1 | // Einbinden von bestehenden Modulen
2 | #include <avr/io.h> // AVR Standart IO Register Definitionen
3 | #include <stdio.h> // Standart IO Register
4 | #include <avr/iom644.h> // ATMega644 Register Definitionen
5 | #include <avr/iomxx4.h> // ATMegaXX4 Register Definitionen
6 | #include <avr/interrupt.h> // Interrupt Register Definitionen
7 | #include "arrays.h"
8 |
9 | //------------------------------------------------------------------------------
10 | // Definitionen
11 | #define LED_green_on (PORTD |= (1<<5))
12 | #define LED_green_off (PORTD &= (~(1<<5)))
13 | #define LED_red_on (PORTB |= (1<<3))
14 | #define LED_red_off (PORTB &= (~(1<<3)))
15 | #define LED_blue_on (PORTD |= (1<<7))
16 | #define LED_blue_off (PORTD &= (~(1<<7)))
17 | #define X_select (PORTB &= (~(1<<0)))
18 | #define Y_select (PORTB &= (~(1<<1)))
19 | #define no_select ((PORTB |= (1<<0)) & (PORTB |= (1<<1)))
20 |
21 | #define search 0
22 | #define waitSOH 1
23 | #define waitCONTROL 2
24 | #define waitAXIS 3
25 | #define waitEOT 4
26 | #define Buf_max 49
27 | #define RXTX_Reg UDR0
28 | #define ENQ 0x05
29 | #define SOH 0x01 // Start of Header
30 | #define EOT 0x04 // End of Transmission
31 |
32 | #define F_CPU 24000000 // Quarzfrequenz
33 | #define BAUDRATE 3000000 // Baudrate für Kommunikation
34 |
35 | int uart_putchar(char c, FILE *stream); //privat für printf
36 | static FILE mystdout = FDEV_SETUP_STREAM(uart_putchar, NULL,_FDEV_SETUP_WRITE);
37 |
38 | //------------------------------------------------------------------------------
39 | // Variablen
40 | static volatile int SysCount = 0; // Nutz-Counter
41 | static volatile int index_rxBuf_R = 0; // Index wo zuletzt gelesen wurde
42 | static volatile int index_rxBuf_W = 0; // Index wo zuletzt geschrieben wurde
43 | static volatile int rxBuf[Buf_max+1]; // RX Buffer
44 |
45 | //int control[600]={};
46 | //uint16_t x_achse[600]={};
47 | //uint16_t y_achse[600]={};
48 |
49 | //------------------------------------------------------------------------------
50 | // Funktionen
51 | void DAC_Output(uint16_t val){ // converts 12Bit to the DA Converter
52 | if(val & (1<<8)){
53 | PORTC |= (1<<3);
54 | }
55 | else{
56 | PORTC &= (~(1<<3));
57 | }
58 | if(val & (1<<9)){
59 | PORTC |= (1<<2);
60 | }
61 | else{
62 | PORTC &= (~(1<<2));
63 | }
64 | if(val & (1<<10)){
65 | PORTC |= (1<<1);
66 | }
67 | else{
68 | PORTC &= (~(1<<1));
69 | }
70 | if(val & (1<<11)){
71 | PORTC |= (1<<0);
72 | }
73 | else{
74 | PORTC &= (~(1<<0));
75 | }
76 | PORTA = val;
77 | }
78 | void SysInit(){
79 | int i = 0;
80 |
81 | DDRA = 0xFF; // IO Definieren
82 | DDRB = 0x1B;
83 | DDRC = 0x0F;
84 | PORTC = 0xF0; // Pull up einschalten
85 | DDRD = 0xF0;
86 |
87 | UBRR0H = ((F_CPU/(BAUDRATE*8L)-1) >> 8); // calc Baud
88 | UBRR0L = (uint8_t)(F_CPU/(BAUDRATE*8L)-1); // Double speed
89 | UCSR0A |= (1<<U2X0); // RS232 Settings: double speed
90 | UCSR0B |= (1<<RXCIE0)|(1<<RXEN0)|(1<<TXEN0); // Complete Interrupts, RX und TX einschalten
91 | UCSR0C |= (1<<UCSZ01)|(1<<UCSZ00); // Asynchron, 8-Bit
92 |
93 | TCCR2A |= (1<<WGM21); // Timer2 löst mit 100kHz Interrupt aus
94 | TCCR2B |= (1<<CS21);
95 | TIMSK2 |= (1<<OCIE2A);
96 | OCR2A = 30;
97 |
98 | for(i=0;i<=Buf_max;i++){
99 | rxBuf[i] = 0;
100 | }
101 | DAC_Output(2048);
102 | X_select;
103 | Y_select;
104 | no_select;
105 |
106 | stdout = &mystdout;
107 |
108 | sei(); // Global Interrupts einschalten
109 | }
110 |
111 | int uart_putchar(char c, FILE *stream) //Nur für Ausgabe mit printf
