Merkwürdige Fehler beim Fit (ISE 11.1)
OP Persönliche Seite #1520581
Started : "Fit".
CS: block property: block_name=/HC573/EXPANDED_FlattenFull/HC573/my_latch<6>1 prop_name=TYPE prop_terse=XDM_PROPERTY_STRING "TYPE" "INV"
CS: block property: block_name=/HC573/EXPANDED_FlattenFull/HC573 prop_name=TYPE prop_terse=XDM_PROPERTY_STRING "TYPE" "HC573"
Process "Fit" failed
Irgenwie kann ich überhaupt nicht erkenne was das Problem sein soll,
Synthese geht ohne Probleme durch, Code:
-- Create Date:    12:53:59 12/15/2009
-- Module Name:    HC573 - Behavioral
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity HC573 is
    Port ( addr_in  : in  STD_LOGIC_VECTOR (6 downto 0);
        addr_out : out STD_LOGIC_VECTOR (6 downto 0);
           latch : in  STD_LOGIC
end HC573;
architecture Behavioral of HC573 is
signal my_latch : std_logic_vector(6 downto 0);
begin
  my_latch <= addr_in when latch = '1' else "1010101";
  addr_out <= my_latch;
end Behavioral;
