Forum: FPGA, VHDL & Co. EDK ERROR:Portability:89 - File system full
Autor: Peter M. (whitsha)
Hallo an alle,
Folgendes Problem:
ich versuche eine FSL Verbingung aufzubauen, so sieht das das mhs-file
aus:
PARAMETER VERSION = 2.1.0
 PORT fpga_0_RS232_Uart_1_RX_pin = fpga_0_RS232_Uart_1_RX, DIR = I
 PORT fpga_0_RS232_Uart_1_TX_pin = fpga_0_RS232_Uart_1_TX, DIR = O
 PORT fpga_0_DIP_Switches_8Bit_GPIO_in_pin =
fpga_0_DIP_Switches_8Bit_GPIO_in, DIR = I, VEC = [0:7]
 PORT fpga_0_DDR2_SDRAM_DDR2_ODT_pin = fpga_0_DDR2_SDRAM_DDR2_ODT, DIR =
O
 PORT fpga_0_DDR2_SDRAM_DDR2_Addr_pin = fpga_0_DDR2_SDRAM_DDR2_Addr, DIR
= O, VEC = [12:0]
 PORT fpga_0_DDR2_SDRAM_DDR2_BankAddr_pin =
fpga_0_DDR2_SDRAM_DDR2_BankAddr, DIR = O, VEC = [1:0]
 PORT fpga_0_DDR2_SDRAM_DDR2_CAS_n_pin = fpga_0_DDR2_SDRAM_DDR2_CAS_n,
DIR = O
 PORT fpga_0_DDR2_SDRAM_DDR2_CE_pin = fpga_0_DDR2_SDRAM_DDR2_CE, DIR = O
 PORT fpga_0_DDR2_SDRAM_DDR2_CS_n_pin = fpga_0_DDR2_SDRAM_DDR2_CS_n, DIR
= O
 PORT fpga_0_DDR2_SDRAM_DDR2_RAS_n_pin = fpga_0_DDR2_SDRAM_DDR2_RAS_n,
DIR = O
 PORT fpga_0_DDR2_SDRAM_DDR2_WE_n_pin = fpga_0_DDR2_SDRAM_DDR2_WE_n, DIR
= O
 PORT fpga_0_DDR2_SDRAM_DDR2_Clk_pin = fpga_0_DDR2_SDRAM_DDR2_Clk, DIR =
O, VEC = [1:0]
 PORT fpga_0_DDR2_SDRAM_DDR2_Clk_n_pin = fpga_0_DDR2_SDRAM_DDR2_Clk_n,
 PORT fpga_0_DDR2_SDRAM_DDR2_DM_pin = fpga_0_DDR2_SDRAM_DDR2_DM, DIR =
O, VEC = [3:0]
 PORT fpga_0_DDR2_SDRAM_DDR2_DQS = fpga_0_DDR2_SDRAM_DDR2_DQS, DIR = IO,
VEC = [3:0]
 PORT fpga_0_DDR2_SDRAM_DDR2_DQS_n = fpga_0_DDR2_SDRAM_DDR2_DQS_n, DIR =
IO, VEC = [3:0]
 PORT fpga_0_DDR2_SDRAM_DDR2_DQ = fpga_0_DDR2_SDRAM_DDR2_DQ, DIR = IO,
VEC = [31:0]
 PORT fpga_0_DDR2_SDRAM_DDR2_DQS_Div_I_pin =
fpga_0_DDR2_SDRAM_DDR2_DQS_Div_I, DIR = I
 PORT fpga_0_DDR2_SDRAM_DDR2_DQS_Div_O_pin =
fpga_0_DDR2_SDRAM_DDR2_DQS_Div_O, DIR = O
 PORT fpga_0_FLASH_Mem_A_pin = fpga_0_FLASH_Mem_A, DIR = O, VEC = [8:31]
 PORT fpga_0_FLASH_Mem_DQ_pin = fpga_0_FLASH_Mem_DQ, DIR = IO, VEC =
[0:7]
 PORT fpga_0_FLASH_Mem_WEN_pin = fpga_0_FLASH_Mem_WEN, DIR = O
 PORT fpga_0_FLASH_Mem_RPN_pin = fpga_0_FLASH_Mem_RPN, DIR = O
 PORT fpga_0_FLASH_Mem_OEN_pin = fpga_0_FLASH_Mem_OEN, DIR = O
 PORT fpga_0_FLASH_Mem_CEN_pin = fpga_0_FLASH_Mem_CEN, DIR = O
