1 | /************************************************************************/
2 | /* */
3 | /* Debouncing 8 Keys */
4 | /* Sampling 4 Times */
5 | /* With Repeat Function */
6 | /* */
7 | /* Author: Peter Dannegger */
8 | /* danni@specs.de */
9 | /* */
10 | /************************************************************************/
11 | // Target: ATMega48
12 |
13 | #include <io.h>
14 | #include <interrupt.h>
15 |
16 | typedef unsigned char u8;
17 | typedef signed short s16;
18 |
19 | #define XTAL 8000000L // 8MHz
20 |
21 | #define KEY_PIN PINB
22 | #define KEY0 0
23 | #define KEY1 1
24 | #define KEY2 2
25 | #define KEY3 3
26 |
27 | #define LED_DDR DDRC
28 | #define LED_PORT PORTC
29 | #define LED0 0
30 | #define LED1 1
31 | #define LED2 2
32 |
33 | #define REPEAT_MASK (1<<KEY3^1<<KEY2^1<<KEY1^1<<KEY0)
34 | #define REPEAT_START 10 // after 100ms
35 | #define REPEAT_NEXT 20 // every 200ms
36 |
37 | u8 key_state; // debounced and inverted key state:
38 | // bit = 1: key pressed
39 | u8 key_press; // key press detect
40 |
41 | u8 key_rpt; // key long press and repeat
42 |
43 |
44 | ISR( TIMER0_COMPA_vect ) // every 10ms
45 | {
46 | static u8 ct0, ct1, rpt;
47 | u8 i;
48 |
49 | i = key_state ^ ~KEY_PIN; // key changed ?
50 | ct0 = ~( ct0 & i ); // reset or count ct0
51 | ct1 = ct0 ^ (ct1 & i); // reset or count ct1
52 | i &= ct0 & ct1; // count until roll over ?
53 | key_state ^= i; // then toggle debounced state
54 | key_press |= key_state & i; // 0->1: key press detect
55 |
56 | if( (key_state & REPEAT_MASK) == 0 ) // check repeat function
57 | rpt = REPEAT_START; // start delay
58 | if( --rpt == 0 ){
59 | rpt = REPEAT_NEXT; // repeat delay
60 | key_rpt |= key_state & REPEAT_MASK;
61 | }
62 | }
63 |
64 |
65 |
66 | u8 get_key_press( u8 key_mask )
67 | {
68 | cli(); // read and clear atomic !
69 | key_mask &= key_press; // read key(s)
70 | key_press ^= key_mask; // clear key(s)
71 | sei();
72 | return key_mask;
73 | }
74 |
75 | u8 get_key_rpt( u8 key_mask )
76 | {
77 | cli(); // read and clear atomic !
78 | key_mask &= key_rpt; // read key(s)
79 | key_rpt ^= key_mask; // clear key(s)
80 | sei();
81 | return key_mask;
82 | }
83 |
84 | u8 get_key_short( u8 key_mask )
85 | {
86 | cli(); // read key state and key press atomic !
87 | return get_key_press( ~key_state & key_mask );
88 | }
89 |
90 | u8 get_key_long( u8 key_mask )
91 | {
92 | return get_key_press( get_key_rpt( key_mask ));
93 | }
94 |
95 | int main( void )
96 | {
97 | TCCR0A = 1<<WGM01; // Mode 2: CTC
98 | TCCR0B = 1<<CS02^1<<CS00; // divide by 1024
99 | OCR0A = (s16)(XTAL / 1024.0 * 10e-3 - 0.5); // preload for 10ms
100 | TIMSK0 = 1<<OCIE0A; // enable timer interrupt
101 |
102 | LED_PORT = 0xFF;
103 | LED_DDR = 0xFF;
104 | sei();
105 |
106 | for(;;){ // main loop
107 |
108 | switch( get_key_long( 1<<KEY1^1<<KEY0 )){
109 |
110 | case 1<<KEY0: LED_PORT ^= 1<<LED0; break;
111 |
112 | case 1<<KEY1: LED_PORT ^= 1<<LED1; break;
113 |
114 | case 1<<KEY1^1<<KEY0: LED_PORT ^= 1<<LED2; break;
115 | }
116 |
117 | switch( get_key_rpt( 1<<KEY3^1<<KEY2 )){
118 |
119 | case 1<<KEY2: LED_PORT ^= 1<<LED0; break;
120 |
121 | case 1<<KEY3: LED_PORT ^= 1<<LED1; break;
122 |
123 | case 1<<KEY3^1<<KEY2: LED_PORT ^= 1<<LED2; break;
124 | }
125 | }
126 | }
