1 | //LCD
2 | void _long_delay(void);
3 | void _lcd_write_command(unsigned char);
4 | void LCD_Write(unsigned char *);
5 | void LCD_Init(void);
6 | char LCD_Putchar(char);
7 | #define LCD_Clear {_lcd_write_command(0x01); _long_delay();_long_delay();}
8 | void LCD_Gotoxy(unsigned char , unsigned char );
9 | void LCD_Gotoxy2(unsigned char , unsigned char );
10 | void LCD_DezAusgabe(unsigned long wert , char stellen , unsigned char punkt);
11 | void LCD_Puts(const char *s);
12 |
13 |
14 | void _long_delay(void)
15 | {
16 | long t = 3000;
17 | while (t--);
18 | }
19 |
20 | void _short_delay(void)
21 | {
22 | int t = 350;
23 | while (t--);
24 | }
25 |
26 |
27 | void _lcd_write_command(unsigned char data)
28 | {
29 | DDRC |= (0x80+0x40+0x20+0x10+0x08);
30 | LCD_PORT_w = (data & 0xf0) | DISPLAY_EN;
31 | LCD_PORT_w = (data & 0xf0) | DISPLAY_EN;
32 | LCD_PORT_w = (data & 0xf0) | DISPLAY_EN;
33 | LCD_PORT_w = (data & 0xf0);
34 | LCD_PORT_w = (data & 0xf0);
35 | LCD_PORT_w = (data & 0xf0);
36 | LCD_PORT_w = (data << 4) | DISPLAY_EN;
37 | LCD_PORT_w = (data << 4) | DISPLAY_EN;
38 | LCD_PORT_w = (data << 4) | DISPLAY_EN;
39 | LCD_PORT_w = (data << 4);
40 | DDRC &= ~(0x80+0x40+0x20+0x10+0x08);
41 | PORTD &= ~0x08;
42 |
43 | }
44 |
45 | void _lcd_write_4bit(unsigned char data)
46 | {
47 | DDRC |= (0x80+0x40+0x20+0x10+0x08);
48 | LCD_PORT_w = (data << 4) | DISPLAY_EN;
49 | LCD_PORT_w = (data << 4) | DISPLAY_EN;
50 | LCD_PORT_w = (data << 4) | DISPLAY_EN;
51 | LCD_PORT_w = (data << 4);
52 | LCD_PORT_w = (data << 4);
53 | DDRC &= ~(0x80+0x40+0x20+0x10+0x08);
54 | PORTD &= ~0x08;
55 |
56 | }
57 |
58 | void lcd_write_byte(unsigned char data)
59 | {
60 | DDRC |= (0x80+0x40+0x20+0x10+0x08);
61 | LCD_PORT_w = (data & 0xf0) | DISPLAY_EN | DISPLAY_RS;
62 | LCD_PORT_w = (data & 0xf0) | DISPLAY_EN | DISPLAY_RS;
63 | LCD_PORT_w = (data & 0xf0) | DISPLAY_RS;
64 | LCD_PORT_w = (data & 0xf0) | DISPLAY_RS;
65 | LCD_PORT_w = (data << 4) | DISPLAY_EN | DISPLAY_RS;
66 | LCD_PORT_w = (data << 4) | DISPLAY_EN | DISPLAY_RS;
67 | LCD_PORT_w = (data << 4) | DISPLAY_RS;
68 | DDRC &= ~(0x80+0x40+0x20+0x10+0x08);
69 | PORTD &= ~0x08;
70 |
71 | }
72 |
73 |
74 | int my_pput(int zeichen)
75 | {
76 | lcd_write_byte((char) zeichen);
77 | return(1);
78 | }
79 |
80 | // initialize the LCD controller
81 | void LCD_Init(void)
82 | {
83 |
84 | LCD_PORT_DDR = 0xff;// - (0x01 + 0x02) ;//0xf0 | DISPLAY_RS | DISPLAY_EN;
85 | _long_delay();
86 | _long_delay();
87 | _lcd_write_4bit(0x03); // noch 8 Bit
88 | _long_delay();
89 | _lcd_write_4bit(0x03); // noch 8 Bit
90 | _long_delay();
91 | _lcd_write_4bit(0x03); // noch 8 Bit
92 | _long_delay();
93 | _lcd_write_4bit(0x02); // jetzt 4 Bit
94 | _long_delay();
95 |
96 | _lcd_write_command(0x28); // 4 Bit Zweizeilig
97 | //-
98 | _long_delay();
99 | _long_delay();
100 | _lcd_write_command(0x1C);
101 | _long_delay();
102 | _lcd_write_command(0x74);
103 | _long_delay();
104 | _lcd_write_command(0x52); //
105 | _long_delay();
106 | _lcd_write_command(0x69); // Contrast
107 |
108 | // ----------------------------
109 | //-
110 | _long_delay();
111 | _lcd_write_command(0x08); // Display aus
112 | _long_delay();
113 | _lcd_write_command(0x01); // Clear
114 | _long_delay();
115 | _lcd_write_command(0x06); //Entry mode
116 | _long_delay();
117 | _lcd_write_command(0x08 + 4); // Display an
118 | _long_delay();
119 | }
120 |
121 |
122 | void LCD_Gotoxy(unsigned char x , unsigned char y)
123 | {
124 | _short_delay();
125 | switch(y)
126 | { case 0 : _lcd_write_command(x + 0x80); break;
127 | case 1 : _lcd_write_command(x + 0xC0); break;
128 | case 2 : _lcd_write_command(x + (0x80 + 20)); break;
129 | case 3 : _lcd_write_command(x + (0xC0 + 20)); break;
130 | }
131 |
132 | }
133 |
134 |
135 | void LCD_Write(unsigned char *this_text)
136 | {
137 | unsigned char i = 0;
138 |
139 | while(this_text[i] != 0)
140 | {
141 | lcd_write_byte(this_text[i++]);
142 | _long_delay();
143 |
144 | }
145 |
146 |
147 | }
148 |
149 |
150 | char LCD_Putchar(char zeichen)
151 | {
152 | _short_delay();
153 | lcd_write_byte((char) zeichen);
154 | return(1);
155 | }
156 | void LCD_Puts(const char *s)
157 | {
158 | register char c;
159 |
160 | while ( (c = *s++) ) {
161 | LCD_Putchar(c);
162 | }
163 | }
164 |
165 |
166 |
167 | int main()
168 | {
169 | LCD_Init();
170 | LCD_Clear;
171 | LCD_Gotoxy(0,0);
172 | LCD_Puts("Hallo Welt");
173 | for(;;)
174 | {
175 | }
176 | return 0;
177 | }
