1 | Build started 4.1.2010 at 22:39:46
2 | avr-gcc -I"D:\test-ct-bot\H-files" -mmcu=atmega32 -Wall -gdwarf-2 -std=gnu99 -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT timer.o -MF dep/timer.o.d -c ../H-files/timer.c
3 | In file included from D:\test-ct-bot\H-files/features.h:14,
4 | from D:\test-ct-bot\H-files/time.h:23,
5 | from D:\test-ct-bot\H-files/sched.h:4,
6 | from D:\test-ct-bot\H-files/pthread.h:4,
7 | from ../H-files/timer.c:30:
8 | D:\test-ct-bot\H-files/sys/cdefs.h:46:44: error: missing binary operator before token "("
9 | D:\test-ct-bot\H-files/sys/cdefs.h:50:44: error: missing binary operator before token "("
10 | D:\test-ct-bot\H-files/sys/cdefs.h:80:1: warning: "__CONCAT" redefined
11 | In file included from ../H-files/global.h:34,
12 | from ../H-files/ct-Bot.h:312,
13 | from ../H-files/timer.c:26:
14 | c:/program files/atmel/winavr-20090313/lib/gcc/../../avr/include/stdint.h:286:1: warning: this is the location of the previous definition
15 | In file included from D:\test-ct-bot\H-files/features.h:14,
16 | from D:\test-ct-bot\H-files/time.h:23,
17 | from D:\test-ct-bot\H-files/sched.h:4,
18 | from D:\test-ct-bot\H-files/pthread.h:4,
19 | from ../H-files/timer.c:30:
20 | D:\test-ct-bot\H-files/sys/cdefs.h:138:19: error: missing binary operator before token "("
21 | D:\test-ct-bot\H-files/sys/cdefs.h:196:19: error: missing binary operator before token "("
22 | D:\test-ct-bot\H-files/sys/cdefs.h:205:19: error: missing binary operator before token "("
23 | D:\test-ct-bot\H-files/sys/cdefs.h:214:19: error: missing binary operator before token "("
24 | D:\test-ct-bot\H-files/sys/cdefs.h:223:19: error: missing binary operator before token "("
25 | D:\test-ct-bot\H-files/sys/cdefs.h:235:19: error: missing binary operator before token "("
26 | D:\test-ct-bot\H-files/sys/cdefs.h:245:19: error: missing binary operator before token "("
27 | D:\test-ct-bot\H-files/sys/cdefs.h:254:19: error: missing binary operator before token "("
28 | D:\test-ct-bot\H-files/sys/cdefs.h:262:19: error: missing binary operator before token "("
29 | D:\test-ct-bot\H-files/sys/cdefs.h:276:19: error: missing binary operator before token "("
30 | D:\test-ct-bot\H-files/sys/cdefs.h:286:20: error: missing binary operator before token "("
31 | D:\test-ct-bot\H-files/sys/cdefs.h:291:20: error: missing binary operator before token "("
32 | D:\test-ct-bot\H-files/sys/cdefs.h:298:19: error: missing binary operator before token "("
33 | In file included from D:\test-ct-bot\H-files/time.h:25,
34 | from D:\test-ct-bot\H-files/sched.h:4,
35 | from D:\test-ct-bot\H-files/pthread.h:4,
36 | from ../H-files/timer.c:30:
37 | D:\test-ct-bot\H-files/bits/types.h:46: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'loff_t'
38 | D:\test-ct-bot\H-files/bits/types.h:50: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'ino_t'
39 | D:\test-ct-bot\H-files/bits/types.h:62: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'dev_t'
40 | D:\test-ct-bot\H-files/bits/types.h:67: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'gid_t'
41 | D:\test-ct-bot\H-files/bits/types.h:72: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'mode_t'
42 | D:\test-ct-bot\H-files/bits/types.h:77: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nlink_t'
43 | D:\test-ct-bot\H-files/bits/types.h:82: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'uid_t'
44 | D:\test-ct-bot\H-files/bits/types.h:88: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'off_t'
45 | D:\test-ct-bot\H-files/bits/types.h:100: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'pid_t'
46 | D:\test-ct-bot\H-files/bits/types.h:110: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'ssize_t'
47 | In file included from D:\test-ct-bot\H-files/time.h:25,
48 | from D:\test-ct-bot\H-files/sched.h:4,
49 | from D:\test-ct-bot\H-files/pthread.h:4,
50 | from ../H-files/timer.c:30:
51 | D:\test-ct-bot\H-files/bits/types.h:158:20: error: missing binary operator before token "("
52 | In file included from D:\test-ct-bot\H-files/time.h:25,
53 | from D:\test-ct-bot\H-files/sched.h:4,
54 | from D:\test-ct-bot\H-files/pthread.h:4,
55 | from ../H-files/timer.c:30:
56 | D:\test-ct-bot\H-files/bits/types.h:235: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'blkcnt_t'
