1 | writeCommand(0xAE); // x // set off
2 |
3 | waitms(100);
4 |
5 | writeCommand(0xB3); // // clock divider
6 | writeCommand(0x91); // // clock divider
7 |
8 | writeCommand(0xA8); // // multiplex ratio
9 | writeCommand(0x3F); // // multiplex ratio
10 |
11 | writeCommand(0xA2); // // set offset
12 | writeCommand(0x44); // // set offset
13 |
14 | writeCommand(0xA1); // // start line
15 | writeCommand(0x00); // // start line
16 |
17 | writeCommand(0xA0); // // re-map
18 | writeCommand(0x41); // // re-map
19 |
20 | writeCommand(0xAD); // // set master config
21 | writeCommand(0x02); // // set master config
22 |
23 | writeCommand(0xCF); // // set bias current
24 | writeCommand(0xF0); // // set bias current
25 |
26 | writeCommand(0x86); // // set current range
27 |
28 | writeCommand(0x81); // // set contrast
29 | writeCommand(0x7F); // // set contrast
30 |
31 | writeCommand(0xB2); // // set row period
32 | writeCommand(0x46); // // set row period
33 |
34 | writeCommand(0xB1); // // set phase length
35 | writeCommand(0x28); // // set phase length
36 |
37 | writeCommand(0xBC); // // set precharge voltage
38 | writeCommand(0x10); // // set precharge voltage
39 |
40 | writeCommand(0xBE); // // set vcomh voltage
41 | writeCommand(0x02); // // set vcomh voltage
42 |
43 | writeCommand(0xBF); // // set vsl
44 | writeCommand(0x0D); // // set vsl
45 |
46 | writeCommand(0xA4); // // set display mode
47 |
48 | // clear screen
49 | for (i = 0; i < 80; i++) {
50 | uint8_t j;
51 | for (j = 0; j < 64; j++) {
52 | writeData(0x00);
53 | }
54 | }
55 |
56 | vcc_supply(ON);
57 |
58 | waitms(100);
59 |
60 | writeCommand(0xAF); // display on
