1 | /****************************************************************************/
2 | /* */
3 | /* Programm LED und Taster aktiv high */
4 | /* */
5 | /****************************************************************************/
6 |
7 | #ifndef F_CPU
8 | #define F_CPU 8000000 // processor clock frequency 8Mhz
9 | #warning kein F_CPU definiert
10 | #endif
11 |
12 | #include <stdint.h>
13 | #include <avr/io.h>
14 | #include <avr/interrupt.h>
15 | #include <inttypes.h>
16 |
17 | #define LED PB1 //Pin der LED
18 | #define PIN_Taster PINB
19 | #define Taster PB0
20 |
21 | // ----------------------------------------------------------------------------
22 | // Funktionsdeklarationen
23 | // ----------------------------------------------------------------------------
24 | void init(void);
25 | uint8_t get_key_press( uint8_t key_mask );
26 |
27 |
28 | // ----------------------------------------------------------------------------
29 | // globale Variablen für Interrupts (volatile)
30 | // ----------------------------------------------------------------------------
31 | volatile uint8_t key_state; // debounced and inverted key state:
32 | // bit = 1: key pressed
33 | volatile uint8_t key_press; // key press detect
34 | volatile unsigned short millisekunden = 0;
35 | volatile unsigned short entprellzeit = 0;
36 |
37 |
38 |
39 | //Timer2 Comapre Match Interrupt CTC
40 | ISR(TIMER2_COMP_vect) // every 1ms
41 | {
42 | millisekunden++; // wird für späteres pollen benötigt
43 | entprellzeit++;
44 | if (entprellzeit == 10){ // every 10ms
45 | static uint8_t ct0, ct1;
46 | uint8_t i;
47 |
48 | entprellzeit = 0; // Entprellzeit wieder zurücksetzen
49 |
50 | i = key_state ^ PIN_Taster; // key changed ?
51 | ct0 = ~( ct0 & i ); // reset or count ct0
52 | ct1 = ct0 ^ (ct1 & i); // reset or count ct1
53 | i &= ct0 & ct1; // count until roll over ?
54 | key_state ^= i; // then toggle debounced state
55 | key_press |= key_state & i; // 0->1: key press detect
56 |
57 | }
58 | }
59 |
60 | //Das Hauptprogramm
61 | int main()
62 | {
63 |
64 | TCCR2 = (1<<CS22) | (1 << WGM21); // Prescaler 64, CTC Clear on Compare Match
65 | OCR2 = 124; // jede 1ms tritt ein Compare Match Interrupt auf
66 | TIMSK |= (1<<OCIE2); // Timer Compare Match Enable
67 |
68 | DDRB = 0x00; //Datenrichtungsregister zunächst alle Eingang
69 | DDRB |= (1 << DDB1); //PB1 als Ausgang schalten für LED
70 | PORTB = (1 << PB1); //LED aus
71 |
72 | sei();
73 |
74 | while(1)
75 |
76 |
77 | //Zustand des Tasters abfragen mit Entprellfunktion
78 | if (get_key_press( 1<<Taster )){
79 |
80 | if (!(PINB & (1<<LED))){ //LED war an
81 | PORTB |= (1 << LED); //LED ausschalten
82 |
83 | }
84 |
85 | else {
86 | PORTB &=~ (1 << LED); //LED anschalten
87 | }
88 | }
89 |
90 | }
91 |
92 | // Funktionen
93 | ///////////////////////////////////////////////////////////////////
94 | // by Peter Danegger
95 | // check if a key has been pressed. Each pressed key is reported
96 | // only once
97 | ///////////////////////////////////////////////////////////////////
98 | uint8_t get_key_press( uint8_t key_mask )
99 | {
100 | cli(); // read and clear atomic !
101 | key_mask &= key_press; // read key(s)
102 | key_press ^= key_mask; // clear key(s)
103 | sei();
104 | return key_mask;
105 | }
