Forum: Mikrocontroller und Digitale Elektronik interrupteinstellung lpc2378
von Steffen H. (mcst)
Hi
ich bin ARM-Neuling und hab so meine Probleme.
ich will auf einem LPC2378 den CAN über interrupt laufen lassen, die
Beiträge hier im Forum haben mir leider noch nicht weiterhelfen können.
Meine Initialisierung sieht wie folgt aus :
CAN1IER = CAN2IER = 0x01; // Enable receive interrupts
VICVectAddr23 = HandlerAddr //HandlerAddris Pointer auf function
VICVectCntl23 = 0x01;
VICIntEnable = 1 << 23;  /* Enable Interrupt */
nun dacht ich, es muss noch das I-Flag im CPSR vom ARM-Kern deaktiviert
werden daher steht in meinem Startup-File:
/* Stack Sizes */
.set  UND_STACK_SIZE, 0x00000004 /* stack for "undefined instruction" interrupts is 4 bytes*/
.set  ABT_STACK_SIZE, 0x00000004/* stack for "abort" interrupts is 4 bytes*/
.set  FIQ_STACK_SIZE, 0x00000004/* stack for "FIQ" interrupts  is 4 bytes*/
.set  IRQ_STACK_SIZE, 0X00000080/* stack for "IRQ" normal interrupts is 4 bytes*/
.set  SVC_STACK_SIZE, 0x00000004/* stack for "SVC" supervisor mode is 4 bytes*/
/* Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs (program status registers) */
.set  MODE_USR, 0x10 /* Normal User Mode */
.set  MODE_FIQ, 0x11 /* FIQ Processing Fast Interrupts Mode */
.set  MODE_IRQ, 0x12 /* IRQ Processing Standard Interrupts Mode */
.set  MODE_SVC, 0x13 /* Supervisor Processing Software Interrupts Mode*/
.set  MODE_ABT, 0x17 /* Abort Processing memory Faults Mode*/
.set  MODE_UND, 0x1B /* Undefined Processing Undefined Instructions Mode*/
.set  MODE_SYS, 0x1F /* System Running Priviledged Operating System Tasks  Mode*/
.set  I_BIT, 0x80 /* when I bit is set, IRQ is disabled (program status registers) */
.set  F_BIT, 0x40 /* when F bit is set, FIQ is disabled (program status registers) */
/* Setup a stack for each mode - note that this only sets up a usable stack for User mode.   Also each mode is setup with interrupts initially disabled. */
24
25
      ldr   r0, =_stack_end
26
      msr   CPSR_c, #MODE_UND|I_BIT|F_BIT   /* Undefined Instruction Mode  */
27
      mov   sp, r0
28
      sub   r0, r0, #UND_STACK_SIZE
29
      msr   CPSR_c, #MODE_ABT|I_BIT|F_BIT  /* Abort Mode */
30
      mov   sp, r0
31
      sub   r0, r0, #ABT_STACK_SIZE
32
      msr   CPSR_c, #MODE_FIQ|I_BIT|F_BIT   /* FIQ Mode */
33
      mov   sp, r0
34
     sub   r0, r0, #FIQ_STACK_SIZE
35
      msr   CPSR_c, #MODE_IRQ|I_BIT|F_BIT   /* IRQ Mode */
36
      mov   sp, r0
37
      sub   r0, r0, #IRQ_STACK_SIZE
38
      msr   CPSR_c, #MODE_SVC|I_BIT|F_BIT  /* Supervisor Mode */
39
      mov   sp, r0
40
      sub   r0, r0, #SVC_STACK_SIZE
41
      msr   CPSR_c, #MODE_SYS|F_BIT  /* User Mode */
42
      mov   sp, r0
Problem ist nun: wenn mein Interrupt kommt bleibt der µC stehen
die Interrupt-Routine wird nicht ausgeführt.
Auf VICVectAddr23 steht 0x01B0, genau an dieser Speicheradresse befindet
sich laut Mapfile die Routine.
ich denke nun das ich mit den Bit's im CPSR irgend was falsch mache.
und noch eine Frage: wenn ein Interrupt am ARM anleigt wechselt er dann
in den IRQ-Mode? und such sich die entsprechende Adresse der
Interruproutien selber aus dem register?
