Forum: Mikrocontroller und Digitale Elektronik Initialisierung SED1520
Autor: Marko (Gast)
ich versuche seit zwei Tagen ein Grafik-LCD, Typ LMC84S042C13M
(Datenblatt:
http://www.mark-products.com/pdf/g122x32/84_042/84...)
anzusteuern. Leider schaffe ich nicht einmal es zu initialisieren. Das
LCD bleibt leer. Man kann den Schatten der Pixel erkennen, die
Takterzeugung (2kHz) und die Kontrastspannung stimmen also schon mal.
Ich poste mal meinen Code, vielleicht findet ja jemand einen Fehler:
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
#define F_CPU 1000000
#include <util/delay.h>
#define DATA    PORTA
#define DATA_DDR  DDRA
#define CTRL    PORTD
#define CTRL_DDR  DDRD
#define A0    (1<<PD0)
#define CS2    (1<<PD1)
#define CS1    (1<<PD2)
#define LCD_E  (1<<PD3)
#define RESET  (1<<PD4)
#define LCD_OFF 0xAE
#define LCD_ON 0xAF
#define LCD_RESET 0xE2
#define LCD_STATIC 0xA4
#define LCD_STARTLINE 0xC0
#define LCD_COLUMNADDR 0x00
#define LCD_DUTY32 0xA9
#define LCD_ADC 0xA0
#define LCD_PAGE1 0xBB
#define LCD_RMW_END 0xEE
void timer_init(void)
  DDRB |= (1<<PB3);  // enable OC0 pin
  TCCR0 |= (1<<WGM01) | (1<<COM00) | (1<<CS01);  // CTC mode, toggle OC0 on compare match
                          // prescaler = 8
  OCR0 = 31;  // 2khz
void ports_init(void)
  CTRL = 0xff;
  CTRL &= ~LCD_E;
  CTRL_DDR = 0xff;
  DATA = 0xff;
  DATA_DDR = 0xff;
void write_ctrl(unsigned char c)
  DATA = c;
  CTRL &= ~A0; // A0 low -> command
  CTRL &= ~(CS1 | CS2); // send to both controllers
  CTRL |= LCD_E;
  _delay_us(100);
  CTRL &= ~LCD_E;
  CTRL |= (CS1 | CS2);
  CTRL |= A0;
void write_data(unsigned char c)
  DATA = c;
  CTRL |= LCD_E;
  _delay_us(100);
  CTRL &= ~LCD_E;
void lcd_reset(void)
  CTRL &= ~LCD_RESET;
  _delay_us(100);
  CTRL |= LCD_RESET;
  _delay_ms(100);
int main(void)
  timer_init();
  ports_init();
  lcd_reset();
  _delay_ms(100);
  write_ctrl(LCD_OFF);
  _delay_ms(10);
  write_ctrl(LCD_STARTLINE);
  _delay_ms(10);
  write_ctrl(LCD_STATIC);
  _delay_ms(10);
  write_ctrl(LCD_COLUMNADDR);
  _delay_ms(10);
  write_ctrl(LCD_PAGE1);
  _delay_ms(10);
  write_ctrl(LCD_DUTY32);
  _delay_ms(10);
  write_ctrl(LCD_ADC);
  _delay_ms(10);
  write_ctrl(LCD_RMW_END);
  _delay_ms(10);
  write_data(0x55);
  write_data(0x55);
  for(;;);
Autor: Marko (Gast)
Achso, Controller ist ein ATMega16 auf einem STK500.
Autor: spess53 (Gast)
Hi
Du schaltest das Display am Ende der Initialisierung nicht ein.
MfG Spess
Autor: Marko (Gast)
headdesk
Funktioniert jetzt. Danke :) Ich hatte es mal drin, aber bei irgendeiner
Änderung ist es wohl rausgeflogen ...