 PORT sys_clk_pin = dcm_clk_s, DIR = I, SIGIS = CLK, CLK_FREQ =
125000000
 PORT sys_rst_pin = sys_rst_s, DIR = I, RST_POLARITY = 0, SIGIS = RST
 PORT eigener_ip_0_LEDOUT_pin = eigener_ip_0_LEDOUT, DIR = O, VEC =
[1:0]
BEGIN microblaze
 PARAMETER INSTANCE = microblaze_0
 PARAMETER HW_VER = 7.10.a
 PARAMETER C_DEBUG_ENABLED = 1
 PARAMETER C_AREA_OPTIMIZED = 1
 PARAMETER C_FSL_LINKS = 1
 PARAMETER C_FAMILY = spartan3adsp
 PARAMETER C_INSTANCE = microblaze_0
 BUS_INTERFACE DPLB = mb_plb
 BUS_INTERFACE IPLB = mb_plb
 BUS_INTERFACE DEBUG = microblaze_0_dbg
 BUS_INTERFACE DLMB = dlmb
 BUS_INTERFACE ILMB = ilmb
 BUS_INTERFACE MFSL0 = fsl_v20_0
 PORT MB_RESET = mb_reset
END
BEGIN plb_v46
 PARAMETER INSTANCE = mb_plb
 PARAMETER HW_VER = 1.02.a
 PORT PLB_Clk = sys_clk_s
 PORT SYS_Rst = sys_bus_reset
END
BEGIN lmb_v10
 PARAMETER INSTANCE = ilmb
 PARAMETER HW_VER = 1.00.a
 PORT LMB_Clk = sys_clk_s
END
BEGIN lmb_v10
 PARAMETER INSTANCE = dlmb
END
BEGIN lmb_bram_if_cntlr
 PARAMETER INSTANCE = dlmb_cntlr
 PARAMETER HW_VER = 2.10.a
 PARAMETER C_BASEADDR = 0x00000000
 PARAMETER C_HIGHADDR = 0x00001fff
 BUS_INTERFACE SLMB = dlmb
 BUS_INTERFACE BRAM_PORT = dlmb_port
END
 PARAMETER INSTANCE = ilmb_cntlr
 BUS_INTERFACE SLMB = ilmb
 BUS_INTERFACE BRAM_PORT = ilmb_port
END
BEGIN bram_block
 PARAMETER INSTANCE = lmb_bram
 BUS_INTERFACE PORTA = ilmb_port
 BUS_INTERFACE PORTB = dlmb_port
END
BEGIN xps_uartlite
 PARAMETER INSTANCE = RS232_Uart_1
 PARAMETER C_BAUDRATE = 9600
 PARAMETER C_DATA_BITS = 8
 PARAMETER C_ODD_PARITY = 0
 PARAMETER C_USE_PARITY = 0
 PARAMETER C_SPLB_CLK_FREQ_HZ = 62500000
 PARAMETER C_BASEADDR = 0x84000000
 PARAMETER C_HIGHADDR = 0x8400ffff
 BUS_INTERFACE SPLB = mb_plb
 PORT RX = fpga_0_RS232_Uart_1_RX
 PORT TX = fpga_0_RS232_Uart_1_TX
END
BEGIN xps_gpio
 PARAMETER INSTANCE = DIP_Switches_8Bit
 PARAMETER C_GPIO_WIDTH = 8
 PARAMETER C_IS_DUAL = 0
 PARAMETER C_IS_BIDIR = 0
 PARAMETER C_ALL_INPUTS = 1
 PARAMETER C_BASEADDR = 0x81400000
 PARAMETER C_HIGHADDR = 0x8140ffff
 PORT GPIO_in = fpga_0_DIP_Switches_8Bit_GPIO_in
END
BEGIN mpmc
 PARAMETER INSTANCE = DDR2_SDRAM
 PARAMETER HW_VER = 4.00.a
 PARAMETER C_NUM_PORTS = 1
 PARAMETER C_MEM_PARTNO = MT47H32M16-5E
 PARAMETER C_DDR2_DQSN_ENABLE = 1
