1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 | use IEEE.STD_LOGIC_ARITH.ALL;
4 | use IEEE.STD_LOGIC_UNSIGNED.ALL;
5 | use IEEE.NUMERIC_STD.ALL;
6 |
7 |
8 | entity topsound is
9 | Port (
10 | clk : in STD_LOGIC;
11 | button : in STD_LOGIC_Vector(4 downto 1);
12 | led : out STD_logic_Vector(8 downto 1 );
13 | audio_out : out STD_LOGIC := '0';
14 | ramAddress: out STD_LOGIC_VECTOR (16 downto 0 );
15 | ramData : inout STD_LOGIC_VECTOR (7 downto 0 );
16 | ramNWE : out STD_LOGIC; -- write enable (beide low aktiv)
17 | ramNOE : out STD_LOGIC; -- ram data output enable
18 | top_rs232_rxd : in std_logic; -- RS232 RxD
19 | top_rs232_txd : out std_logic -- RS232 TxD
20 | );
21 | end topsound;
22 |
23 | architecture Behavioral of topsound is
24 |
25 | component RS232_Interface is
26 |
27 | port( clk : in std_logic; -- Systemtakt
28 | rs232_rxd : in std_logic; -- RS232 RxD
29 | rs232_tra_en : in std_logic; -- Byte soll auf TxD abgesetzt werden
30 | rs232_dat_in : in std_logic_vector(7 downto 0); -- auf TxD abzusetzendes Byte
31 | rs232_txd : out std_logic := '1'; -- RS232 TxD
32 | rs232_rec_en : out std_logic := '0'; -- Byte wurde über RxD empfangen
33 | rs232_txd_busy : out std_logic; -- RS232 TxD besetzt
34 | rs232_dat_out : out std_logic_vector(7 downto 0) -- empfangenes Byte
35 | );
36 | end component;
37 |
38 | component Sound_PWM is
39 | Port ( value_in : in STD_LOGIC_VECTOR (7 downto 0);
40 | clk : in STD_LOGIC;
41 | pwm_out : out STD_LOGIC);
42 | end component;
43 |
44 | component dbg is
45 | Port (
46 | clk : in STD_LOGIC;
47 | vec_out : out STD_LOGIC_VECTOR (7 downto 0);
48 | vec_in : in STD_LOGIC_VECTOR (7 downto 0);
49 | ram_address : out STD_LOGIC_VECTOR (16 downto 0);
50 | ram_data_in : in STD_LOGIC_VECTOR (7 downto 0);
51 | ram_data_out : in STD_LOGIC_VECTOR (7 downto 0);
52 | val_out : out STD_LOGIC_VECTOR (7 downto 0);
53 | ram_nwe : out STD_LOGIC;
54 | ram_noe : out STD_LOGIC
55 | );
56 | end component;
57 |
58 | signal s_rs232_tra_en : std_logic; -- Byte soll auf TxD abgesetzt werden
59 | signal s_rs232_dat_in : std_logic_vector(7 downto 0); -- auf TxD abzusetzendes Byte
60 | signal s_rs232_dat_out : std_logic_vector(7 downto 0); -- empfangenes Byte
61 | signal s_rs232_rec_en : std_logic; -- Byte wurde über RxD empfangen
62 | signal s_rs232_txd_busy : std_logic; -- RS232 TxD besetzt
63 | signal s_value : std_logic_vector(7 downto 0);
64 | signal s_mem_data_out : std_logic_vector(7 downto 0);
65 | signal s_mem_data_in : std_logic_vector(7 downto 0);
66 | signal s_c_ram_nwe : std_logic;
67 | signal s_ram_address : std_logic_vector(16 downto 0);
68 | signal tmp : std_logic_vector(16 downto 0);
69 |
70 | begin
71 |
72 | RS232_Interface_impl: RS232_Interface
73 | port map(
74 | clk => clk,
75 | rs232_rxd => top_rs232_rxd,
76 | rs232_tra_en => s_rs232_tra_en,
77 | rs232_dat_in => s_rs232_dat_in,
78 | rs232_txd => top_rs232_txd,
79 | rs232_rec_en => s_rs232_rec_en,
80 | rs232_txd_busy => s_rs232_txd_busy,
81 | rs232_dat_out => s_rs232_dat_out
82 | );
83 |
84 | debug_interface_impl: dbg
85 | port map
86 | (
87 | clk => clk,
88 | vec_out => s_rs232_dat_in,
89 | vec_in => s_rs232_dat_out,
90 | ram_address => s_ram_address,
91 | ram_data_out=> s_mem_data_out,
92 | ram_data_in => s_mem_data_in,
93 | val_out => s_value,
94 | ram_nwe => s_c_ram_nwe,
95 | ram_noe => ramNOE
96 | );
97 |
98 | sound_interface_impl: Sound_PWM
99 | port map(
100 | value_in => s_value,
101 | clk => clk,
102 | pwm_out => audio_out
103 | );
104 |
105 | process (s_mem_data_out, s_c_ram_nwe)
106 | begin
107 | if s_c_ram_nwe = '0' then
108 | ramData <= s_mem_data_out; -- Debug treibt Datenbus
109 | else
110 | ramData <= "ZZZZZZZZ"; -- Debug verhält sich passiv
111 | end if;
112 | end process;
113 |
114 |
115 | -- Glue Logic
116 |
117 | ramNWE <= s_c_ram_nwe;
118 | s_mem_data_in <= ramData;
119 | ramAddress <= s_ram_address;
120 | led(8 downto 1) <= s_value;
121 |
122 |
123 | end Behavioral;