112 | {
113 | if (c == '\n')
114 | uart_putchar('\r', stream);
115 | loop_until_bit_is_set(UCSR0A, UDRE0);
116 | UDR0 = c;
117 | return 0;
118 | }
119 |
120 |
121 | void RS232(void){
122 | static int RS232_state = 0; // Protokollstatus
123 | static int index_par = 0; // Array-Variable für Parameters
124 | static uint16_t k = 0;
125 | if(index_rxBuf_W == index_rxBuf_R){ // Buffer Error abgleichen
126 | return; // Wenn Error => aus Funktion heraus springen
127 | }
128 | if(index_rxBuf_R == Buf_max){ // Erhöhen
129 | index_rxBuf_R = 0;
130 | }
131 | else{
132 | index_rxBuf_R ++;
133 | }
134 | switch (RS232_state){ // RS232 Protokoll
135 | case search:
136 | if(rxBuf[index_rxBuf_R] == '@'){
137 | RS232_state = waitSOH;
138 | printf("dac_board_v1");
139 | }
140 | break;
141 | case waitSOH:
142 | switch (rxBuf[index_rxBuf_R]){
143 | case SOH:
144 | RS232_state = waitCONTROL; // In nächsten State wechselnd
145 | break;
146 | case EOT:
147 | RS232_state = waitSOH;
148 | break;
149 | default:
150 | RXTX_Reg = NACK;
151 | break;
152 | }
153 | break;
154 | case waitCONTROL:
155 | control[k] = rxBuf[index_rxBuf_R];
156 | RS232_state = waitAXIS;
157 | break;
158 | case waitAXIS:
159 | switch (index_par){
160 | case 0:
161 | x_achse[k] = (rxBuf[index_rxBuf_R] << 4);
162 | index_par ++;
163 | break;
164 | case 1:
165 | x_achse[k] |= (x_achse[k - 1] | (rxBuf[index_rxBuf_R] >> 4));
166 | k ++;
167 | y_achse[k] = ((rxBuf[index_rxBuf_R] & 0x0F) << 8);
168 | index_par ++;
169 | break;
170 | case 2:
171 | y_achse[k] |= (y_achse[k - 1] | (rxBuf[index_rxBuf_R]));
172 | index_par = 0;
173 | RS232_state = waitEOT;
174 | break;
175 | }
176 | break;
177 | case waitEOT:
178 | if(rxBuf[index_rxBuf_R] == EOT){
179 | RS232_state = waitSOH;
180 | }
181 | break;
182 | }
183 | if(k == 599) k = 0;
184 | else k ++;
185 | }
186 | void Output(){
187 | static uint16_t p = 0;
188 | if((control[p] & (1<<7)) != 0){
189 | LED_red_on;
190 | }
191 | else{
192 | LED_red_off;
193 | }
194 | if((control[p] & (1<<6)) != 0){
195 | LED_green_on;
196 | }
197 | else{
198 | LASER_green_off;
199 | }
200 | if((control[p] & (1<<5)) != 0){
201 | LED_blue_on;
202 | }
203 | else{
204 | LED_blue_off;
205 | }
206 | if((control[p] & 0x1F) == SysCount){
207 | DAC_Output(x_achse[p]);
208 | X_select;
209 | no_select;
210 | DAC_Output(y_achse[p]);
211 | Y_select;
212 | no_select;
213 | if((p == 299) || (p == 599)) RXTX_Reg = ENQ;
214 | if(p == 574) p = 0;
215 | else p ++;
216 | SysCount = 0;
217 | }
218 | }
219 | //------------------------------------------------------------------------------
220 | // INTERRUPS
221 | ISR(TIMER2_COMPA_vect){ // Mit 100kHz SysCount erhöhen
222 | SysCount ++;
223 | }
224 | ISR(USART0_RX_vect){ // Received Complete Interrupt
225 | if(index_rxBuf_W == Buf_max){ // Damit Buffer nicht überläuft
226 | index_rxBuf_W = 0;
227 | }
228 | else{
229 | index_rxBuf_W ++;
230 | }
231 | if(index_rxBuf_W == index_rxBuf_R){ // Wenn Write-Index Read-Index eingeholt hat
232 | return;
233 | }
234 | else{ // Daten speichern
235 | rxBuf[index_rxBuf_W] = RXTX_Reg;
236 | }
237 | }
238 | //------------------------------------------------------------------------------
239 | // Hauptfunktion (wird beim Start ausgeführt)
240 | int main(void){
241 | SysInit(); // Systeminitialisierung
242 | while(1){
243 | RS232();
244 | Output();
245 | }
246 | return 0;
247 | }
248 | //------------------------------------------------------------------------------
