Forum: FPGA, VHDL & Co. A > B, Bits werden weg synthestisiert
Autor: B. U. (peggy)
im wesentlichen habe ich den Code:
library ieee;
use ieee.STD_LOGIC_1164.all;
library ieee;
use ieee.NUMERIC_STD.all;
library AppPackages;
use AppPackages.AppPackage.all;
entity  Testdetimm  is
port (TimeReq : in std_logic_vector (17 downto 0);
      TimeVal : in std_logic_vector (17 downto 0);
      clk : in std_logic ;
      clrn : in std_logic ;
      CompTimeNow : out std_logic ;
      TimeTooShort : out std_logic ;
      NewPat : in std_logic
end Testdetimm;
architecture  a  of  Testdetimm  is
    signal TimeReqM : unsigned(17 downto 0 );
    signal TimeValM : unsigned(17 downto 0 );
    signal detimm : unsigned(17 downto 0 );
    signal detimm2 : unsigned(17 downto 0 );
    signal SubTime : unsigned(17 downto 0 );
    signal TimeReqMS : unsigned(17 downto 0 );
    signal SubReq : unsigned(17 downto 0 );
    signal NewPatS : std_logic;
begin
    process (clk, clrn)
    begin
        if clrn = '0' then
            TimeReqM <= (others =>'0');
            TimeValM <= (others =>'0');
            detimm  <= (others =>'0');
            detimm2  <= (others =>'0');
            SubTime <= (others =>'0');
            CompTimeNow <= '0';
            NewPatS <='0';
            TimeTooShort  <= '0';
        elsif clk'event and clk = '1' then
            detimm <= to_unsigned(ct20us,18);
            detimm2 <= detimm (16 downto 0) & '0';
            TimeReqM <= unsigned(TimeReq);
            TimeValM <= unsigned(TimeVal);
            SubTime <= TimeReqM - TimeValM;
            SubReq <= TimeReqM - TimeReqMS;
            if ( (NewPatS ='0') AND (NewPat ='1')) then
                if (SubReq < (detimm2 + "111")) then
                    TimeTooShort  <= '1';
                else
                end if;
            end if;
            if (detimm2 < SubTime) AND (detimm > SubTime ) then
                CompTimeNow <= '1';
            else
                CompTimeNow <= '0';
            end if;
            NewPatS <= NewPat;
            TimeReqMS <= TimeReqM;
         end if;
    end process;
end;
cT20us ist eine Konstante aus AppPackage mit folgender Definition:
constant cT1us       : integer range 0 to  2047 :=  30;
constant cT20us      : integer range 0 to  2047 :=  20 * cT1us;
Mein Problem ist nun wie folgt:
Wenn ich alles generiere (mit Visual Elite)
"detimm[2]" "detimm[1]"  "detimm[0]" "detimm2[3]"  "detimm2[2]"
"detimm2[1]" "detimm2[0]"  einfach weg synthetisiert.
Simuliere ich dann mit Quartus 6.1 kommt folgendes (siehe Bild)
Warum? Ist an den Casts was falsch? Kann ich eine if-Abfrage mit
unsigned überhaupt machen?
Bin ratlos...
Vielleicht ist der Fehler sehr einfach und ich sehe ihn nicht... Wo sind
meine Bits hin?
Wer kann mir helfen? Falsche Lib? Besser Unsigned?
Vlg
Autor: Jan M. (mueschel)
Diese Bits werden einach nicht benoetigt - detimm hat einen festen Wert.
Um zu sehen, ob SubTime kleiner ist als dieser Wert, wird Bit 0 nicht
gebraucht, deswegen entfernt es die Synthese.
Ah, ok ich verstehe, genauso ist es auch z. B. detimm2[9], egal was da
in SubTim[9] steht, entscheidend ist SubTim[10].
Vielen Dank!!!
Genau. Sobald die Bits irgendwie gebraucht werden, wird die Synthese sie
auch nicht mehr entfernen.
  • [vhdl]VHDL-Code[/vhdl]
