Hallo erstmal ich hätte eine rissen bitte da ich mich mit c Null auskenne könnte mir jemand diesen Code erklären oder eventuell ins bascom übersetzen ? /*********************************************************************** ************************************* SPI Interface code for Playstation (Ps1 or Ps2) game controllers. version: 1.4 date: April 4, 2009 compiler: gcc-avr compiler AVR: ATmega168 clock source: 16 MHz external crystal The Playstation Controller Pinouts (http://www.gamesx.com/controldata/psxcont/psxcont.htm) LOOKING AT THE PLUG (male connector) ------------------------------- PIN 1->| o o o | o o o | o o o | \_____________________________/ PIN # USAGE 1. DATA 2. COMMAND 3. N/C (9 Volts unused) 4. GND 5. VCC 6. ATT 7. CLOCK 8. N/C 9. ACK *Note: All Playstation controllers are abbreviated as DSC (Dualshock Controller) in the code below. ************************************************************************ *************************************/ #include <avr/io.h> #define F_CPU 16000000UL #include <util/delay.h> #include <avr/interrupt.h> #include <inttypes.h> #define BAUDRATE 57600 // Define baudrate for RS232 communication #define STATUS_LED_RED PC2 // Red LED cathode on PC2; indicates no controller or communication error #define STATUS_LED_GREEN PC4 // Green LED cathode on PC4; indicates proper communication with DSC #define COMMAND PB3 // SPI MOSI; sends commands from AVR to DSC #define DATA PB4 // SPI MISO; receives incoming data from DSC; 1k external pull-up required #define CLOCK PB5 // SPI SCK; serial clock controlled by AVR, DATA is read on rising edge #define ATTENTION PC1 // Initiates and closes each data packet transmission #define MODE_SELECT PC0 // MODE_SELECT pin state defines DSC mode; low = full analog (Ps2 only), high = default #define SS PB2 // SPI slave select pin; set as output to ensure AVR remains SPI master #define MODE_SELECT_PORT PORTC #define MODE_SELECT_PORT_IN PINC #define LED_PORT PORTC #define ATTENTION_PORT PORTC /* Global Variables */ uint8_t received_byte, analog_flag, data[18]; /* init() sets all registers and enables necessary interrupts */ void init(void){ /*Set pin I/O registers*/ // Set output on SCK (CLOCK) and MOSI (COMMAND) pins for spi communication DDRB |= _BV(SS) | _BV(COMMAND) | _BV(CLOCK); // Set output mode for all status LEDs and ATTENTION pin DDRC |= _BV(STATUS_LED_RED) | _BV(STATUS_LED_GREEN) | _BV(ATTENTION); // Enable internal pull-up resistor on mode select pin MODE_SELECT_PORT |= _BV(MODE_SELECT); /* Configure SPI registers (pg.173) */ // SPE enables SPI hardware; DORD sets data order to LSB first; MSTR selects master mode; CPOL sets clock polarity (high when idle) // CPHA selects data setup on falling edge of clock, read on rising edge; SPR1 sets clock prescale factor at 64 (250kHz clock) SPCR |= _BV(SPE) | _BV(DORD) | _BV(MSTR) | _BV(CPOL) | _BV(CPHA) | _BV(SPR1); /* Configure USART registers */ // Equations for calculating and setting UBRR0L (baudrate register) (pg. 179) if((F_CPU 16 BAUDRATE - 1) < 20){ UCSR0A |= _BV(U2X0); UBRR0L = F_CPU 8 BAUDRATE - 1;} else{ UBRR0L = F_CPU 16 BAUDRATE - 1;} // USART control/status register B (pg. 196); RXCIE0 enables RX complete interrupt; TXEN0/RXEN0 enable receiver/ transmitter UCSR0B |= _BV(RXCIE0) | _BV(TXEN0) | _BV(RXEN0); // USART control and status register C (pg. 197); UCSZ01 and UCSZ00 sets character size to 8 bits; UCSR0C = _BV(UCSZ01) | _BV(UCSZ00); /* Enable global interrupts*/ sei(); /* Clear status flags. */ uint8_t x; x = SPSR; x = SPDR; } /* Core AVR-DSC send/receive communication function; takes command_byte, returns single data byte from controller. */ uint8_t ps2_comm(uint8_t command_byte){ SPDR = command_byte; // Write command byte to SPI data register to begin transmission (pg. 175) while(!