Sollte der ARM lieber in einem anderem Modus laufen? momentan ist der
System mode eingestellt.
hoffe auf eure Hilfe ich bin am verzweifeln!!!
von Microman (Gast)
poste doch mal dein komplettes Startupfile, damit man sehen kann wie es
bei einem IRQ darin abläuft und ob die Adresse auch aus dem VICVectAddr
abgeholt und angesprungen wird. Es ist wichtig was an der Stelle der
IRQ-Exception steht.
Gruß Microman
OK hier der Startupcode:
/* Stack Sizes */
.set  UND_STACK_SIZE, 0x00000080    /* stack for "undefined instruction" interrupts is 4 bytes  */
.set  ABT_STACK_SIZE, 0x00000080    /* stack for "abort" interrupts is 4 bytes                  */
.set  FIQ_STACK_SIZE, 0x00000080    /* stack for "FIQ" interrupts  is 4 bytes               */
.set  IRQ_STACK_SIZE, 0X00000200    /* stack for "IRQ" normal interrupts is 4 bytes          */
.set  SVC_STACK_SIZE, 0x00000080    /* stack for "SVC" supervisor mode is 4 bytes          */
.set  MODE_SVC, 0x13                /* Supervisor Processing Software Interrupts Mode       */
.set  MODE_ABT, 0x17                /* Abort Processing memory Faults Mode             */
.set  MODE_UND, 0x1B                /* Undefined Processing Undefined Instructions Mode     */
.set  MODE_SYS, 0x1F                /* System Running Priviledged Operating System Tasks  Mode  */
.text
.arm
.global  Reset_Handler
24
.global _startup
25
.func   _startup
26
27
.section .startup, "ax"
28
29
_startup:
30
31
# Exception Vectors
32
33
_vectors:       ldr     PC, Reset_Addr
34
                ldr     PC, Undef_Addr
35
                ldr     PC, SWI_Addr
36
                ldr     PC, PAbt_Addr
37
                ldr     PC, DAbt_Addr
38
                nop              /* Reserved Vector (holds Philips ISP checksum) */
39
                //ldr     PC, [PC,#-0xFF0]  /* see page 71 of "Insiders Guide to the Philips ARM7-Based Microcontrollers" by Trevor Martin  */
40
                ldr     PC, [PC, #-0x0120]  // Vector from VicVectAddr
41
                ldr     PC, FIQ_Addr
42
43
Reset_Addr:     .word   Reset_Handler    /* defined in this module below  */
44
Undef_Addr:     .word   UNDEF_Routine    /* defined in main.c  */
45
SWI_Addr:       .word   SWI_Routine      /* defined in main.c  */
46
PAbt_Addr:      .word   UNDEF_Routine    /* defined in main.c  */
47
DAbt_Addr:      .word   UNDEF_Routine    /* defined in main.c  */
48
IRQ_Addr:       .word   IRQ_Routine      /* defined in main.c  */
49
FIQ_Addr:       .word   FIQ_Routine      /* defined in main.c  */
50
                .word   0          /* rounds the vectors and ISR addresses to 64 bytes total  */
51
52
# Reset Handler
53
54
Reset_Handler:
55
56
        .extern TargetResetInit
57
                 ldr     SP, =_stack_end    @ temporary stack at Stack_Top
58
                 LDR R0, =TargetResetInit
59
                 MOV LR, PC
60
                 BX R0
61
62
63
64
65
66
          ldr   r0, =_stack_end
67
//Enter Undefined Instruction Mode and set its Stack Pointer
68
69
          mov   sp, r0
70
71
72
//Enter Abort Mode and set its Stack Pointer
73
74
          mov   sp, r0
75
76
77
//Enter FIQ Mode and set its Stack Pointer
78
79
          mov   sp, r0
80
81
82
//Enter IRQ Mode and set its Stack Pointer
83
84
          mov   sp, r0
85
86
87
//Enter Supervisor Mode and set its Stack Pointer
88
89
          mov   sp, r0
90
          SUB   sl, sp, #SVC_STACK_SIZE
91
          //sub   r0, r0, #SVC_STACK_SIZE
92
93
//Enter User Mode and set its Stack Pointer
94
        //  msr   CPSR_c, #MODE_SYS|I_BIT|F_BIT
95
        //  mov   sp, r0
96
97
98
// copy .data section (Copy from ROM to RAM)
99
                ldr     R1, =_etext
