1 | /***********************************************************************/
2 | /* This file is part of the uVision/ARM development tools */
3 | /* Copyright KEIL ELEKTRONIK GmbH 2002-2005 */
4 | /***********************************************************************/
5 | /* */
6 | /* STARTUP.S: Startup file for Philips LPC2000 device series */
7 | /* */
8 | /***********************************************************************/
9 |
10 | /*
11 | This file has been heavily modified for the GNU-Toolchain by:
12 | Martin Thomas, Kaiserslautern, Germany
13 | <mthomas@rhrk.uni-kl.de>
14 | http://www.siwawi.arubi.uni-kl.de/avr_projects
15 |
16 | Most of the original Keil-code is still in this file but
17 | disabled by "#if 0". Some but not all of my modifications
18 | are marked with mthomas/mt. "Diff" against the orignal
19 | code to see everything I have changed.
20 |
21 | If it does not work for you: don't blame Keil or Philips.
22 | */
23 |
24 | /* mthomas: I have not tested if the Keil Configuration Wizard
25 | can still handle this file.
26 | */
27 |
28 | /*
29 | //*** <<< Use Configuration Wizard in Context Menu >>> ***
30 | */
31 |
32 |
33 | /*
34 | mthomas: The explanation below is still kept as a reference.
35 | In this port of the code the RAM/ROM_MODE and the
36 | remapping-setting is selescted by definitions passed
37 | to the preprocessor from the makefile.
38 |
39 | * The STARTUP.S code is executed after CPU Reset. This file may be
40 | * translated with the following SET symbols. In uVision these SET
41 | * symbols are entered under Options - ASM - Set.
42 | *
43 | * REMAP: when set the startup code initializes the register MEMMAP
44 | * which overwrites the settings of the CPU configuration pins. The
45 | * startup and interrupt vectors are remapped from:
46 | * 0x00000000 default setting (not remapped)
47 | * 0x80000000 when EXTMEM_MODE is used
48 | * 0x40000000 when RAM_MODE is used
49 | *
50 | * EXTMEM_MODE: when set the device is configured for code execution
51 | * from external memory starting at address 0x80000000. The startup
52 | * vectors are located to 0x80000000.
53 | *
54 | * RAM_MODE: when set the device is configured for code execution
55 | * from on-chip RAM starting at address 0x40000000. The startup
56 | * vectors are located to 0x40000000.
57 | */
58 |
59 | /* mt: Map Preprocessor definitions to assembler definitions/symbols */
60 |
61 | .set EXTMEM_MODE, 0
62 |
63 | #if defined(ROM_RUN)
64 | .set RAM_MODE, 0
65 | #if defined(VECTORS_IN_RAM)
66 | .set REMAP, 1
67 | .set VECTREMAPPED, 1
68 | #else
69 | .set REMAP, 0
70 | .set VECTREMAPPED, 0
71 | #endif
72 | #elif defined(RAM_RUN)
73 | .set RAM_MODE, 1
74 | .set REMAP, 1
75 | .set VECTREMAPPED, 0
76 | #else
77 | #error "define ROM_MODE or RAM_MODE in makefile"
78 | #endif
79 |
80 |
81 |
82 | .if (RAM_MODE)
83 | .print "RAM_MODE enabled"
84 | .else
85 | .print "ROM_MODE enabled"
86 | .endif
87 |
88 | .if (REMAP)
89 | .print "remapping enabled"
90 | .endif
91 |
92 | .if (VECTREMAPPED)
93 | .print "Vectors at start of RAM"
94 | .else
95 | .print "Vectors at start of Code"
96 | .endif
97 |
98 |
99 | // Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs
100 |
101 | .set Mode_USR, 0x10
102 | .set Mode_FIQ, 0x11
103 | .set Mode_IRQ, 0x12
104 | .set Mode_SVC, 0x13
105 | .set Mode_ABT, 0x17
106 | .set Mode_UND, 0x1B
107 | .set Mode_SYS, 0x1F
108 |
109 | .set I_Bit, 0x80 /* when I bit is set, IRQ is disabled */
110 | .set F_Bit, 0x40 /* when F bit is set, FIQ is disabled */
111 |
112 |
113 | /*
114 | // <h> Stack Configuration (Stack Sizes in Bytes)
115 | // <o0> Undefined Mode <0x0-0xFFFFFFFF:4>
116 | // <o1> Supervisor Mode <0x0-0xFFFFFFFF:4>
117 | // <o2> Abort Mode <0x0-0xFFFFFFFF:4>
