Hallo, ich habe mir einen drehgeber bei reichelt bestellt. Nachdem ich ja noch immer recht wenig plan von dem Ganzen habe habe ich bissl geschaut und folgenden quelltext gefunden /*********************************************************************** */ /* */ /* Reading rotary encoder */ /* one, two and four step encoders supported */ /* */ /* Author: Peter Dannegger */ /* */ /*********************************************************************** */ #include <avr/io.h> #include <avr/interrupt.h> // target: ATmega16 //---------------------------------------------------------------------- -- #define XTAL 8e6 // 8MHz #define PHASE_A (PINA & 1<<PA1) #define PHASE_B (PINA & 1<<PA3) #define LEDS_DDR DDRC #define LEDS PORTC // LEDs against VCC volatile int8_t enc_delta; // -128 ... 127 static int8_t last; void encode_init( void ) { int8_t new; new = 0; if( PHASE_A ) new = 3; if( PHASE_B ) new ^= 1; // convert gray to binary last = new; // power on state enc_delta = 0; TCCR0 = 1<<WGM01^1<<CS01^1<<CS00; // CTC, XTAL / 64 OCR0 = (uint8_t)(XTAL / 64.0 * 1e-3 - 0.5); // 1ms TIMSK |= 1<<OCIE0; } ISR( TIMER0_COMP_vect ) // 1ms for manual move-ment { int8_t new, diff; new = 0; if( PHASE_A ) new = 3; if( PHASE_B ) new ^= 1; // convert gray to binary diff = last - new; // difference last - new if( diff & 1 ){ // bit 0 = value (1) last = new; // store new as next last enc_delta += (diff & 2) - 1; // bit 1 = direction (+/-) } } int8_t encode_read1( void ) // read single step encoders { int8_t val; cli(); val = enc_delta; enc_delta = 0; sei(); return val; // counts since last call } int8_t encode_read2( void ) // read two step encoders { int8_t val; cli(); val = enc_delta; enc_delta = val & 1; sei(); return val >> 1; } int8_t encode_read4( void ) // read four step encoders { int8_t val; cli(); val = enc_delta; enc_delta = val & 3; sei(); return val >> 2; } int main( void ) { int32_t val = 0; LEDS_DDR = 0xFF; encode_init(); sei(); for(;;){ val += encode_read1(); // read a single step encoder LEDS = val; } } Dieser code ist für den mega16. Ich habe aber nur nen mega 8515 und nen mega32 zur hand, aber das dürfte doch auch nicht anders sein, oder? Ich müsste dann doch einfach im AVR stu-dio beim gcc als target eben den mega32 auswählen, oder? Mein Ziel wäre echt einfach nur n Drehgeber, bei dem die LED einfach immer einen schritt wei-tergeht (damit ich diesen code dann für eine displayansteuerung/menüauswahl verwenden kann). Danke schon mal Grüße
Verschoben durch User
Bevor du stupide nur das "Target" änderst, solltest du versuchen den gefundenen code zu verstehen. Weil dann fällt dir auf, dass der eigendliche Encoder-Code prozessorunabhängig ist (ich benutze ihn sogar auf einem Renesas M16C26A). Mit dem Verstehen des Codes wird dir dann auch klar, welche Ports/Register du für deinen Prozessor ggf. anpassen musst. Einfach auf gut Glück das Target ändern ist zwar ´ne Maßnahme, bringt aber u.U. neue Probleme mit sich, welche einem "Anfänger" das Leben unnötig schwer machen.
habs das in word geschrieben - kann sein dass der das getrennt hat... die ports PINA & 1<<PA1 habe ich auf PINB & 1<<PA0 PINB & 1<<PA2 PINB & 1<<PA4 geändert LED Port habe ich auch angepasst. Habe eben sogar nen Quellcode gefunden der die Ports genauso ansteuert wie es bei mir der fall ist - aber selbst das funkte nicht mit dem 8515er.
Weshalb die Interrupts abschalten ? Um ein Byte zu lesen ? Was soll da unterbrochen werden ?
@aha > Weshalb die Interrupts abschalten ? Um ein Byte zu lesen ? Was soll da > unterbrochen werden ? cli(); val = enc_delta; enc_delta = val & 1; sei(); da liegt ja mehr als ein opcode dazwischen, da kann schon was verloren gehen. @TK schau Dri mal diese Zeilen: TCCR0 = 1<<WGM01^1<<CS01^1<<CS00; // CTC, XTAL / 64 OCR0 = (uint8_t)(XTAL / 64.0 * 1e-3 - 0.5); // 1ms an und vergleiche die Timer0 Einstellung von Mega16 und Deinem Zielcontroller. Bei Mega32 sollte das aber auch passen. Außerdem noch den Takt und den Vorteiler von Timer0 anschauen und mal ausrechnen nach wie vielen ms Timer0 überläuft. (Beispielcode und Zielcontroller) HTH, Klaus
