Problem mit RFM12B
Gast #1550407
Hallo!
Ich versuche gerade eine RFM12B Funkstrecke zum laufen zu bringen.
Leider funzt es nicht und ich bin ratlos!! :-(
Hier mal das Bascom Beispiel von Elektor das ich verwende:
für den Sender:
   Init_rfm12
   Freq = 868.300
   Freq_rfm12
   'Sende key data
   Test3:
      D = Spi16(&H8238)
      Do
         Wait_rfm12
         D = Spi16(&Hb82d)
         Wait_rfm12
         D = Spi16(&Hb8d4)
      Loop
Sub Init_rfm12
  Nsel = 1
  Sck = 0
  'D = Spi16(&H80d7)                                         ' El , Ef ,
11.5pf, 433 MHz band
  D = Spi16(&H80e7)                                         ' El , Ef ,
11.5pf, 868 MHz band
  D = Spi16(&H82d9)                                         '!er , !ebb
, Et , Es , Ex , !eb , !ew , Dc
  D = Spi16(&Ha67c)                                         ' 434,15 MHz
/ 868,3 MHz
  D = Spi16(&Hc647)                                         ' 4.8kbps
  D = Spi16(&H94a0)                                         ' Vdi , Fast
, 134 kHz , 0db , -79dbm
  D = Spi16(&Hc2ac)                                         ' Al , !ml ,
Dig , Dqd4
  D = Spi16(&Hca81)                                         ' Fifo8 ,
Sync , !ff , Dr
  D = Spi16(&Hc483)                                         ' @pwr , No
Rstric , !st , !fi , Oe , En
  D = Spi16(&H9850)                                         '9854??' 90
kHz , power - 0 dB
  D = Spi16(&He000)                                         '
  D = Spi16(&Hc800)                                         '
  D = Spi16(&Hc000)                                         ' 1 MHz ,
2.2V
End Sub
Sub Freq_rfm12
  If Freq < 800 Then Freq = Freq * 2
  Freq = Freq - 860
  D = Freq / 0.0050
  If D < 96 Then D = 96
  If D > 3903 Then D = 3903
  D = D + &HA000
  D = Spi16(d)
End Sub
Sub Send_rfm12
  D = Spi16(&H8238)
  Wait_rfm12
  D = Spi16(&Hb8aa)
  Wait_rfm12
  D = Spi16(&Hb8aa)
  Wait_rfm12
  D = Spi16(&Hb8aa)
  Wait_rfm12
  D = Spi16(&Hb82d)
  Wait_rfm12
  D = Spi16(&Hb8d4)
  For N = 1 To 10
    Wait_rfm12
    D = &HB800 + Data_out(n)
    D = Spi16(d)
  Next N
  Wait_rfm12
  D = Spi16(&Hb8aa)
  Wait_rfm12
  D = Spi16(&Hb8aa)
  Wait_rfm12
  D = Spi16(&H8208)
End Sub
Sub Wait_rfm12
  Nsel = 0
  Do
  Loop Until Sdo = 1
End Sub
Sub Receive_rfm12
  Tt = Timeout * 10
  D = Spi16(&H82c8)
  D = Spi16(&Hca83)
  For N = 1 To 10
    Nsel = 0
    T = 0
    Do
      T = T + 1
      Waitus 100
      If T > Tt Then Goto Nosignal
    Loop Until Sdo = 1
    D = Spi16(&Hb000)
    Data_in(n) = D
  Next N
Nosignal:
  D = Spi16(&H8208)
End Sub
Function Spi16(byval Dout As Word) As Word
Local Nspi As Integer
Local Dspi As Integer
Local Dsdo As Word
  Nsel = 0
  Dsdo = 0
  For Nspi = 1 To 16
    Dspi = Dout And &H8000
    If Dspi = 0 Then
       Sdi = 0
    Else
       Sdi = 1
    End If
    Dout = Dout * 2
    Dsdo = Dsdo * 2
    Dsdo = Dsdo + Sdo
    Sck = 1
    Waitus 5
    Sck = 0
  Next Nspi
  Nsel = 1
  Spi16 = Dsdo
End Function
für den Empfänger:
   Init_rfm12
   Freq = 868.300
   Freq_rfm12
   'start receiver, all data
   D = &H00AA
   Print #2 , Chr(d)
   Wait 1
      Test4:
      D = Spi16(&H82c8)
      D = Spi16(&Hca8b)
      Print #2 , ""
      For N = 1 To 100
        Wait_rfm12
        D = Spi16(&Hb000)
        Data_in(n) = D
        Print #2 , Chr(d)
      Next N
      Do
      Loop
Sub Init_rfm12
  Nsel = 1
  Sck = 0
/ 868,3 MHz
Dig , Dqd4
Sync , !ff , Dr
kHz , power - 0 dB
  D = Spi16(&He000)                                         '
  D = Spi16(&Hc800)                                         '
2.2V
End Sub
Sub Freq_rfm12
  Freq = Freq - 860
  D = Freq / 0.0050
  D = D + &HA000
  D = Spi16(d)
End Sub
Sub Send_rfm12
  D = Spi16(&H8238)
  Wait_rfm12
  D = Spi16(&Hb8aa)
  Wait_rfm12
  D = Spi16(&Hb8aa)
  Wait_rfm12
  D = Spi16(&Hb8aa)
  Wait_rfm12
  D = Spi16(&Hb82d)
  Wait_rfm12
  D = Spi16(&Hb8d4)
  For N = 1 To 10
    Wait_rfm12
    D = Spi16(d)
  Next N
  Wait_rfm12
  D = Spi16(&Hb8aa)
  Wait_rfm12
  D = Spi16(&Hb8aa)
  Wait_rfm12
  D = Spi16(&H8208)
End Sub
Sub Wait_rfm12
  Nsel = 0
  Do
  Loop Until Sdo = 1
End Sub
Sub Receive_rfm12
  Tt = Timeout * 10
  D = Spi16(&H82c8)
  D = Spi16(&Hca83)
  For N = 1 To 10
    Nsel = 0
    T = 0
    Do
      T = T + 1
      Waitus 100
    Loop Until Sdo = 1
    D = Spi16(&Hb000)
    Data_in(n) = D
  Next N
Nosignal:
  D = Spi16(&H8208)
End Sub
Local Dsdo As Word
  Nsel = 0
  Dsdo = 0
  For Nspi = 1 To 16
    If Dspi = 0 Then
       Sdi = 0
    Else
       Sdi = 1
    End If
    Dout = Dout * 2
    Dsdo = Dsdo * 2
    Dsdo = Dsdo + Sdo
    Sck = 1
    Waitus 5
    Sck = 0
  Next Nspi
  Nsel = 1
  Spi16 = Dsdo
End Function
Wenn ich mir dann die Daten anschaue die der Empfänger übermittelt
(Filter nur auf &HD4 eingestellt), kommt dann das raus: &H00 &H2d &H00
&HD4 &H00 .....
Wenn ich den empfänger aber auf &H2DD4 Filter einstelle, übermittelt er
gar nichts mehr an die Serielle schnittstalle, da er bei Wait_RFM12
hängen bleibt, weil der Filter nie Syncronisiert.
Was ist da los??? kann mir bitte jemand weiter helfen?!?!
Ich vermute mal, das der Sender nach oder vor jedem Byte nochmals ein
Byte mit &H00 sendet, aber warum???
MFG Pirker