118 | // <o3> Fast Interrupt Mode <0x0-0xFFFFFFFF:4>
119 | // <o4> Interrupt Mode <0x0-0xFFFFFFFF:4>
120 | // <o5> User/System Mode <0x0-0xFFFFFFFF:4>
121 | // </h>
122 | */
123 | .set UND_Stack_Size, 0x00000080
124 | .set SVC_Stack_Size, 0x00000080
125 | .set ABT_Stack_Size, 0x00000080
126 | .set FIQ_Stack_Size, 0x00000080
127 | .set IRQ_Stack_Size, 0x00000200
128 | .set USR_Stack_Size, 0x00002000
129 |
130 | #if 0
131 | AREA STACK, DATA, READWRITE, ALIGN=2
132 | DS (USR_Stack_Size+3)&~3 ; Stack for User/System Mode
133 | DS (SVC_Stack_Size+3)&~3 ; Stack for Supervisor Mode
134 | DS (IRQ_Stack_Size+3)&~3 ; Stack for Interrupt Mode
135 | DS (FIQ_Stack_Size+3)&~3 ; Stack for Fast Interrupt Mode
136 | DS (ABT_Stack_Size+3)&~3 ; Stack for Abort Mode
137 | DS (UND_Stack_Size+3)&~3 ; Stack for Undefined Mode
138 | #endif
139 |
140 | .arm
141 | .section .stack, "w"
142 | .align 4
143 | .space (USR_Stack_Size+3)&~3 // Stack for User/System Mode
144 | .space (SVC_Stack_Size+3)&~3 // Stack for Supervisor Mode
145 | .space (IRQ_Stack_Size+3)&~3 // Stack for Interrupt Mode
146 | .space (FIQ_Stack_Size+3)&~3 // Stack for Fast Interrupt Mode
147 | .space (ABT_Stack_Size+3)&~3 // Stack for Abort Mode
148 | .space (UND_Stack_Size+3)&~3 // Stack for Undefined Mode
149 | Top_Stack:
150 |
151 |
152 | // VPBDIV definitions
153 | .set VPBDIV, 0xE01FC100 /* VPBDIV Address */
154 |
155 | /*
156 | // <e> VPBDIV Setup
157 | // <i> Peripheral Bus Clock Rate
158 | // <o1.0..1> VPBDIV: VPB Clock
159 | // <0=> VPB Clock = CPU Clock / 4
160 | // <1=> VPB Clock = CPU Clock
161 | // <2=> VPB Clock = CPU Clock / 2
162 | // <o1.4..5> XCLKDIV: XCLK Pin
163 | // <0=> XCLK Pin = CPU Clock / 4
164 | // <1=> XCLK Pin = CPU Clock
165 | // <2=> XCLK Pin = CPU Clock / 2
166 | // </e>
167 | */
168 | .set VPBDIV_SETUP, 1
169 | .set VPBDIV_Val, 0x00000000
170 |
171 |
172 | // Phase Locked Loop (PLL) definitions
173 | .set PLL_BASE, 0xE01FC080 /* PLL Base Address */
174 | .set PLLCON_OFS, 0x00 /* PLL Control Offset*/
175 | .set PLLCFG_OFS, 0x04 /* PLL Configuration Offset */
176 | .set PLLSTAT_OFS, 0x08 /* PLL Status Offset */
177 | .set PLLFEED_OFS, 0x0C /* PLL Feed Offset */
178 | .set PLLCON_PLLE, (1<<0) /* PLL Enable */
179 | .set PLLCON_PLLC, (1<<1) /* PLL Connect */
180 | .set PLLCFG_MSEL, (0x1F<<0) /* PLL Multiplier */
181 | .set PLLCFG_PSEL, (0x03<<5) /* PLL Divider */
182 | .set PLLSTAT_PLOCK, (1<<10) /* PLL Lock Status */
183 |
184 | /*
185 | // <e> PLL Setup
186 | // <i> Phase Locked Loop
187 | // <i> CCLK - Processor Clock
188 | // <i> Fcco - PLL Oscillator
189 | // <o1.0..4> MSEL: PLL Multiplier Selection
190 | // <1-32><#-1>
191 | // <i> PLL Multiplier "M" Value
192 | // <i> CCLK = M * Fosc
193 | // <o1.5..6> PSEL: PLL Divider Selection
194 | // <0=> 1 <1=> 2 <2=> 4 <3=> 8
195 | // <i> PLL Divider "P" Value
196 | // <i> Fcco = CCLK * 2 * P
197 | // <i> 156MHz <= Fcco <= 320MHz
198 | // </e>
199 | */
200 | .set PLL_SETUP, 1
201 | .set PLLCFG_Val, 0x00000024
202 |
203 |
204 | // Memory Accelerator Module (MAM) definitions
205 | .set MAM_BASE, 0xE01FC000 /* MAM Base Address */
206 | .set MAMCR_OFS, 0x00 /* MAM Control Offset*/
207 | .set MAMTIM_OFS, 0x04 /* MAM Timing Offset */
208 |
209 | /*
210 | // <e> MAM Setup
211 | // <i> Memory Accelerator Module
212 | // <o1.0..1> MAM Control
213 | // <0=> Disabled
214 | // <1=> Partially Enabled
215 | // <2=> Fully Enabled
216 | // <i> Mode
217 | // <o2.0..2> MAM Timing
218 | // <0=> Reserved <1=> 1 <2=> 2 <3=> 3
219 | // <4=> 4 <5=> 5 <6=> 6 <7=> 7
220 | // <i> Fetch Cycles
221 | // </e>
222 | */
223 | .set MAM_SETUP, 1
224 | .set MAMCR_Val, 0x00000002
225 | .set MAMTIM_Val, 0x00000004
226 |
227 |
228 | // Starupt Code must be linked first at Address at which it expects to run.
