUG
161 | print("Schluessel eingelesen: ");
162 | #endif
163 | tagout(key);
164 | KeyEingelesen = 1;
165 | #if DEBUG
166 | print("\n\r");
167 | #endif
168 | }
169 | }
170 | EEPROM_write(0,key[0]);
171 | EEPROM_write(1,key[1]);
172 | EEPROM_write(2,key[2]);
173 | EEPROM_write(3,key[3]);
174 | EEPROM_write(4,key[4]);
175 | }
176 | else
177 | {
178 | // key bereits im EEPROM vorhanden
179 | key[0]=EEPROM_read(0);
180 | key[1]=EEPROM_read(1);
181 | key[2]=EEPROM_read(2);
182 | key[3]=EEPROM_read(3);
183 | key[4]=EEPROM_read(4);
184 | }
185 |
186 | /*
187 | Weitere tags einlesen und mit key
188 | vergleichen und Ergebnis an LEDs anzeigen
189 | Abbruch durch Druck auf Taster
190 | */
191 | uint8_t abbruch = 0;
192 | while (!abbruch)
193 | {
194 | if (em4095_read_tag(tag))
195 | {
196 | tagout(tag);
197 | if (cmp_tag(key,tag))
198 | PORTB = 1<<PB6; // Led an Port PB6 aus und Led an PB7 an
199 | else
200 | PORTB = 1<<PB7; // Led an Port PB7 aus und Led an PB6 an
201 | }
202 | else
203 | {
204 | #if 0
205 | PORTB = 1<<PB7; //Led an Port PB7 aus und Led an PB6 an
206 | #else
207 | PORTB = (1<<PB7) | (1<<PB7); //Led an Port PB7 und PB6 aus
208 | #endif
209 | }
210 |
211 | #if 0
212 | for (d=0; d<50000; d++);
213 |
214 | if (PIND & (1<<PD4))
215 | {
216 | EEPROM_write(0,0x0);
217 | abbruch = 1;
218 | }
219 | #else
220 | /*
221 | User ca. 3s (120*25=3000) Zeit geben,
222 | um Taster zu drücken. Tastendruck selbst
223 | wird alle 25ms gepollt
224 |
225 | Tastendruck löscht 1. Byte vom EEPROM
226 | (key ungültig machen)
227 | */
228 | for (d = 0; d < 120; d++)
229 | {
230 | // active-high Taster gedrückt?
231 | if (PIND & (1<<PD4))
232 | {
233 | EEPROM_write(0,0x0);
234 | abbruch = 1; // while(!abbruch) verlassen
235 | break; // for sofort verlassen
236 | }
237 | _delay_ms(25);
238 | }
239 | #endif
240 | } // while(!abbruch)
241 | }
242 | }
