1 | EQep1Regs.QDECCTL.bit.QSRC=00; // QEP quadrature count mode
2 | EQep1Regs.QEPCTL.bit.FREE_SOFT=2; //unaffected by emulation suspend
3 | EQep1Regs.QEPCTL.bit.PCRM=00; // PCRM=00 mode - QPOSCNT reset on
4 | ///index event
5 | EQep1Regs.QEPCTL.bit.UTE=1; // Unit Timeout Enable
6 | EQep1Regs.QEPCTL.bit.QCLM=1; // Latch on unit time out
7 | EQep1Regs.QEPCTL.bit.IEL = 1; // IEL_RISING
8 | EQep1Regs.QEPCTL.bit.IEI = 2; // IEL_RISING
9 | EQep1Regs.QPOSMAX=4*500 - 1;
10 | EQep1Regs.QEPCTL.bit.QPEN=1; // QEP enable
11 |
12 | EALLOW; // Enable EALLOW
13 | GpioCtrlRegs.GPAMUX2.bit.GPIO20 = 1; // GPIO20 is EQEP1A
14 | GpioCtrlRegs.GPAMUX2.bit.GPIO21 = 1; // GPIO21 is EQEP1B
15 | GpioCtrlRegs.GPAMUX2.bit.GPIO23 = 1; // GPIO23 is EQEP1I
16 | EDIS;
17 |
18 |
19 | In interrupt routine mit 10khz = fabtast
20 |
21 | interrupt void main_isr(void)
22 | {
23 | float Tmp1;
24 | //……………
25 | //…………….
26 | //………………
27 |
28 |
29 |
30 | if (SpeedMessungcount == SpeedMessungAbtast)
31 | // damit kann ich drehzahl_abtastfrequenz kleiner
32 | // machen , drehzahl_abtastfrequenz = fabtast/ SpeedMessungAbtast
33 | {
34 | // Check the position counter for EQEP1
35 | RawTheta = (Uint16)EQep1Regs.QPOSCNT ;// QPOSCNT 32 bit
36 |
37 | // Compute the mechanical angle
38 | MechTheta = RawTheta/(4*500);
39 |
40 | // erste verfahren, da MechTheta leigt im interval (0 - 1), dann es gibt unableitbaren Bereich
41 |
42 | if ((MechTheta < 0.95)&&(MechTheta > 0.05)) // ableitbar Bereich
43 | Tmp1 = fabtast*(MechTheta - OldMechTheta)*60;//rpm
44 | else Tmp1 = Speed;//rpm
45 |
46 |
47 |
48 |
49 | /*
50 | // zeite verfahren,
51 |
52 | if (DirectionQep == 0) // POSCNT is counting down
53 | {
54 | if (MechTheta > OldMechTheta)
55 | Tmp1 = -(1.0 - MechTheta + OldMechTheta)*fabtast;
56 | //x2-x1 should be negative
57 | else
58 | Tmp1 = (v->MechTheta - v->OldMechTheta)*v->K1;
59 | }
60 | else if (DirectionQep ==1 ) // POSCNT is counting up
61 | {
62 | if (MechTheta < OldMechTheta)
63 | Tmp1 = (1.0 + MechTheta - OldMechTheta)* fabtast;
64 | else
65 | Tmp1 = (MechTheta - OldMechTheta)* fabtast;
66 | // x2-x1 should be positive
67 | }
68 |
69 | Tmp1 *= 60; //rpm
70 |
71 | */
72 |
73 |
74 | // Low-pass filter
75 | Tmp1 = K2*Speed + K3*Tmp1; // e.g. fc = 50hz , 1. Order
76 |
77 | if (Tmp1 > BaseRpm) // BaseRpm = 3000 rpm
78 | Speed = BaseRpm;
79 | else if (Tmp1 < - BaseRpm)
80 | Speed = - BaseRpm;
81 | else
82 | Speed = Tmp1;
83 |
84 | // Update the electrical angle
85 | OldMechTheta = MechTheta;
86 |
87 | SpeedMessungcount = 1;
88 | }
89 | else SpeedMessungcount++;
90 | }
