Hallo zusammen, ich versuche den i2c-bus zum laufen zu bringen! ich hoffe ihr könnt mir weiter helfen! ich seh das problem nicht...seh den wald vor lauter bäumen nicht...:( hier einmal der code für den master! MfG Till
[c] //------------------------------------------------------------- //TWI.h : header file for the master Two-wire Serial Interface //------------------------------------------------------------- #ifndef TWI_H #define TWI_H //------------------------------------------- // Definition of global includes //------------------------------------------- #include "MyTypeDefs.h" //------------------------------------------- // Definition of global constants //------------------------------------------- #define F_SCL 400000UL // 400 kHz for SCL //------------------------------------------- // Declaration of global functions //------------------------------------------- void TWI_init(void); u08 TWI_read (u08 TWI_adr, u08 *val, u08 count); u08 TWI_write(u08 TWI_adr, u08 *val, u08 count); #endif [\c] [c] //-------------------------------------------------------- //TWI.c : source file for the master Two-wire Serial Interface //-------------------------------------------------------- //------------------------------------------- // Definition of local includes //------------------------------------------- #include <util/twi.h> #include <util/delay.h> #include "TWI.h" //------------------------------------------- // Definition of local constants //------------------------------------------- #define TW_MT_ACK (u08)0x08 // master transfer acknowledge for address or data //------------------------------------------- // Declaration of local variables //------------------------------------------- static volatile u16 I2C_timer; //------------------------------------------- // Declaration of local functions //------------------------------------------- //------------------------------------------- // Code for functions //------------------------------------------- void delay_us(u08 delay) { while (delay--) _delay_us(1); } //-------------------------------------------------------- // Intialize the I2C-Bus Interface // as Master with SCL 100kHz, non interrupt driven //-------------------------------------------------------- void TWI_init(void) { //-------------------------------------------------------- // SCL = F_CPU/(16+2*TWBR*4^TWSR) // TWSR=0 => TWBR = F_CPU/2/F_SCL-8 //-------------------------------------------------------- TWBR = (u08)(F_CPU/2/F_SCL-7.5); TWSR = 0x00; // TWI-clock prescaler = (TWSR+1) = 1 TWCR = (1<<TWEA)|(1<<TWEN); // no interrupt mode } u08 TWI_read(u08 TWI_adr, u08 *val, u08 count) //------------------------------------------------ // Read n=count bytes from I2C-Bus in polled mode // needs about 200us for reading addr + one byte //------------------------------------------------ { u08 i=0, rc=0; TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN); // send START condition while (!(TWCR & (1<<TWINT))); // wait for response if ((TWSR & 0xF8) == TW_START) // if START was successful { TWDR = (TWI_adr | 0x01); // put slave address+READ to TWDR TWCR = (1<<TWINT)|(1<<TWEN); // and start transmission while (!(TWCR & (1<<TWINT))); // wait for response if ((TWSR & 0xF8) == TW_MR_SLA_ACK) // if acknowledge ok { while (--count>0) // while more than one byte to read { TWCR=(1<<TWINT)|(1<<TWEA)|(1<<TWEN); // then start transfer with acknowledge while (!(TWCR & (1<<TWINT))); // wait for response val[i++]=TWDR; // read databyte from TWDR } TWCR=(1<<TWINT)|(1<<TWEN); // start last byte transfer without acknowledge while (!