1 | #include <avr/io.h>
2 | #include <avr/eeprom.h>
3 | #include <avr/interrupt.h>
4 |
5 | #include "Kam54g10_menueOSD.h"
6 | #include "Kam54g10_usart.h"
7 | #include "Kam54g10_CRC.h"
8 |
9 | //Zoom routine--------------
10 | #define BYTES_IN_COMMAND 19
11 | #define NR_ZOOM_COMMAND 655
12 |
13 | static unsigned short crc_16;
14 | static unsigned int ADIteiler=0;
15 |
16 | // Timer IInterrupt Initialisation
17 | void initall()
18 | {
19 | //interrupt
20 | TCNT0 = 5; //Set Timer/counter
21 | TIMSK |= (1<<TOIE0); //Enable Timer/counter0 overflow interrupt
22 | TCCR0 |= (1<<CS01);
23 | TCCR0 |= (1<<CS00); //Select the clock source to be used by the timer/counter --> CPU Takt --> 4MHz/64
24 | TIFR |= (1<<TOV0); //interrupt starts with each overflow
25 | }//End initall()
26 |
27 | //Interrupt Service Routine für AD Wandlung
28 | ISR(TIMER0_OVF_vect)
29 | {
30 | ADIteiler++; //clocks interrupt counter value on each ms
31 | if(ADIteiler >= 60) //Counter cycle for all ms 60
32 | {
33 | ADIteiler=0; //counter 0 set
34 |
35 | static unsigned char k; //static ist nur in dieser Funktion sichtbar
36 | static unsigned char i;
37 | static unsigned char j;
38 | static unsigned char zommValue = 0;
39 | unsigned char Zoom[NR_ZOOM_COMMAND][BYTES_IN_COMMAND];
40 |
41 | crc_16 = 0;
42 |
43 | for(k = 0; k < NR_ZOOM_COMMAND; k++ )
44 | {
45 |
46 |
47 | Zoom[k][0] = 0x02;
48 | Zoom[k][1] = 0x21;
49 | Zoom[k][2] = 0x45;
50 | Zoom[k][3] = 0x00;
51 | Zoom[k][4] = (unsigned char)(zommValue >>8);
52 | Zoom[k][5] = (unsigned char)zommValue & 0xFF;
53 | Zoom[k][6] = 0x00;
54 | Zoom[k][7] = 0x00;
55 | Zoom[k][8] = 0x00;
56 | Zoom[k][9] = 0x00;
57 | Zoom[k][10] = 0x00;
58 | Zoom[k][11] = 0x00;
59 | Zoom[k][12] = 0x00;
60 | Zoom[k][13] = 0x00;
61 | Zoom[k][14] = 0x00;
62 | Zoom[k][15] = 0x00;
63 | Zoom[k][16] = 0x00;
64 | Zoom[k][17] = 0x00;
65 | Zoom[k][18] = 0x00;
66 |
67 | for (i = 1; i < 17; i++ )
68 | crc_16 = update_crc_16(crc_16, Zoom[k][i]); //calculate crc for the command
69 |
70 | Zoom[k][i] = (unsigned char)(crc_16 >> 8); // add crc value to [17] and [18] Buf position
71 | Zoom[k][i+1] = (unsigned char)crc_16 & 0xFF;
72 |
73 |
74 | for (j = 0; j < BYTES_IN_COMMAND; j++ )
75 | UART_Putc( Zoom[k][j] );
76 |
77 | zommValue=zommValue+100;
78 | }
79 |
80 | }
81 | }//End ISR(TIMER0_OVF_vect)
82 |
83 | void Send_ZoomCommand( void )
84 | {
85 | initall();
86 | cli();
87 | sei();
88 | }
89 |
90 | //Main---------
91 | #include <stdlib.h>
92 | #include <avr/io.h>
93 | #include <util/delay.h>
94 | #include <avr/interrupt.h>
95 |
96 | #include "Kam54g10_Zoom.h"
97 |
98 | #define BYTES_IN_COMMAND 19
99 |
100 | unsigned int iState;
101 |
102 |
103 |
104 | int main(void)
105 | {
106 |
107 | DDRC = 0x00; // PORTB auf Eingang
108 | PORTC = 0xFF; // pull ups for key inputs PortD2 and portD3
109 |
110 | DDRB = 0xFF; // outputs for LEDs
111 | PORTB = 0x00; // LEDs off
112 |
113 | UART_Init();
114 |
115 | sei();
116 |
117 |
118 | iState = 0;
119 | for(;;)
120 | {
121 | if (iState != PINC) // Key state changed ?
122 | {
123 | _delay_ms(50); // dirty "debounce"
124 |
125 | PINC = PINC & 0xFF;
126 | if ((PINC & 0x01) == 0x00) // one key
127 | {
128 | Send_MenueCommand(0);
129 | PORTB = 0xFE;
130 | }
131 |
132 | else if ((PINC & 0x02) == 0x00) // other key
133 | {
134 | PORTB = 0xF7;
135 | Send_ZoomCommand();
136 | }
137 |
138 | else // no key
139 | {
140 | PORTB = 0xff;
141 | }
142 | iState = PINC;
143 | }
144 | }
145 |
146 | }
