Beispiel von Hitex lässt sich nicht linken
Gast #1325164
Guten Tag,
ich will das UART Beispiel von Hitex compelieren.
Und bekomme folgende Fehlermeldung:
test.sct(7): error: L6236E: No section matches selector - no section to
be FIRST/LAST.
Was hat diese zu bedeuten bzw. wie kann ich das Problem beheben?
Ich kann doch das ganze in Simulator laufen lassen?
Vielen Dank im Voraus.
; *** Scatter-Loading Description File generated by uVision ***
LR_IROM1 0x00000000         {    ; load region
  ER_IROM1 0x00000000 0x00020000  {  ; load address = execution address
   *.o (RESET, +First)
   *(InRoot$$Sections)
   .ANY (+RO)
  RW_IRAM1 0x40000000 0x00004000  {  ; RW data
   .ANY (+RW +ZI)
/* PROJECT NAME: UART                                      */
/* Project:      LPC2100 Training course                    */
/* Engineer:     T Martin      tmartin@hitex.co.uk          */
/* Filename:     main.c                                     */
/* Language:     C                                        */
/* Compiler:     Keil ARM  V2.00b                        */
/* Assembler:                                        */
/* COPYRIGHT: Hitex UK Ltd     2005            */
/* LICENSE:   THIS VERSION CREATED FOR FREE DISTRIBUTION  */
/* Function:                                                */
/* Example                                 */
/*       Demonstrates RS232 Comms            */
/* Oscillator frequency 12.000 Mhz              */
/* Target board Keil MCB2100                */
24
25
#define CR     0x0D
26
#include <LPC21xx.H>
27
28
void init_serial (void);
29
int putchar (int ch);
30
int getchar (void);
31
32
33
unsigned char test;
34
35
int main(void)
36
37
VPBDIV = 0x02;            //Divide Pclk by two
38
init_serial();
39
40
while(1)
41
42
43
putchar(getchar());          //Echo terminal
44
45
46
47
void init_serial (void)          /* Initialize Serial Interface       */
48
49
  PINSEL0   = 0x00050000;           /* Enable RxD1 and TxD1              */
50
  U1LCR   = 0x81;               /* 8 bits, no Parity, 1 Stop bit     */
51
  U1DLL   = 0x81;               /* 9600 Baud Rate @ 30MHz VPB Clock  */
52
  U1LCR   = 0x81;                /* DLAB = 0                          */
53
54
55
56
int putchar (int ch)         /* Write character to Serial Port    */
57
58
59
  if (ch == '\n')  {
60
    while (!(U1LSR & 0x20));
61
    U1THR = CR;                   /* output CR */
62
63
64
  return (U1THR = ch);
65
66
67
68
int getchar (void)         /* Read character from Serial Port   */
69
70
71
  while (!(U1LSR & 0x01));
72
73
  return (U1RBR);
74