(TWCR & (1<<TWINT))); // wait for response val[i]=TWDR; // read databyte from TWDR } else { //printl_I("Error: I2C[R] Addr"); rc = 0x10; } } else { //printl_I("Error: I2C[R] Start"); rc = 0x20; } TWCR = (1<<TWINT)|(1<<TWSTO)|(1<<TWEN); // transmit STOP condition delay_us(10); // wait until STOP is transmitted return rc; } u08 TWI_write(u08 TWI_adr, u08 *val, u08 count) //------------------------------------------------ // write n=count bytes to I2C-Bus in polled mode // needs about 200us for writing Addr + one byte //------------------------------------------------ { u08 rc=0; TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN); // send START condition while (!(TWCR & (1<<TWINT))); // wait for response if ((TWSR & 0xF8) == TW_START) // if START was successful { TWDR = (TWI_adr & 0xFE); // put slave address+WRITE to TWDR TWCR = (1<<TWINT)|(1<<TWEN); // and start transmission for (u08 i=0; i<count; i++) { while (!(TWCR & (1<<TWINT))); // wait for response if ((TWSR & 0xC8) == TW_MT_ACK) // if acknowledge ok { TWDR = val[i]; // put databyte to TWDR TWCR = (1<<TWINT)|(1<<TWEN); // and start transmission } else { //printl_I("Error: I2C[W] Data"); rc=0x10; } } } else { //printl_I("Error: I2C[W] Start"); rc=0x20; } while (!(TWCR & (1<<TWINT))); // wait for response TWCR = (1<<TWINT)|(1<<TWSTO)|(1<<TWEN); // transmit STOP condition delay_us(10); // wait until STOP is transmitted return rc; } [\c]
1 | //-------------------------------------------------------------
2 | //TWI.h : header file for the master Two-wire Serial Interface
3 | //-------------------------------------------------------------
4 | |
5 | #ifndef TWI_H
6 | #define TWI_H
7 | |
8 | //-------------------------------------------
9 | // Definition of global includes
10 | //-------------------------------------------
11 | |
12 | #include "MyTypeDefs.h" |
13 | |
14 | //-------------------------------------------
15 | // Definition of global constants
16 | //-------------------------------------------
17 | |
18 | #define F_SCL 400000UL // 400 kHz for SCL
19 | |
20 | //-------------------------------------------
21 | // Declaration of global functions
22 | //-------------------------------------------
23 | |
24 | void TWI_init(void); |
25 | |
26 | u08 TWI_read (u08 TWI_adr, u08 *val, u08 count); |
27 | u08 TWI_write(u08 TWI_adr, u08 *val, u08 count); |
28 | |
29 | #endif
2 | //TWI.c : source file for the master Two-wire Serial Interface
4 | |
5 | //-------------------------------------------
6 | // Definition of local includes
7 | //-------------------------------------------
8 | |
9 | #include <util/twi.h> |
10 | #include <util/delay.h> |
11 | #include "TWI.h" |
12 | |
13 | //-------------------------------------------
14 | // Definition of local constants
15 | //-------------------------------------------
16 | |
17 | #define TW_MT_ACK (u08)0x08 // master transfer acknowledge for address
18 | or data |
19 | |
21 | // Declaration of local variables
23 | |
24 | static volatile u16 I2C_timer; |
25 | |
26 | //-------------------------------------------
27 | // Declaration of local functions
28 | //-------------------------------------------
29 | |
30 | //-------------------------------------------
31 | // Code for functions
32 | //-------------------------------------------
33 | |
34 | void delay_us(u08 delay) |
35 | {
36 | while (delay--) _delay_us(1); |
37 | }
38 | |
39 | //--------------------------------------------------------
40 | // Intialize the I2C-Bus Interface
41 | // as Master with SCL 100kHz, non interrupt driven
42 | //--------------------------------------------------------
43 | |
44 | |
45 | void TWI_init(void) |
46 | {
47 | //--------------------------------------------------------
48 | // SCL = F_CPU/(16+2*TWBR*4^TWSR)
49 | // TWSR=0 => TWBR = F_CPU/2/F_SCL-8
