Hallo alle, Ich hab ein kleines Problem mit JOGL. Ich bekomme immer diese Fehler meldung unter Netbeans: Exception in thread "main" java.lang.UnsatisfiedLinkError: no gluegen-rt in java.library.path at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1678) at java.lang.Runtime.loadLibrary0(Runtime.java:840) at java.lang.System.loadLibrary(System.java:1047) at com.sun.gluegen.runtime.NativeLibLoader.loadLibraryInternal(NativeLibLoa der.java:102) at com.sun.gluegen.runtime.NativeLibLoader.access$000(NativeLibLoader.java: 51) at com.sun.gluegen.runtime.NativeLibLoader$1.run(NativeLibLoader.java:70) at java.security.AccessController.doPrivileged(Native Method) at com.sun.gluegen.runtime.NativeLibLoader.loadGlueGenRT(NativeLibLoader.ja va:68) at com.sun.gluegen.runtime.NativeLibrary.ensureNativeLibLoaded(NativeLibrar y.java:399) at com.sun.gluegen.runtime.NativeLibrary.open(NativeLibrary.java:163) at com.sun.gluegen.runtime.NativeLibrary.open(NativeLibrary.java:129) at com.sun.opengl.impl.x11.DRIHack.begin(DRIHack.java:109) at com.sun.opengl.impl.x11.X11GLDrawableFactory.<clinit>(X11GLDrawableFacto ry.java:99) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Class.java:186) at javax.media.opengl.GLDrawableFactory.getFactory(GLDrawableFactory.java:1 11) at javax.media.opengl.GLCanvas.chooseGraphicsConfiguration(GLCanvas.java:52 0) at javax.media.opengl.GLCanvas.<init>(GLCanvas.java:131) at javax.media.opengl.GLCanvas.<init>(GLCanvas.java:90) at InstallTest.main(InstallTest.java:26) Java Result: 1 BUILD SUCCESSFUL (total time: 3 seconds) also ich weiß echt nimmer weiter hab jetzt schon wegen den Libs und co geschaut aber will trotzdem ned. MFG Patrick
Patrick Weinberger schrieb: > Exception in thread "main" java.lang.UnsatisfiedLinkError: no gluegen-rt > in java.library.path > at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1678) > at java.lang.Runtime.loadLibrary0(Runtime.java:840) > at java.lang.System.loadLibrary(System.java:1047) Hast Du -Djava.library.path=/path/to/gluegen-rt-library zu den Laufzeitoptionen der JRE hinzugefügt? Unter Windows machen möglicherweise Leerzeichen im Pfad Probleme. Als Pfad ist übrigens der Name des Verzeichnisses anzugeben, in der die DLL liegt. Stephan
Das erste Problem hab ich schon gelöst arbeit mit Linux (Ubuntu) Ich hab den Pfad zu den .so Datei angeben. Danke mal
> Das erste Problem
Gibt es ein zweites Problem (und wenn ja: welches)?
Mein Problem ist das er das Gluegen-rt ned findet. Aber was kann ich dagegen jetzt machen obwohl ich diese Lib eingebunden hab? Patrick
