english question^^
Martin schrieb:
> I was not asking what CEO means. I was asking about the meaning of the
> sentence. Do you think that I am too stupid to find CEO?
Well... At least it becomes apparent that you never heard of
webtranslators like Babelfish. Because its translation is basically
correct - this time.
Sorry if the last posts, including mine, were a bit rude. What is your
native language, maybe someone on this forum may be able to translate it
for you.
"Has joined" ist present perfect, so he is still joining, but this is
only the interpretation of a German with English skills on the level of
"international broken English".
@prx
Der Google-Suche nach "present perfect" folgend kann jenes beides, also
Handlung der Vergangenheit fortgesetzt in der Gegenwart und gerade
abgeschlossene Handlung, bedeuten. Somit enthaelt der Satz nicht
genuegend Information um die Frage des OP zu beantworten. Mit dieser
Erkenntnis gehe ich jetzt schlafen :-)
Martin schrieb:
> Does it mean the process of joining became complete recently, so that he
> is now completely joining?
The word "joining" implies it is has started but is not yet complete. So
you can be joining (it's still running) or you can have joined (just
completed).
> Or is the joining complete, meaning finished
> now, so that he is no longer joining?
Yes with regard to grammar.
But usually there is no gradual process of joining in such a case.
Before day X you are not yet CEO and starting with day X you are CEO.
That's part of my irritation regarding your question. I'd simply say he
just recently joined the company as CEO.
Sorry about being a bit rough earlier, but it did not occur to me that
your problem was about grammar not words. Also it usually helps to give
a bit more context, especially when asking in the english branch of a
german forum as native french speaker while having a german name.
Martin schrieb:
> Can somebody please translate what Rik has written?
Basically he says that according to his search on Google, the present
perfect form does not state precisely whether the process has been
completed or is still running. So there is not enough information to
answer your question. And that he is going to sleep.
Has joined - gerade erst kürzlich passiert aber abgeschlossene
Handlung (aus dem Kontext herausgelesen, da to join nicht wirklich Sinn
macht als andauernde Handlung)
Has been joining - Andauernde Handlung, nicht abgeschlossen. Man möchte
einfach den Vorgang an sich betonen. Macht m.E. mit join nicht wirklich
Sinn.
joined - Wenn die Handlung schon zuende ist. Z.B. He joined the company
last month.
Has lived ist zB nicht abgeschlossen. Jedoch has joined ist
abgeschlossen. Es kommt immer auf den Kontext drauf an.
"Sinn machen" wird schon seit Jahren allgemein in der Deutschen sprache
gebraucht und akzeptiert. "Sinn ergibt" ist schoen wenn du das lieber
verwendest aber ich mache lieber Sinn. Sprache hamm sich schon immer
gewandelt und werden es immer tun. Ist auch OK so... Aber das ist hier
OT.
ihr seit nah dran :)
so..kleiner englisch unterricht
The Present Perfect Simple.
have/has + 3rd form
e.g. has joined
Die Present Perfect Tense beschreibt handlungen die - meist kurz - vor
dem Jetzt passiert sind, aber Auswirkungen und Folgen auf die Gegewart
haben.
(er ist als CEO eingetreten --> er ist jetzt CEO)
The Pressent Perfect Progressive.
have/has been +    ing-form
e.g. has been  working as CEO
wird verwendet für Handlungen die erst vor kurzem zu ende gingen.
oder wenn die Handlung noch andauert und mann die Zeitdauer betonen
möchte
e.g. He has been working since seven in the morning.
... gebraucht und akzeptiert ...
Das ist ein Scheinargument, weil die Aussage auch dann richtig ist, wenn
es nur wenige sind, die ""Sinn machen" verwenden. Eine Mehrheit
verwendet es mit Sicherheit nicht.