100
                ldr     R2, =_data
101
                ldr     R3, =_edata
102
LoopRel:       cmp     R2, R3
103
                ldrlo   R0, [R1], #4
104
                strlo   R0, [R2], #4
105
                blo     LoopRel
106
107
// Clear .bss section (Zero init)
108
                mov     R0, #0
109
                ldr     R1, =_bss_start
110
                ldr     R2, =_bss_end
111
LoopZI:      cmp     R1, R2
112
                strlo   R0, [R1], #4
113
                blo     LoopZI
114
115
        /* Enter the C code  */
116
                b       main
117
.endfunc
118
.end
Die I-Bit’s lasen ich damit es keine Probleme bei der Initialisierung
gibt. In meiner Main-Funktion enable ich dann die Interrupts über
Assembler:
#define IRQ_MASK 0x00000080
static inline unsigned asm_get_cpsr(void)
  unsigned long retval;
  asm volatile (" mrs  %0, cpsr" : "=r" (retval) : /* no inputs */  );
  return retval;
static inline void asm_set_cpsr(unsigned val)
  asm volatile (" msr  cpsr, %0" : /* no outputs */ : "r" (val)  );
unsigned enableIRQ(void)
  unsigned _cpsr;
  _cpsr = asm_get_cpsr();
  asm_set_cpsr(_cpsr & ~IRQ_MASK);
  return _cpsr;
Der Interrupt am ARM-Kern bewirkt auch das er zum richtigen Exception
Vector an Stelle 0x0018 springt, also zu der Zeile:
"ldr     PC, [PC, #-0x0120]  "ab hier denk ich läuft es schief.
Ziel ist ja dem Kern die Adresse der Interrupt-Routine mitzuteilen die
im VicVectAddr (0xFFFFFF00) steht. Die Aktion [PC, #-0x0120] springt
aber meiner Meinung falsch oder?
PC ist an dieser Stelle 0x18(befehlsanfang)+0x02 also 0x20
0x20-0x0120 ist bei mir 0xFFFFFEFF müsste man nicht 0x011F abziehen?
0x20-0x011F = 0xFFFFFF00
PS:
meine Interrupt-Routine habe ich so deklariert:
void CAN_Handler(void)
return;
void CAN_Handler(void)  __attribute__ ((interrupt ("IRQ")));
VICVectAddr23 = (unsigned long) CAN_Handler
und danke für den Einsatz!
Zusatz:
laut Disassembly versteht der gcc Assambler anscheinend die Zeile
PC, [PC, #-0x0120] nicht! Allerdingst macht mein Debugger auch Blödsinn
wenn er asm-befegle bekommt
von Wilhelm F. (Gast)
@Steffen H.:
Hab mir mal das UM zum LPC2378 geladen. Seltsam, bei NXP kann ich es
nicht herunter laden, sondern bei Keil.
VICAddress ist 0xFFFF FF00. Da im ARM-Mode, muß die Adresse von
0x18+8=0x20 aus um 0x120 zurück gerechnet werden.
Der Befehl ldr PC, [PC, #-0x0120] spricht generell einen 4k Addressraum
an, sieht damit korrekt aus.
Ich hoffe, du hast generell aber das richtige Startup-File, und nicht zu
viel darin manipuliert (weil da auch die deaktivierte Zeile eines
anderen Controllers mit anderem VIC-Vektor drin ist).
War da nicht noch was mit dem Default-Vektor???
wie meinst du das mit 0x18+8=0x20?
steht die 8 für 0x08 also für 8 Byte?
Wie du sagts sieht alles korrekt aus, aber wenn der µC in den IRQ-mode
geht springt er noch richtig zum Exception Vector aber von da aus macht
er nur noch Mist.
Weis auch nicht wie mir ein Default-Vektor weiterhelfen könnt.
@Steffen H.:
Ja, das scheint auch richtig so.
>IRQ-mode geht springt er noch richtig zum Exception Vector aber
>von da aus macht er nur noch Mist.
An dieser Stelle soll das Register PC mit dem Inhalt der VICAddress
geladen werden. In deinem Fall sollte da der Inhalt von VICVectAddr23
(CAN_Handler) drin stehen.
Hat schon jemals ein anderer IRQ mal funktioniert?
OK, habs schon gesehen, im LPC23xx gibt es wohl keinen nicht
vektorisierten IRQ. Hat sich damit erledigt.
Ganz oben fand ich noch:
Ist das so in Ordnung?
Hast du das richtige Registerfile (z.B. LPC2378.h) eingebunden?
Nicht, das die Registeradressen total nicht stimmen!
Im User Manual LPC2378 fand ich kein Register VICVectCntl23 !