 PARAMETER C_MEM_DATA_WIDTH = 32
 PARAMETER C_MEM_CLK_WIDTH = 2
 PARAMETER C_MEM_DM_WIDTH = 4
 PARAMETER C_MEM_DQS_WIDTH = 4
 PARAMETER C_PIM0_BASETYPE = 2
 PARAMETER C_MPMC_CLK0_PERIOD_PS = 8000
 PARAMETER C_MPMC_BASEADDR = 0x88000000
 PARAMETER C_MPMC_HIGHADDR = 0x8fffffff
 BUS_INTERFACE SPLB0 = mb_plb
 PORT DDR2_ODT = fpga_0_DDR2_SDRAM_DDR2_ODT
 PORT DDR2_Addr = fpga_0_DDR2_SDRAM_DDR2_Addr
 PORT DDR2_BankAddr = fpga_0_DDR2_SDRAM_DDR2_BankAddr
 PORT DDR2_CAS_n = fpga_0_DDR2_SDRAM_DDR2_CAS_n
 PORT DDR2_CE = fpga_0_DDR2_SDRAM_DDR2_CE
 PORT DDR2_CS_n = fpga_0_DDR2_SDRAM_DDR2_CS_n
 PORT DDR2_RAS_n = fpga_0_DDR2_SDRAM_DDR2_RAS_n
 PORT DDR2_WE_n = fpga_0_DDR2_SDRAM_DDR2_WE_n
 PORT DDR2_Clk = fpga_0_DDR2_SDRAM_DDR2_Clk
 PORT DDR2_Clk_n = fpga_0_DDR2_SDRAM_DDR2_Clk_n
 PORT DDR2_DM = fpga_0_DDR2_SDRAM_DDR2_DM
 PORT DDR2_DQS = fpga_0_DDR2_SDRAM_DDR2_DQS
 PORT DDR2_DQS_n = fpga_0_DDR2_SDRAM_DDR2_DQS_n
 PORT DDR2_DQ = fpga_0_DDR2_SDRAM_DDR2_DQ
 PORT DDR2_DQS_Div_I = fpga_0_DDR2_SDRAM_DDR2_DQS_Div_I
 PORT DDR2_DQS_Div_O = fpga_0_DDR2_SDRAM_DDR2_DQS_Div_O
 PORT MPMC_Clk0 = DDR2_SDRAM_mpmc_clk_s
 PORT MPMC_Clk90 = DDR2_SDRAM_mpmc_clk_90_s
 PORT MPMC_Rst = sys_periph_reset
END
BEGIN xps_mch_emc
 PARAMETER INSTANCE = FLASH
 PARAMETER C_MCH_PLB_CLK_PERIOD_PS = 16000
 PARAMETER C_NUM_BANKS_MEM = 1
 PARAMETER C_MAX_MEM_WIDTH = 8
 PARAMETER C_MEM0_WIDTH = 8
 PARAMETER C_INCLUDE_DATAWIDTH_MATCHING_0 = 1
 PARAMETER C_SYNCH_MEM_0 = 0
 PARAMETER C_TCEDV_PS_MEM_0 = 70000
 PARAMETER C_TAVDV_PS_MEM_0 = 70000
 PARAMETER C_TWC_PS_MEM_0 = 70000
 PARAMETER C_TWP_PS_MEM_0 = 45000
 PARAMETER C_THZOE_PS_MEM_0 = 25000
 PARAMETER C_THZCE_PS_MEM_0 = 25000
 PARAMETER C_TLZWE_PS_MEM_0 = 5000
 PARAMETER C_MEM0_BASEADDR = 0x87000000
 PARAMETER C_MEM0_HIGHADDR = 0x87ffffff
 PORT Mem_A = fpga_0_FLASH_Mem_A_split
 PORT Mem_WEN = fpga_0_FLASH_Mem_WEN
 PORT Mem_DQ = fpga_0_FLASH_Mem_DQ
 PORT Mem_OEN = fpga_0_FLASH_Mem_OEN
 PORT Mem_CEN = fpga_0_FLASH_Mem_CEN
 PORT Mem_RPN = fpga_0_FLASH_Mem_RPN
END
BEGIN util_bus_split
 PARAMETER INSTANCE = FLASH_util_bus_split_1
 PARAMETER C_SIZE_IN = 32
 PARAMETER C_LEFT_POS = 0
 PARAMETER C_SPLIT = 8
 PORT Sig = fpga_0_FLASH_Mem_A_split
 PORT Out2 = fpga_0_FLASH_Mem_A
END
BEGIN clock_generator
