Forum: Mikrocontroller und Digitale Elektronik DIL/NetPC9200_ssvirq
von zeiro (Gast)
Ich habe einen DIL/NetPC9200 und versuche gerade das Demobeispiel ssvirq
zu compilieren. Leider bekomme ich folgende Fehlermeldung:
zeiro@6715b:~/test4$ make
/usr/local/arm-linux/bin/arm-linux-gcc -D__KERNEL__ -DMODULE
-march=armv4 -mtune=arm9tdmi -I/usr/src/linux-2.4.27-vrs1-ssv1/include
-Os -pipe -mapcs-32 -Uarm -Wall -Wstrict-prototypes -Wno-trigraphs
-fno-strict-aliasing -fno-common -mshort-load-bytes -msoft-float -c
ssvirq.c -o ssvirq.o
ssvirq.c: In function `ssvirq_init':
ssvirq.c:90: `AT91PS_SYS' undeclared (first use in this function)
ssvirq.c:90: (Each undeclared identifier is reported only once
ssvirq.c:90: for each function it appears in.)
ssvirq.c:90: parse error before `AT91_SYS'
ssvirq.c:94: `AT91_SYS' undeclared (first use in this function)
make: *** [ssvirq.o] Fehler 1
wie kann in nun herausfinden in welcher Header-Datei sich AT91_SYS
befinden soll?
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/init.h>
#include <asm/io.h>
#include <asm/uaccess.h>
#include "ssvirq.h"
static volatile unsigned long ssvirq_count = 0;
static unsigned long *ssvirq_userptr = NULL;
static int ssvirq_used = 0, irqnr = SSVIRQ_IRQNUMBER;
/* load kernel module - insmod ssvirq.o... */
static int __init ssvirq_init(void) {
    AT91PS_SYS AT91_SYS = (AT91PS_SYS) AT91C_VA_BASE_SYS;
    /* change Source Mode Register for
       AIC entry 25 to positive edge triggered */
23
    AT91_SYS->AIC_SMR[25] = (0x3 << 5);
24
    /* PIO function disable - enable IRQ0 pin */
25
    AT91_SYS->PIOB_PDR = (1 << 29);
26
27
    /* register irq handler */
28
    if (request_irq(irqnr, ssvirq_interrupt, SA_INTERRUPT,
29
        "ssvirq", NULL)) {
30
        printk(KERN_ERR "ssvirq: can't get assigned irq %i\n", irqnr);
31
  return -EIO;
32
33
34
    /* register character device handler */
35
    if (register_chrdev(SSVIRQ_MAJOR,"ssvirq",&ssvirq_fops)) {
36
  printk(KERN_ERR "ssvirq: unable to get major %d\n", SSVIRQ_MAJOR);
37
  free_irq(irqnr, NULL);
38
  return -EIO;
39
40
41
    printk(KERN_INFO "ssvirq module installed.\n");
42
43
    return 0;
44
45
46
/* unload kernel module - rmmod ssvirq... */
47
static void __exit ssvirq_cleanup(void) {
48
49
    /* unregister irq handler */
50
51
    /* unregister character device handler */
52
    unregister_chrdev(SSVIRQ_MAJOR, "ssvirq");
53
    printk(KERN_INFO "ssvirq module removed.\n");
54
55
56
EXPORT_NO_SYMBOLS;
57
58
module_init(ssvirq_init);
59
module_exit(ssvirq_cleanup);
