Eval AD7760/62EDZ an FX2
OP (Firma: home) #1346368
Hallo zusammen...
mein erster Beitrag und dann gleich so eine Frage:
also ich habe hier 2 Eval-Boards:
ein Cypress FX2 Development Board CY3681 PDC-9018 REV C
(http://www.cypress.com/?rID=14319)
und ein Analog Devices EVAL-AD7760/62EDZ
(http://www.analog.com/en/analog-to-digital-converters/ad-converters/ad7760/products/product.html)
Ich habe mir das FX2 GPIF Tool Utility-Beispiel von Cypress genommen (zu
finden in: C:\Cypress\USB\Application Reference Materials\Support
Information\High Speed Devices\CY7C68013 FX2\Examples) und es ein wenig
abgewandelt:
in gfpitool.c
void TD_Init( void )
{ // Called once at startup
  // 16-bit bus (WORDWIDE=1)...
  SYNCDELAY;                    //
  EP2FIFOCFG = 0x01;
  SYNCDELAY;                    //
  EP6FIFOCFG = 0x05;
void TD_Poll( void )
{ // Called repeatedly while the device is idle
  BYTE dummy = 0;
  // Handle OUT data...
  // is the host sending data...
  if( !( EP2468STAT & 0x01 ) )
    // EP2EF=0, when endp buffer "not" empty
24
25
    // ...at this point the pkt. switched from the usb domain to the cpu domain
26
27
    // if the host sent a pkt... then a buffer was available
28
    // AUTOOUT=0, so pass pkt. to peripheral domain - (GPIF)
29
    SYNCDELAY;          //
30
    EP2BCL = 0x00;            // w/skip=0
31
32
33
  else
34
35
    // host is "not" sending data...
36
37
38
  if ( write_mode == TRUE )
39
40
  // is the peripheral interface idle...
41
  if( GPIFTRIG & 0x80 )
42
43
    // DONE=1, when GPIF is "idle"
44
45
    // check if there's a pkt in the peripheral domain...
46
    if( EP24FIFOFLGS & 0x02 )
47
48
      // ...EF=1 when buffer "empty", no more data to xfr.
49
50
    else
51
52
      // EF=0, when slave fifo is "not empty"
53
      // ...the cpu passed the pkt. to the peripheral domain
54
55
      // check if peripheral "not full"...
56
//      if( GPIFREADYSTAT & 0x02 )
57
58
        // RDY1=1, when peripheral is "not" FULL (tied to peripheral "full" flag)
59
60
//        xFIFOTC_OUT = ( ( EP2FIFOBCH << 8 ) + EP2FIFOBCL );
61
62
        // setup GPIF transaction count
63
        SYNCDELAY;            //
64
        EP2GPIFTCH = EP2FIFOBCH;
65
        SYNCDELAY;
66
        EP2GPIFTCL = EP2FIFOBCL;
67
68
        // trigger FIFO write transaction(s), using SFR
69
        // R/W=0, EP[1:0]=00 for EP2 write(s)
70
        SYNCDELAY;
71
        GPIFTRIG = GPIFTRIGWR | GPIF_EP2;
72
73
        // NOTE: 512 bytes transfers in ~75usec on 8-bit async bus
74
        // ...once master (GPIF) drains OUT pkt, it (re)arms to usb domain
75
76
        if( xFIFOTC_OUT < enum_pkt_size )
77
78
          // handle short pkt. to peripheral
79
80
          // wait for the transaction to terminate naturally...
81
          while( !( GPIFTRIG & 0x80 ) )
82
83
              // should take <75usec @ 8-bit async.
84
            ; // poll GPIFTRIG.7, DONE bit...
85
86
87
          // signal "shortpkt" to peripheral peripheral here...
88
89
        else
90
91
          // was max. pkt. size...
92
          // ...let transaction terminate naturally...
93
94
95
96
//      else
97
98
        // RDY1=0, when peripheral is FULL
99
100
101
102
  else
103
104
    // DONE=0 when GPIF is "not" IDLE...