(SPSR & _BV(SPIF))); // Loop to prevent write collision _delay_us(20); // Delay between byte transmissions return(SPDR); // Return byte from controller in shift register receive buffer (pg. 175) } /* Function to simplify configuration of DSC; requires 4 command bytes, loop_bytes sets number of bytes following the default 6 */ void config_comm(uint8_t byte2, uint8_t byte4, uint8_t byte5, uint8_t byte6, uint8_t loop_bytes){ ATTENTION_PORT &= ~_BV(ATTENTION); _delay_us(16); ps2_comm(0x01); analog_flag = ps2_comm(byte2); ps2_comm(0x00); ps2_comm(byte4); ps2_comm(byte5); ps2_comm(byte6); for(uint8_t x = 0; x < loop_bytes; x++) ps2_comm(0x00); _delay_us(16); ATTENTION_PORT |= _BV(ATTENTION); _delay_ms(16); } /* USART RS232 transmit single byte function */ void avr_transmit_byte (uint8_t data) { while (!(UCSR0A & _BV(UDRE0))); // Wait for USART data register empty flag (pg. 195) UDR0 = data; // Write byte to USART I/O data register to initiate transmission (p. 195) } /*Interrupt routines*/ // USART receive completion interrupt service routine ISR(SIG_USART_RECV){ received_byte = UDR0; // Store byte received from serial port if(received_byte == 0x7A){ // If byte received is 0x7A ("z" in ASCII) for(uint8_t x = 0; x < ((analog_flag & 0x0F) << 1); x++) // Loop transmits mode specific byte count from data array avr_transmit_byte(data[x]); received_byte = 0; } } int main(void){ init(); /* Infinite while loop*/ while(1){ LED_PORT |= _BV(STATUS_LED_GREEN); // Green status LED off LED_PORT &= ~_BV(STATUS_LED_RED); // Red status LED on (no controller/communication error) analog_flag = 0x00; // Variable to verify controller communication/mode status /* DSC initialization/configuration loop; protocol and command details from http://www.curiousinventor.com/guides/ps2 */ while((analog_flag != 0x79) && (analog_flag != 0x73) && (analog_flag != 0x41)){ config_comm(0x43, 0x01, 0x00, 0x00, 0x00); // Put controller in config mode config_comm(0x44, 0x01, 0x03, 0x00, 0x03); // Set up for analog mode if(~MODE_SELECT_PORT_IN & _BV(MODE_SELECT)) // Check for mode selection config_comm(0x4F, 0xFF, 0xFF, 0x03, 0x03); // Configures full analog mode (if supported) config_comm(0x43, 0x00, 0x5A, 0x00, 0x03); // Exit config mode config_comm(0x42, 0x00, 0x00, 0x00, 0x0F); // Poll once with standard header } LED_PORT &= ~_BV(STATUS_LED_GREEN); // Green status LED on (controller connected and configured) LED_PORT |= _BV(STATUS_LED_RED); // Red status LED off /* Auto-configured polling loop for all three controller modes */ while((((analog_flag == 0x41) || (analog_flag == 0x73)) && (MODE_SELECT_PORT_IN & _BV(MODE_SELECT))) || ((analog_flag == 0x79) && (~MODE_SELECT_PORT_IN & _BV(MODE_SELECT)))){ ATTENTION_PORT &= ~_BV(ATTENTION); // Begin communication with DSC _delay_us(16); // Delay between ATTENTION dropping low and data transmission ps2_comm(0x01); // byte 0; standard header analog_flag = ps2_comm(0x42); // byte 1; standard header ps2_comm(0x00); // byte 2; standard header for(uint8_t x = 0; x < ((analog_flag & 0x0F) << 1); x++) // Loop loads data array with mode specific byte count data[x] = ps2_comm(0x00); _delay_us(16); // Delay following data transmission before ATTENTION returns high ATTENTION_PORT |= _BV(ATTENTION); // End communication with DSC _delay_ms(16); //Delay for roughly 60 samples per second } _delay_ms(16); } }
