1 | #include <avr/io.h>
2 | #include <avr/interrupt.h>
3 |
4 | // Für alte avr-gcc Versionen
5 | #ifndef SIGNAL
6 | #include <avr/signal.h>
7 | #endif // SIGNAL
8 |
9 | #include "rc5.h"
10 |
11 | #ifndef RC5_INT
12 | #define RC5_INT RC5_INT0
13 | #endif /* RC5_INT */
14 |
15 | #ifndef RC5_PRESCALE
16 | #define RC5_PRESCALE 1024
17 | #endif /* RC5_PRESCALE */
18 |
19 | /* ******************************************************************************** */
20 |
21 | rc5_t rc5;
22 |
23 | /* ******************************************************************************** */
24 |
25 | #ifndef F_CPU
26 | #error Please define F_CPU
27 | #endif /* !F_CPU */
28 |
29 | /* µs for a whole bit of RC5 (first & second part) */
30 | #define RC5_BIT_US (64*27)
31 |
32 | #define RC5_TICKS \
33 | ((uint8_t) ((uint32_t) (F_CPU / 1000 * RC5_BIT_US / 1000 / RC5_PRESCALE)))
34 |
35 | #define RC5_DELTA \
36 | (RC5_TICKS / 6)
37 |
38 | typedef union
39 | {
40 | uint16_t w;
41 | uint8_t b[2];
42 | } code_t;
43 |
44 | static code_t code;
45 | static uint8_t rc5_addr;
46 |
47 | /* Number of Bits received so far */
48 | /* Number of Interrupts occured so far */
49 | static uint8_t nbits;
50 | static uint8_t nint;
51 |
52 | /* ******************************************************************************** */
53 |
54 | void rc5_init (uint8_t addr)
55 | {
56 | nint = 0;
57 | nbits = 0;
58 | rc5.flip = -1;
59 |
60 | rc5_addr = addr;
61 |
62 | #if (RC5_PRESCALE==1024)
63 | TCCR0B = (1 << CS02) | (1 << CS00);
64 | #elif (RC5_PRESCALE==256)
65 | TCCR0B = (1 << CS02);
66 | #elif (RC5_PRESCALE==64)
67 | TCCR0B = (1 << CS01) | (1 << CS00);
68 | #else
69 | #error This RC5_PRESCALE is not supported
70 | #endif /* RC5_PRESCALE */
71 |
72 | /* INTx on falling edge */
73 | /* clear pending INTx */
74 | /* enable INTx interrupt */
75 | #if (RC5_INT == RC5_INT0)
76 | MCUCR = (MCUCR | (1 << ISC01)) & ~ (1 << ISC00);
77 | EIFR = (1 << INTF0);
78 | EIMSK |= (1 << INT0);
79 | #elif (RC5_INT == RC5_INT1)
80 | MCUCR = (MCUCR | (1 << ISC11)) & ~ (1 << ISC10);
81 | EIFR = (1 << INTF1);
82 | EIMSK |= (1 << INT1);
83 | #else
84 | #error please define RC5_INT
85 | #endif /* RC5_INT */
86 | }
87 |
88 | /* ******************************************************************************** */
89 |
90 | SIGNAL (SIG_OVERFLOW0)
91 | {
92 | TIMSK0 &= ~(1 << TOIE0);
93 |
94 | uint8_t _nbits = nbits;
95 | code_t _code = code;
96 |
97 | if (26 == _nbits)
98 | {
99 | _nbits++;
100 | _code.w <<= 1;
101 | }
102 |
103 | if (27 == _nbits
104 | && _code.b[1] >= 0x30 /* AGC == 3 */
105 | && 0 > rc5.flip)
106 | {
107 | uint8_t _rc5_code;
108 | uint8_t _rc5_addr;
109 | /* we do the bit manipulation stuff by hand, because of code size */
