1 | #include "T6963C.h"
2 | //-------------------------------------------------------------------------------------------------
3 | //
4 | // Delay function
5 | //
6 | //-------------------------------------------------------------------------------------------------
7 | void delay(void)
8 | {
9 | volatile unsigned char i;
10 | for(i = 0; i < (16000000/1000000); i++)
11 | {
12 | asm("nop");
13 | }
14 | }
15 | //-------------------------------------------------------------------------------------------------
16 | //
17 | // Ports intalization
18 | //
19 | //-------------------------------------------------------------------------------------------------
20 | void GLCD_InitalizeInterface(void)
21 | {
22 | GLCD_DATA_DDR = 0xFF;
23 | GLCD_CTRL_DDR = ((1 << GLCD_WR) | (1 << GLCD_RD) | (1 << GLCD_CE) | (1 << GLCD_CD) | (1 << GLCD_RESET) | (1 << GLCD_FS));
24 | GLCD_CTRL_PORT |= ((1 << GLCD_WR) | (1 << GLCD_RD) | (1 << GLCD_CE) | (1 << GLCD_CD) | (1 << GLCD_RESET) | (1 << GLCD_FS));
25 | }
26 | //-------------------------------------------------------------------------------------------------
27 | //
28 | // Reads dispay status
29 | //
30 | //-------------------------------------------------------------------------------------------------
31 | unsigned char GLCD_ChceckStatus(void)
32 | {
33 | uint8_t tmp;
34 | GLCD_DATA_DDR = 0x00;
35 |
36 | GLCD_CTRL_PORT &= ~((1 << GLCD_RD) | (1 << GLCD_CE));
37 | delay();
38 | tmp = GLCD_DATA_PIN;
39 | GLCD_DATA_DDR = 0xFF;
40 | GLCD_CTRL_PORT |= ((1 << GLCD_RD) | (1 << GLCD_CE));
41 | return tmp;
42 | }
43 | //-------------------------------------------------------------------------------------------------
44 | //
45 | // Writes instruction
46 | //
47 | //-------------------------------------------------------------------------------------------------
48 | void GLCD_WriteCommand(unsigned char command)
49 | {
50 | while(!(GLCD_ChceckStatus()&0x03));
51 | GLCD_DATA_PORT = command;
52 |
53 | GLCD_CTRL_PORT &= ~((1 << GLCD_WR) | (1 << GLCD_CE));
54 | delay();
55 | GLCD_CTRL_PORT |= ((1 << GLCD_WR) | (1 << GLCD_CE));
56 | }
57 |
58 | //-------------------------------------------------------------------------------------------------
59 | //
60 | // Writes data
61 | //
62 | //-------------------------------------------------------------------------------------------------
63 | void GLCD_WriteData(unsigned char data)
64 | {
65 | while(!(GLCD_ChceckStatus()&0x03));
66 | GLCD_DATA_PORT = data;
67 |
68 | GLCD_CTRL_PORT &= ~((1 << GLCD_WR) | (1 << GLCD_CE) | (1 << GLCD_CD));
69 | delay();
70 | GLCD_CTRL_PORT |= ((1 << GLCD_WR) | (1 << GLCD_CE) | (1 << GLCD_CD));
71 | }
72 | //-------------------------------------------------------------------------------------------------
73 | //
74 | // Reads data
75 | //
76 | //-------------------------------------------------------------------------------------------------
77 | unsigned char GLCD_ReadData(void)
78 | {
79 | uint8_t tmp;
80 | while(!(GLCD_ChceckStatus()&0x03));
81 | GLCD_DATA_DDR = 0x00;
82 |
83 | GLCD_CTRL_PORT &= ~((1 << GLCD_RD) | (1 << GLCD_CE) | (1 << GLCD_CD));
84 | delay();
85 | tmp = GLCD_DATA_PIN;
86 | GLCD_CTRL_PORT |= ((1 << GLCD_RD) | (1 << GLCD_CE) | (1 << GLCD_CD));
87 | GLCD_DATA_DDR = 0xFF;
88 | return tmp;
89 | }
90 | //-------------------------------------------------------------------------------------------------
91 | //
92 | // Sets address pointer for display RAM memory
93 | //
94 | //-------------------------------------------------------------------------------------------------
95 | void GLCD_SetAddressPointer(unsigned int address)
96 | {
97 | GLCD_WriteData(address & 0xFF);
98 | GLCD_WriteData(address >> 8);
99 | GLCD_WriteCommand(T6963_SET_ADDRESS_POINTER);
100 | }
101 | //-------------------------------------------------------------------------------------------------
102 | //