105
106
  } else {
107
108
if ( EP68FIFOFLGS & 0x01 )
109
110
  dummy = LED2_ON;
111
} else {
112
  dummy = LED2_OFF;
113
114
if (( GPIFREADYSTAT & 0x01 ))
115
116
  dummy = LED0_ON;
117
} else {
118
  dummy = LED0_OFF;
119
120
if (!( GPIFREADYSTAT & 0x01 ))
121
122
  if ( !( GPIFTRIG & 0x80 ) )
123
124
    dummy = LED1_ON;
125
126
} else {
127
  dummy = LED1_OFF;
128
129
130
// Handle IN data...
131
132
133
134
135
136
    // check if peripheral "not empty"...
137
    if ( !( GPIFREADYSTAT & 0x01 ) )
138
139
      // RDY0=1, when peripheral "not" empty...
140
141
      if( EP68FIFOFLGS & 0x01 )
142
143
        // EP6FF=1, when fifo "full"
144
145
      else
146
147
        // EP6FF=0, when fifo "not full", buffer available...
148
149
150
        SYNCDELAY;          //
151
        EP6GPIFTCH = 0x00;
152
        SYNCDELAY;
153
        EP6GPIFTCL = 0x04;
154
155
        // trigger FIFO read transaction(s), using SFR
156
        // R/W=1, EP[1:0]=FIFO_EpNum for EPx read(s)
157
        SYNCDELAY;
158
        GPIFTRIG = GPIFTRIGRD | GPIF_EP6;
159
160
161
        // NOTE: 64 bytes transfers in ~10usec on 8-bit async bus
162
163
164
        SYNCDELAY;                //
165
166
167
168
169
170
171
172
       // AUTOIN=0, so 8051 pass pkt. to host...
173
        SYNCDELAY;              //
174
        INPKTEND = 0x06;        // ...commit however many bytes in pkt.
175
                                // ...NOTE: this also handles "shortpkt"
176
177
/*    count++;
178
      XGPIFSGLDATLX = count;
179
    count++;
180
    XGPIFSGLDATH = count;
181
182
183
184
    else
185
186
      // master has all the data the peripheral sent...
187
188
189
  else
190
191
    // peripheral interface busy...
192
193
194
195
dazu noch ein paar Kleinigkeiten mit den LED's zur Kontrolle von einigen
Sachen.
Außerdem lasse ich den FX2 vom ADC mit 40MHz synchronisieren (das Zeug
steht ja dann alles in der gpif.c)
Die Pinbelegung:  ADC -> FX2
MCLK_CED   - IFCLK
DATA[15:0] - FD[15:0]
CS         - CTL1
RD/WR      - CTL2
DRDY       - RDY0
soweit so gut.
Nun die Frage: ich habe also die Waveforms mit dem GPIF-Designer
geändert und bekomme es einfach nicht gebacken die Daten richtig vom ADC
aus zulesen. Es ist doch so, dass die FIFORd-Waveform so oft aufgerufen
wird, wie groß der gewählte FIFO-Puffer gewählt ist, also hier:
        SYNCDELAY;          //
        EP6GPIFTCH = 0x00;
        SYNCDELAY;
        EP6GPIFTCL = 0x04;
4 x 2 Byte = 8 Byte (wegen WIDEWORD)?
Ich habe aber nun das Problem, dass ich zwar Daten (etwas davon)
bekomme, aber eigentlich möchte ich nur 4 Byte (2 WIDEWORD's) auslesen,
lese aber mittlerweile 8 aus, weil schon die ersten 2 Bytes, die ich
bekomme immer(!) auf FF stehen (?). Dann bekomme ich irgendein Byte,
dann wieder FF, wieder ein Byte, dann wieder FF...
Ich habe einfach das Gefühl, dass die zweiten 8 Bit nicht auslesen kann?
Habe mir das TRM und die AD-Unterlagen schon zu Gemüte geführt (würg),
weiß jetzt aber nicht weiter?!
Jetzt hoffe ich dass man mit dem Ganzen hier ein wenig was anfangen
kann?
Danke schonmal
mfg
  • [vhdl]VHDL-Code[/vhdl]