 PARAMETER INSTANCE = clock_generator_0
 PARAMETER HW_VER = 2.00.a
 PARAMETER C_EXT_RESET_HIGH = 1
 PARAMETER C_CLKIN_FREQ = 125000000
 PARAMETER C_CLKOUT0_FREQ = 62500000
 PARAMETER C_CLKOUT0_BUF = TRUE
 PARAMETER C_CLKOUT0_PHASE = 0
 PARAMETER C_CLKOUT0_GROUP = NONE
 PARAMETER C_CLKOUT1_FREQ = 125000000
 PARAMETER C_CLKOUT1_BUF = TRUE
 PARAMETER C_CLKOUT1_PHASE = 0
 PARAMETER C_CLKOUT1_GROUP = DCM0
 PARAMETER C_CLKOUT2_FREQ = 125000000
 PARAMETER C_CLKOUT2_BUF = TRUE
 PARAMETER C_CLKOUT2_PHASE = 90
 PARAMETER C_CLKOUT2_GROUP = DCM0
 PORT CLKOUT0 = sys_clk_s
 PORT CLKOUT1 = DDR2_SDRAM_mpmc_clk_s
 PORT CLKOUT2 = DDR2_SDRAM_mpmc_clk_90_s
 PORT CLKIN = dcm_clk_s
 PORT LOCKED = Dcm_all_locked
 PORT RST = net_gnd
END
BEGIN mdm
 PARAMETER INSTANCE = debug_module
 PARAMETER HW_VER = 1.00.b
 PARAMETER C_MB_DBG_PORTS = 1
 PARAMETER C_USE_UART = 1
 PARAMETER C_UART_WIDTH = 8
 PARAMETER C_BASEADDR = 0x84400000
 PARAMETER C_HIGHADDR = 0x8440ffff
 BUS_INTERFACE MBDEBUG_0 = microblaze_0_dbg
 PORT Debug_SYS_Rst = Debug_SYS_Rst
END
BEGIN proc_sys_reset
 PARAMETER INSTANCE = proc_sys_reset_0
 PARAMETER C_EXT_RESET_HIGH = 0
 PORT Slowest_sync_clk = sys_clk_s
 PORT Dcm_locked = Dcm_all_locked
 PORT Ext_Reset_In = sys_rst_s
 PORT MB_Reset = mb_reset
 PORT Bus_Struct_Reset = sys_bus_reset
 PORT MB_Debug_Sys_Rst = Debug_SYS_Rst
 PORT Peripheral_Reset = sys_periph_reset
END
BEGIN eigener_ip
 PARAMETER INSTANCE = eigener_ip_0
 BUS_INTERFACE SFSL = fsl_v20_0
 PORT LEDOUT = eigener_ip_0_LEDOUT
END
BEGIN fsl_v20
 PARAMETER INSTANCE = fsl_v20_0
 PARAMETER HW_VER = 2.11.a
 PORT FSL_Clk = sys_clk_s
 PORT SYS_Rst = sys_rst_s
 PORT FSL_M_Clk = net_gnd
 PORT FSL_S_Clk = net_gnd
END
Beim Download bekomme ich dann folgende Fehlermeldung:
Davor habe ich das System schon mehrmals ins FPGA geladen,... ohne
Fehler
Auf welche Einstellungen sollte man beim FSL Aufbau achten, ... und wie
überprüft man am besten ob diese auch richtig im FPGA funktioniert?
Danke im Voraus
Peter
Autor: Georg A. (Gast)
> Auf welche Einstellungen sollte man beim FSL Aufbau achten...
Darauf, dass auf der Festplatte noch genügend Platz für die Unmengen von
Dateien ist, die so ein EDK-Lauf erzeugt?
  • [vhdl]VHDL-Code[/vhdl]