103 | // Clears text area of display RAM memory
104 | //
105 | //-------------------------------------------------------------------------------------------------
106 | void GLCD_ClearText(void)
107 | {
108 | int i;
109 | GLCD_SetAddressPointer(GLCD_TEXT_HOME);
110 |
111 | for(i = 0; i < GLCD_TEXT_SIZE; i++)
112 | {
113 | GLCD_WriteDisplayData(0);
114 | }
115 | }
116 | //-------------------------------------------------------------------------------------------------
117 | //
118 | // Clears characters generator area of display RAM memory
119 | //
120 | //-------------------------------------------------------------------------------------------------
121 | void GLCD_ClearCG(void)
122 | {
123 | unsigned int i;
124 | GLCD_SetAddressPointer(GLCD_EXTERNAL_CG_HOME);
125 |
126 | for(i = 0; i < 256 * 8; i++)
127 | {
128 | GLCD_WriteDisplayData(0);
129 | }
130 | }
131 | //-------------------------------------------------------------------------------------------------
132 | //
133 | // Clears graphics area of display RAM memory
134 | //
135 | //-------------------------------------------------------------------------------------------------
136 | void GLCD_ClearGraphic(void)
137 | {
138 | int i;
139 | GLCD_SetAddressPointer(GLCD_GRAPHIC_HOME);
140 | for(i = 0; i < GLCD_GRAPHIC_SIZE; i++)
141 | {
142 | GLCD_WriteDisplayData(0x00);
143 | }
144 | }
145 | //-------------------------------------------------------------------------------------------------
146 | //
147 | // Writes a single character (ASCII code) to display RAM memory
148 | //
149 | //-------------------------------------------------------------------------------------------------
150 | void GLCD_WriteChar(char charCode)
151 | {
152 | GLCD_WriteDisplayData(charCode - 32);
153 | }
154 | //-------------------------------------------------------------------------------------------------
155 | //
156 | // Writes null-terminated string to display RAM memory
157 | //
158 | //-------------------------------------------------------------------------------------------------
159 | void GLCD_WriteString(char * string)
160 | {
161 | while(*string)
162 | {
163 | GLCD_WriteChar(*string++);
164 | }
165 | }
166 | //-------------------------------------------------------------------------------------------------
167 | //
168 | // Writes null-terminated string from program memory to display RAM memory
169 | //
170 | //-------------------------------------------------------------------------------------------------
171 | void GLCD_WriteStringPgm(prog_char * string)
172 | {
173 | char ch;
174 | while((ch = pgm_read_byte(string++)))
175 | {
176 | GLCD_WriteChar(ch);
177 | }
178 | }
179 | //-------------------------------------------------------------------------------------------------
180 | //
181 | // Sets display coordinates
182 | //
183 | //-------------------------------------------------------------------------------------------------
184 | void GLCD_TextGoTo(unsigned char x, unsigned char y)
185 | {
186 | unsigned int address;
187 |
188 | address = GLCD_TEXT_HOME + x + (GLCD_TEXT_AREA * y);
189 |
190 | GLCD_SetAddressPointer(address);
191 | }
192 | //-------------------------------------------------------------------------------------------------
193 | //
194 | // Writes single char pattern to character generator area of display RAM memory
195 | //
196 | //-------------------------------------------------------------------------------------------------
197 | void GLCD_DefineCharacter(unsigned char charCode, unsigned char * defChar)
198 | {
199 | unsigned int address;
200 | unsigned char i;
201 |
202 | address = GLCD_EXTERNAL_CG_HOME + (8 * charCode);
203 |
204 | GLCD_SetAddressPointer(address);
205 |
206 | for(i = 0; i < 8 ; i++)
207 | {
208 | GLCD_WriteDisplayData(*(defChar + i));
209 | }
210 | }
211 |