57 | D:\test-ct-bot\H-files/bits/types.h:239: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'fsblkcnt_t'
58 | D:\test-ct-bot\H-files/bits/types.h:243: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'fsfilcnt_t'
59 | In file included from D:\test-ct-bot\H-files/sched.h:4,
60 | from D:\test-ct-bot\H-files/pthread.h:4,
61 | from ../H-files/timer.c:30:
62 | D:\test-ct-bot\H-files/time.h:29:23: error: bits/time.h: No such file or directory
63 | D:\test-ct-bot\H-files/time.h:31:24: error: sys/select.h: No such file or directory
64 | In file included from D:\test-ct-bot\H-files/sched.h:4,
65 | from D:\test-ct-bot\H-files/pthread.h:4,
66 | from ../H-files/timer.c:30:
67 | D:\test-ct-bot\H-files/time.h:34: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'suseconds_t'
68 | D:\test-ct-bot\H-files/time.h:74: warning: 'struct timeval' declared inside parameter list
69 | D:\test-ct-bot\H-files/time.h:74: warning: its scope is only this definition or declaration, which is probably not what you want
70 | D:\test-ct-bot\H-files/time.h:112: error: field 'it_interval' has incomplete type
71 | D:\test-ct-bot\H-files/time.h:114: error: field 'it_value' has incomplete type
72 | D:\test-ct-bot\H-files/time.h:140: error: array type has incomplete element type
73 | In file included from D:\test-ct-bot\H-files/pthread.h:4,
74 | from ../H-files/timer.c:30:
75 | D:\test-ct-bot\H-files/sched.h:5:23: error: sys/types.h: No such file or directory
76 | In file included from D:\test-ct-bot\H-files/pthread.h:4,
77 | from ../H-files/timer.c:30:
78 | D:\test-ct-bot\H-files/sched.h:46: error: expected ')' before 'pid'
79 | D:\test-ct-bot\H-files/sched.h:47: error: expected ')' before 'pid'
80 | D:\test-ct-bot\H-files/sched.h:49: error: expected ')' before 'pid'
81 | D:\test-ct-bot\H-files/sched.h:50: error: expected ')' before 'pid'
82 | D:\test-ct-bot\H-files/sched.h:52: error: expected ')' before 'pid'
83 | D:\test-ct-bot\H-files/sched.h:53: error: expected ')' before 'pid'
84 | D:\test-ct-bot\H-files/sched.h:55: error: expected ')' before 'pid'
85 | D:\test-ct-bot\H-files/sched.h:56: error: expected ')' before 'pid'
86 | D:\test-ct-bot\H-files/sched.h:67: error: expected ')' before 'pid'
87 | D:\test-ct-bot\H-files/sched.h:68: error: expected ')' before 'pid'
88 | In file included from D:\test-ct-bot\H-files/pthread.h:5,
89 | from ../H-files/timer.c:30:
90 | D:\test-ct-bot\H-files/signal.h:11:22: error: sys/time.h: No such file or directory
91 | D:\test-ct-bot\H-files/signal.h:125:2: error: #error signal layout not yet known
92 | In file included from D:\test-ct-bot\H-files/pthread.h:5,
93 | from ../H-files/timer.c:30:
94 | D:\test-ct-bot\H-files/signal.h:255: error: expected specifier-qualifier-list before 'pid_t'
95 | D:\test-ct-bot\H-files/signal.h:265: error: expected specifier-qualifier-list before 'pid_t'
96 | D:\test-ct-bot\H-files/signal.h:271: error: expected specifier-qualifier-list before 'pid_t'
97 | D:\test-ct-bot\H-files/signal.h:495: error: expected ')' before 'pid'
98 | D:\test-ct-bot\H-files/signal.h:499: warning: 'struct timespec' declared inside parameter list
99 | D:\test-ct-bot\H-files/signal.h:512:26: error: sys/ucontext.h: No such file or directory
100 | In file included from ../H-files/timer.c:30:
101 | D:\test-ct-bot\H-files/pthread.h:112: warning: 'struct timespec' declared inside parameter list
102 | D:\test-ct-bot\H-files/pthread.h:235: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'pthread_atfork'
103 | ../H-files/timer.c: In function 'timer_get_tickCount16':
104 | ../H-files/timer.c:60: warning: 'timer_mutex' is static but used in inline function 'timer_get_tickCount16' which is not static
105 | ../H-files/timer.c:62: warning: 'timer_mutex' is static but used in inline function 'timer_get_tickCount16' which is not static
106 | ../H-files/timer.c: In function 'timer_get_tickCount32':
107 | ../H-files/timer.c:68: warning: 'timer_mutex' is static but used in inline function 'timer_get_tickCount32' which is not static
108 | ../H-files/timer.c:70: warning: 'timer_mutex' is static but used in inline function 'timer_get_tickCount32' which is not static
109 | make: *** [timer.o] Error 1
110 | Build failed with 54 errors and 10 warnings...
