Forum: FPGA, VHDL & Co. Signal übergabe geht nicht
von Reni (Gast)
ich baue gerade an einem Modul um mehrere 74HC595 zu bespielen. Jedoch
verstehe ich nicht. WARUM das :
led1DS<= PIN_RAMDAT(bitcounter-1); nicht geht.
Ich habe das Modul stark abgespeckt um das Prinzip zu testen. Jedoch
ohne Erfolg. Warum geht es nicht, hat jemand einen Ansatz?
Danke
------------ CODE ---------
entity ic74hc595 is
Generic  (
              Laenge               : integer   :=   8;        -- Anzahl
der zu übertragenden Bits
              Module         : integer   :=   10       -- N-1 Module
  port(   PIN_CLKIN        : in std_logic;
      PIN_RESET        : in std_logic;
      PIN_RAMADR        : out std_logic_vector(7 downto 0);
      PIN_RAMDAT        : in std_logic_vector(7 downto 0);      --
Dateneingang
      PIN_RAMRD        : out std_logic;
      -- ZEILEN
      PIN_ZeilenCLKOUT    : out std_logic;
      PIN_ZeilenDATAOUT    : out std_logic;
      PIN_ZeilenLATCH      : out std_logic;
      -- Farben
      PIN_LedCLK        : out std_logic;
      PIN_Led1DOUT      : out std_logic;
      PIN_Led2DOUT      : out std_logic;
      PIN_LedLATCH      : out std_logic;
      PIN_LedOE        : out std_logic
end ic74hc595;
-- Architecture
architecture Behavioral of ic74hc595 is
  -- Deklarationen
  type tra_states            is (ramReadH,
                      ramReadL,
                      reset_state,
                      start_state,
                      dataout_state,
                      clkh_state,
                      clkl_state,
                      modulinc_state,
                      modulCheck_state,
                      latch_state,
                      stop_state,
                      latchen_state);
  signal tra_state          : tra_states := reset_state;
  signal tra_byte_reg          : std_logic_vector(7 downto 0);  --
Transmitt byte
  signal zeilenShift          : std_logic_vector(7 downto 0);
  signal zeilen_reg          : std_logic_vector(7 downto 0);
  signal zeilenCLK          : std_logic;
  signal zeilenDS            : std_logic;
  signal zeilenLA            : std_logic;
  signal  ledCLK            : std_logic;
  signal  led1DS             : std_logic;
  signal  led2DS             : std_logic;
  signal  ledLA             : std_logic;
  signal  ledOE             : std_logic;
  signal ramADR              : std_logic_vector(7 downto 0) := (others
=> '0');
  signal ramRD            : std_logic;
  signal bitcounter            : integer range 0 to Laenge;  -- wenn
bitcounter = Laenge --> alle Bits uebertragen
  signal modulcounter            : integer range 0 to Module;
begin
  Transmitter : process(PIN_CLKIN,PIN_RESET)
  begin
      if(PIN_RESET='1')then
      tra_state<=reset_state;
    elsif rising_edge(PIN_CLKIN) then
      case tra_state is
        -- Reset State
        -- Zurücksetzen aller Werte
        when reset_state =>
              tra_state<= ramReadH;
              zeilen_reg  <= "00000001";
              ramRD <='0';
              modulcounter<=0;
              ramADR<= (others => '0');
              bitcounter <= Laenge;
        -- RAM ReadH/L
        -- Lesen des Wertes an der Adresse ramADR
        when ramReadH =>
            ramRD<='1';
            tra_state<= ramReadL;
        when ramReadL =>
            ramRD<='0';
            ramADR<=ramADR+1;
            tra_state<= start_state;
        -- start State
        -- Zurücksetzen der Einspeiswerte
        when start_state =>
          tra_byte_reg <= PIN_RAMDAT(7 downto 0);
          tra_state <= dataout_state;
        when dataout_state =>
          -- LEDS
          ledCLK<='0';
          ledLA<='0';
          zeilenCLK<='0';
          zeilenLA<='0';
          led2DS<='0';
          -- Zeilen
          if(modulcounter+1=Module) then
            zeilenDS<=zeilen_reg(bitcounter-1);
          end if;
          tra_state <= clkh_state;
        -- CLK High
        when clkh_state =>
           ledCLK<='1';
           tra_state <= clkl_state;
           bitcounter<=bitcounter-1;
          -- Zeilen
            zeilenCLK<='1';
          end if;
        -- CLK LOW
        when clkl_state =>
           ledCLK<='0';
           zeilenCLK <='0';
           if(bitcounter=0) then
            tra_state<= modulinc_state;
           else
            tra_state<= clkh_state;
           end if;
          -- Zeilen
            zeilenCLK<='0';
          end if;
        -- ModulInc
        when modulinc_state =>
        null;
        when others =>
        null;
      end case;
    end if;
  end process;
  PIN_RAMADR      <= ramADR;
  PIN_RAMRD      <= ramRD;
  PIN_ZeilenCLKOUT   <=  zeilenCLK;
  PIN_ZeilenDATAOUT  <=  zeilenDS;
  PIN_ZeilenLATCH   <=  zeilenLA;
  PIN_LedCLK      <=  ledCLK;
  PIN_Led1DOUT    <=  led1DS;
  PIN_Led2DOUT    <=  led2DS;
  PIN_LedLATCH    <=  ledLA;
  PIN_LedOE      <=  ledOE;
end Behavioral;
von Reni (Gast)
ok ich habes ...
einfach flasches State gewählt -.-