212 | //-------------------------------------------------------------------------------------------------
213 | //
214 | // Set (if color==1) or clear (if color==0) pixel on screen
215 | //
216 | //-------------------------------------------------------------------------------------------------
217 | void GLCD_SetPixel(unsigned char x, unsigned char y, unsigned char color)
218 | {
219 | unsigned char tmp;
220 | unsigned int address;
221 |
222 | address = GLCD_GRAPHIC_HOME + (x / GLCD_FONT_WIDTH) + (GLCD_GRAPHIC_AREA * y);
223 |
224 | GLCD_SetAddressPointer(address);
225 |
226 | GLCD_WriteCommand(T6963_DATA_READ_AND_NONVARIABLE);
227 | tmp = GLCD_ReadData();
228 |
229 | if(color)
230 | tmp |= (1 << (GLCD_FONT_WIDTH - 1 - (x % GLCD_FONT_WIDTH)));
231 | else
232 | tmp &= ~(1 << (GLCD_FONT_WIDTH - 1 - (x % GLCD_FONT_WIDTH)));
233 |
234 | GLCD_WriteDisplayData(tmp);
235 |
236 | }
237 | //-------------------------------------------------------------------------------------------------
238 | //
239 | // Writes display data and increment address pointer
240 | //
241 | //-------------------------------------------------------------------------------------------------
242 | void GLCD_WriteDisplayData(unsigned char x)
243 | {
244 | GLCD_WriteData(x);
245 | GLCD_WriteCommand(T6963_DATA_WRITE_AND_INCREMENT);
246 | }
247 | //-------------------------------------------------------------------------------------------------
248 | //
249 | // Sets graphics coordinates
250 | //
251 | //-------------------------------------------------------------------------------------------------
252 | void GLCD_GraphicGoTo(unsigned char x, unsigned char y)
253 | {
254 | unsigned int address;
255 | address = GLCD_GRAPHIC_HOME + (x / GLCD_FONT_WIDTH) + (GLCD_GRAPHIC_AREA * y);
256 | GLCD_SetAddressPointer(address);
257 | }
258 | //-------------------------------------------------------------------------------------------------
259 | //
260 | // Displays bitmap from program memory
261 | //
262 | //-------------------------------------------------------------------------------------------------
263 | void GLCD_Bitmap(unsigned char * bitmap, unsigned char x, unsigned char y, unsigned char width, unsigned char height)
264 | {
265 | unsigned char i, j;
266 |
267 | for(j = 0; j < height; j++)
268 | {
269 | GLCD_GraphicGoTo(x, y + j);
270 | for(i = 0; i < width/GLCD_FONT_WIDTH; i++)
271 | {
272 | GLCD_WriteDisplayData(pgm_read_byte(bitmap + i + (GLCD_GRAPHIC_AREA * j)));
273 | }
274 | }
275 | }
276 | //-------------------------------------------------------------------------------------------------
277 | //
278 | // Display initalization
279 | //
280 | //-------------------------------------------------------------------------------------------------
281 | void GLCD_Initalize(void)
282 | {
283 | GLCD_InitalizeInterface();
284 |
285 | GLCD_CTRL_PORT &= ~(1 << GLCD_RESET);
286 | _delay_ms(1);
287 | GLCD_CTRL_PORT |= (1 << GLCD_RESET);
288 |
289 | #if (GLCD_FONT_WIDTH == 8)
290 | GLCD_CTRL_PORT &= ~(1 << GLCD_FS);
291 | #endif
292 |
293 | GLCD_WriteData(GLCD_GRAPHIC_HOME & 0xFF);
294 | GLCD_WriteData(GLCD_GRAPHIC_HOME >> 8);
295 | GLCD_WriteCommand(T6963_SET_GRAPHIC_HOME_ADDRESS);
296 |
297 | GLCD_WriteData(GLCD_GRAPHIC_AREA);
298 | GLCD_WriteData(0x00);
299 | GLCD_WriteCommand(T6963_SET_GRAPHIC_AREA);
300 |
301 | GLCD_WriteData(GLCD_TEXT_HOME);
302 | GLCD_WriteData(GLCD_TEXT_HOME >> 8);
303 | GLCD_WriteCommand(T6963_SET_TEXT_HOME_ADDRESS);
304 |
305 | GLCD_WriteData(GLCD_TEXT_AREA);
306 | GLCD_WriteData(0x00);
307 | GLCD_WriteCommand(T6963_SET_TEXT_AREA);
308 |
309 | GLCD_WriteData(GLCD_OFFSET_REGISTER);
310 | GLCD_WriteData(0x00);
311 | GLCD_WriteCommand(T6963_SET_OFFSET_REGISTER);
312 |
313 | GLCD_WriteCommand(T6963_DISPLAY_MODE | T6963_GRAPHIC_DISPLAY_ON | T6963_TEXT_DISPLAY_ON /*| T6963_CURSOR_DISPLAY_ON*/);
314 |
315 | GLCD_WriteCommand(T6963_MODE_SET | 0);
316 |
317 | }