110 | _rc5_code = _code.b[0] & 0x3f; /* 0b00111111 : #0..#5 */
111 | _code.w <<= 2;
112 | _rc5_addr = _code.b[1] & 0x1f; /* 0b00011111 : #6..#10 */
113 |
114 | if (rc5_addr & 0x80
115 | || rc5_addr == _rc5_addr)
116 | {
117 | rc5.code = _rc5_code;
118 | rc5.addr = _rc5_addr;
119 | signed char flip = 0;
120 | if (_code.b[1] & 0x20) /* 0b00100000 : #11 */
121 | flip = 1;
122 | rc5.flip = flip;
123 | }
124 | }
125 |
126 | nint = 0;
127 | nbits = 0;
128 |
129 | /* INTx on falling edge */
130 | /* clear pending INTx */
131 | /* enable INTx interrupt */
132 | #if (RC5_INT == RC5_INT0)
133 | MCUCR = (MCUCR | (1 << ISC01)) & ~ (1 << ISC00);
134 | EIFR = (1 << INTF0);
135 | EIMSK |= (1 << INT0);
136 | #elif (RC5_INT == RC5_INT1)
137 | MCUCR = (MCUCR | (1 << ISC11)) & ~ (1 << ISC10);
138 | EIFR = (1 << INTF1);
139 | EIMSK |= (1 << INT1);
140 | #endif
141 | }
142 |
143 | /* ******************************************************************************** */
144 |
145 | #if (RC5_INT == RC5_INT0)
146 | SIGNAL (SIG_INTERRUPT0)
147 | #elif (RC5_INT == RC5_INT1)
148 | SIGNAL (SIG_INTERRUPT1)
149 | #endif /* RC5_INT */
150 | {
151 | code_t _code = code;
152 | uint8_t _nint = nint;
153 |
154 | uint8_t tcnt0 = TCNT0;
155 | TCNT0 = 0;
156 |
157 | if (0 == _nint)
158 | {
159 | /* INTx on both edges */
160 | #if (RC5_INT == RC5_INT0)
161 | MCUCR = (MCUCR | (1 << ISC00)) & ~ (1 << ISC01);
162 | #elif (RC5_INT == RC5_INT1)
163 | MCUCR = (MCUCR | (1 << ISC10)) & ~ (1 << ISC11);
164 | #endif /* RC5_INT */
165 |
166 | TIFR0 = (1 << TOV0);
167 | TIMSK0 |= (1 << TOIE0);
168 | _code.w = 0;
169 | }
170 | else
171 | {
172 | /* Number of bits of the just elapsed period */
173 | uint8_t n = 1;
174 |
175 | /* Bits received so far */
176 | uint8_t _nbits = nbits;
177 |
178 | /* is TCNT0 close to RC5_TICKS or RC5_TICKS/2 ? */
179 | if (tcnt0 > RC5_TICKS + RC5_DELTA)
180 | goto invalid;
181 | else if (tcnt0 < RC5_TICKS/2 - RC5_DELTA)
182 | goto invalid;
183 | else if (tcnt0 > RC5_TICKS - RC5_DELTA)
184 | n = 2;
185 | else if (tcnt0 > RC5_TICKS/2 + RC5_DELTA)
186 | goto invalid;
187 |
188 | /* store the just received 1 or 2 bits */
189 | do
190 | {
191 | _nbits++;
192 | if (_nbits & 1)
193 | {
194 | _code.w <<= 1;
195 | _code.b[0] |= _nint & 1;
196 | }
197 | }
198 | while (--n);
199 |
200 | if (0)
201 | {
202 | invalid:
203 |
204 | /* disable INTx, run into Overflow0 */
205 | #if (RC5_INT == RC5_INT0)
206 | EIMSK &= ~(1 << INT0);
207 | #elif (RC5_INT == RC5_INT1)
208 | EIMSK &= ~(1 << INT1);
209 | #endif /* RC5_INT */
210 |
211 | _nbits = 0;
212 | }
213 |
214 | nbits = _nbits;
215 | }
216 |
217 | code = _code;
218 | nint = 1+_nint;
219 | }