50 | //--------------------------------------------------------
51 | TWBR = (u08)(F_CPU/2/F_SCL-7.5); |
52 | TWSR = 0x00; // TWI-clock prescaler = (TWSR+1) = 1 |
53 | TWCR = (1<<TWEA)|(1<<TWEN); // no interrupt mode |
54 | }
55 | |
56 | u08 TWI_read(u08 TWI_adr, u08 *val, u08 count) |
57 | //------------------------------------------------
58 | // Read n=count bytes from I2C-Bus in polled mode
59 | // needs about 200us for reading addr + one byte
60 | //------------------------------------------------
61 | {
62 | u08 i=0, rc=0; |
63 | TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN); // send START condition |
64 | while (!(TWCR & (1<<TWINT))); // wait for response |
65 | if ((TWSR & 0xF8) == TW_START) // if START was successful |
66 | {
67 | TWDR = (TWI_adr | 0x01); // put slave address+READ |
68 | to TWDR |
69 | TWCR = (1<<TWINT)|(1<<TWEN); // and start transmission |
70 | while (!(TWCR & (1<<TWINT))); // wait for response |
71 | if ((TWSR & 0xF8) == TW_MR_SLA_ACK) // if acknowledge ok |
72 | {
73 | while (--count>0) // while more than one |
74 | byte to read |
75 | {
76 | TWCR=(1<<TWINT)|(1<<TWEA)|(1<<TWEN); // then start transfer |
77 | with acknowledge |
78 | while (!(TWCR & (1<<TWINT))); // wait for response |
79 | val[i++]=TWDR; // read databyte from TWDR |
80 | }
81 | TWCR=(1<<TWINT)|(1<<TWEN); // start last byte |
82 | transfer without acknowledge |
83 | while (!(TWCR & (1<<TWINT))); // wait for response |
84 | val[i]=TWDR; // read databyte from TWDR |
85 | }
86 | else
87 | {
88 | //printl_I("Error: I2C[R] Addr");
89 | rc = 0x10; |
90 | }
91 | }
92 | else
93 | {
94 | //printl_I("Error: I2C[R] Start");
95 | rc = 0x20; |
96 | }
97 | TWCR = (1<<TWINT)|(1<<TWSTO)|(1<<TWEN); // transmit STOP |
98 | condition
99 | delay_us(10); // wait until STOP is |
100 | transmitted
101 | return rc; |
102 | }
103 | |
104 | u08 TWI_write(u08 TWI_adr, u08 *val, u08 count) |
105 | //------------------------------------------------
106 | // write n=count bytes to I2C-Bus in polled mode
107 | // needs about 200us for writing Addr + one byte
108 | //------------------------------------------------
109 | {
110 | u08 rc=0; |
111 | TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN); // send START condition |
112 | while (!(TWCR & (1<<TWINT))); // wait for response |
113 | if ((TWSR & 0xF8) == TW_START) // if START was successful |
114 | {
115 | TWDR = (TWI_adr & 0xFE); // put slave address+WRITE |
116 | to TWDR |
117 | TWCR = (1<<TWINT)|(1<<TWEN); // and start transmission |
118 | for (u08 i=0; i<count; i++) |
119 | {
120 | while (!(TWCR & (1<<TWINT))); // wait for response |
121 | if ((TWSR & 0xC8) == TW_MT_ACK) // if acknowledge ok |
122 | {
123 | TWDR = val[i]; // put databyte to TWDR |
124 | TWCR = (1<<TWINT)|(1<<TWEN); // and start transmission |
125 | }
126 | else
127 | {
128 | //printl_I("Error: I2C[W] Data");
129 | rc=0x10; |
130 | }
131 | }
132 | }
133 | else
134 | {
135 | //printl_I("Error: I2C[W] Start");
136 | rc=0x20; |
137 | }
138 | while (!(TWCR & (1<<TWINT))); // wait for response |
139 | TWCR = (1<<TWINT)|(1<<TWSTO)|(1<<TWEN); // transmit STOP condition |
140 | delay_us(10); // wait until STOP is |
141 | transmitted
142 | return rc; |
143 | }
@ADMINS Hallo Admins! Ich finde es zum kotzen: Wie wär es, wenn ihr es endlich mal auf die Reihe kriegt, dass man mehr als 80 Zeichen auf eine Zeile bringt, ohne dass automatisch Zeilenumbrüche eingefügt werden. 120 Zeichen wäre das Minimum. Oder viel besser: beliebig lang bis zum gewollten Zeilenumbruch, ansonsten dynamische Zeilenlängen (je nach Fensterbreite). Sowas ist heutzutage doch State-of-the-Art!!!
hey danke für die schnelle antwort, guck mir das mal genauer an :) aber ist mein code total für die katz ?:(
