1 | Error: Can't access JTAG chain
2 | Error: Can't configure device. Expected JTAG ID code 0x020B30DD for device 1, but found JTAG ID code 0x00000000.
3 | Error: Operation failed
4 | Info: Ended Programmer operation at Sat Oct 17 15:46:36 2009
5 | Info: Started Programmer operation at Sat Oct 17 15:46:55 2009
6 | Info: Started Programmer operation at Sat Oct 17 15:47:29 2009
7 | Error: Device chain in use
8 | Error: Operation failed
9 | Info: Ended Programmer operation at Sat Oct 17 15:47:39 2009
10 | Error: Can't access JTAG chain
11 | Info: Operation canceled
12 | Info: Ended Programmer operation at Sat Oct 17 15:47:43 2009
13 | Info: Started Programmer operation at Sat Oct 17 15:48:02 2009
14 | Info: Configuring device index 1
15 | Info: Device 1 contains JTAG ID code 0x020B30DD
16 | Error: Can't access JTAG chain
17 | Error: Can't configure device. Expected JTAG ID code 0x020B30DD for device 1, but found JTAG ID code 0xFFFFFFFF.
18 | Error: Operation failed
19 | Info: Ended Programmer operation at Sat Oct 17 15:48:04 2009
20 | Info: Started Programmer operation at Sat Oct 17 15:48:06 2009
21 | Error: JTAG Server can't access selected programming hardware
22 | Error: Operation failed
23 | Info: Ended Programmer operation at Sat Oct 17 15:48:06 2009
24 | Info: Started Programmer operation at Sat Oct 17 15:48:08 2009
25 | Error: JTAG Server can't access selected programming hardware
26 | Error: Operation failed
27 | Info: Ended Programmer operation at Sat Oct 17 15:48:08 2009
28 | Info: Started Programmer operation at Sat Oct 17 15:48:12 2009
29 | Error: JTAG Server can't access selected programming hardware
30 | Error: Operation failed
31 | Info: Ended Programmer operation at Sat Oct 17 15:48:12 2009
32 | Info: Started Programmer operation at Sat Oct 17 15:48:12 2009
33 | Error: JTAG Server can't access selected programming hardware
34 | Error: Operation failed
35 | Info: Ended Programmer operation at Sat Oct 17 15:48:12 2009
36 | Info: Started Programmer operation at Sat Oct 17 15:48:17 2009
37 | Error: Can't access JTAG chain
38 | Error: Operation failed
39 | Info: Ended Programmer operation at Sat Oct 17 15:48:17 2009
40 | Info: Started Programmer operation at Sat Oct 17 15:48:51 2009
41 | Info: Configuring device index 1
42 | Info: Device 1 contains JTAG ID code 0x020B30DD
43 | Error: Can't access JTAG chain
44 | Error: Can't configure device. Expected JTAG ID code 0x020B30DD for device 1, but found JTAG ID code 0xFFFFFFFF.
45 | Error: Operation failed
46 | Info: Ended Programmer operation at Sat Oct 17 15:48:53 2009
47 | Info: Started Full Compilation at Sat Oct 17 15:49:02 2009 Westeuropäische Normalzeit
48 | Info: Ended Full Compilation at Sat Oct 17 15:49:32 2009 Westeuropäische Normalzeit
49 | Info: Started Programmer operation at Sat Oct 17 15:49:43 2009
50 | Error: JTAG Server can't access selected programming hardware
51 | Error: Operation failed
52 | Info: Ended Programmer operation at Sat Oct 17 15:49:43 2009
53 | Info: Started Programmer operation at Sat Oct 17 15:50:05 2009
54 | Error: JTAG Server can't access selected programming hardware
55 | Error: Operation failed
56 | Info: Ended Programmer operation at Sat Oct 17 15:50:05 2009
57 | Info: Started Programmer operation at Sat Oct 17 15:50:20 2009
58 | Error: JTAG Server can't access selected programming hardware
59 | Error: Configuration failed
60 | Info: Ended Programmer operation at Sat Oct 17 15:50:20 2009
61 | Info: Started Programmer operation at Sat Oct 17 15:50:24 2009
62 | Error: JTAG Server can't access selected programming hardware
63 | Error: Configuration failed
64 | Info: Ended Programmer operation at Sat Oct 17 15:50:24 2009
65 | Info: Started Programmer operation at Sat Oct 17 15:51:41 2009
66 | Error: Device chain in Chain Description File does not match physical device chain -- expected 2 device(s) but found 1 device(s).
67 | Error: Operation failed
68 | Info: Ended Programmer operation at Sat Oct 17 15:51:42 2009
69 | Info: Started Programmer operation at Sat Oct 17 15:51:50 2009
70 | Info: Configuring device index 1
71 | Info: Device 1 contains JTAG ID code 0x020B30DD
72 | Error: Can't access JTAG chain
73 | Error: Can't configure device. Expected JTAG ID code 0x020B30DD for device 1, but found JTAG ID code 0x00000000.
74 | Info: Operation canceled
75 | Info: Ended Programmer operation at Sat Oct 17 15:53:21 2009
76 | Info: Started Programmer operation at Sat Oct 17 15:53:43 2009
77 | Info: Configuring device index 1
78 | Info: Device 1 contains JTAG ID code 0x020B30DD
79 | Error: Can't access JTAG chain
80 | Error: Can't configure device. Expected JTAG ID code 0x020B30DD for device 1, but found JTAG ID code 0x00000000.
81 | Info: Operation canceled
82 | Info: Ended Programmer operation at Sat Oct 17 15:54:51 2009
83 | Info: Started Programmer operation at Sat Oct 17 15:55:24 2009
84 | Error: Unable to reset device before configuration
85 | Error: Configuration failed
86 | Info: Ended Programmer operation at Sat Oct 17 15:55:24 2009
87 | Info: Started Programmer operation at Sat Oct 17 15:55:29 2009
88 | Error: Unable to reset device before configuration
89 | Error: Configuration failed
90 | Info: Ended Programmer operation at Sat Oct 17 15:55:30 2009
91 | Info: Started Programmer operation at Sat Oct 17 15:55:31 2009
92 | Error: Unable to reset device before configuration
93 | Error: Configuration failed
94 | Info: Ended Programmer operation at Sat Oct 17 15:55:32 2009
95 | Info: Started Programmer operation at Sat Oct 17 15:55:38 2009
96 | Info: Configuring device index 1
97 | Info: Device 1 contains JTAG ID code 0x020B30DD
98 | Error: Can't access JTAG chain
99 | Error: Can't configure device. Expected JTAG ID code 0x020B30DD for device 1, but found JTAG ID code 0xFFFFFFFF.
100 | Info: Operation canceled
101 | Info: Ended Programmer operation at Sat Oct 17 15:55:56 2009
102 | Info: Started Programmer operation at Sat Oct 17 15:56:07 2009
103 | Info: Configuring device index 1
104 | Info: Device 1 contains JTAG ID code 0x020B30DD
105 | Error: Can't access JTAG chain