229 |
230 | .if (EXTMEM_MODE)
231 | .set CODE_BASE, 0x80000000
232 | .elseif (RAM_MODE)
233 | .set CODE_BASE, 0x40000000
234 | .else
235 | .set CODE_BASE, 0x00000000
236 | .endif
237 |
238 | #if 0
239 | AREA STARTUPCODE, CODE, AT CODE_BASE // READONLY, ALIGN=4
240 | PUBLIC __startup
241 |
242 | EXTERN CODE32 (?C?INIT)
243 |
244 | __startup PROC CODE32
245 |
246 | // Pre-defined interrupt handlers that may be directly
247 | // overwritten by C interrupt functions
248 | EXTERN CODE32 (Undef_Handler?A)
249 | EXTERN CODE32 (SWI_Handler?A)
250 | EXTERN CODE32 (PAbt_Handler?A)
251 | EXTERN CODE32 (DAbt_Handler?A)
252 | EXTERN CODE32 (IRQ_Handler?A)
253 | EXTERN CODE32 (FIQ_Handler?A)
254 | #endif
255 |
256 | .text
257 | .arm
258 |
259 | .if (VECTREMAPPED)
260 | .print "Vectors in section .vectmapped -> .data"
261 | .section .vectmapped, "ax"
262 | .else
263 | .print "Vectors in section .vectorg -> .text"
264 | .section .vectorg, "ax"
265 | .endif
266 |
267 | // Pre-defined interrupt handlers that may be directly
268 | // overwritten by C interrupt functions
269 | .extern Undef_Handler
270 | .extern SWI_Handler
271 | .extern PAbt_Handler
272 | .extern DAbt_Handler
273 | .extern IRQ_Handler
274 | .extern FIQ_Handler
275 |
276 |
277 | // Exception Vectors
278 | // Mapped to Address 0.
279 | // Absolute addressing mode must be used.
280 |
281 | __Vectors: LDR PC,Reset_Addr
282 | LDR PC,Undef_Addr
283 | LDR PC,SWI_Addr
284 | LDR PC,PAbt_Addr
285 | LDR PC,DAbt_Addr
286 | NOP /* Reserved Vector */
287 | // LDR PC,IRQ_Addr
288 | // LDR PC,[PC, #-0x0FF0] /* Vector from VicVectAddr */
289 | LDR PC,IRQ_Wrapper_Addr
290 | LDR PC,FIQ_Addr
291 |
292 | Reset_Addr: .word Reset_Handler
293 | Undef_Addr: .word Undef_Handler
294 | // SWI_Addr: .word SWI_Handler
295 | // SWI_Wrapper_Addr: .word SWI_Wrapper
296 | SWI_Addr: .word SoftwareInterrupt /* in swi_handler.S */
297 | PAbt_Addr: .word PAbt_Handler
298 | DAbt_Addr: .word DAbt_Handler
299 | .word 0 /* Reserved Address */
300 | // IRQ_Addr: .word __IRQ_Handler
301 | IRQ_Wrapper_Addr: .word __IRQ_Wrapper
302 | FIQ_Addr: .word FIQ_Handler
303 |
304 | Undef_Handler: B Undef_Handler
305 | /* SWI_Handler: B SWI_Handler */
306 | PAbt_Handler: B PAbt_Handler
307 | DAbt_Handler: B DAbt_Handler
308 | /* IRQ_Handler: B IRQ_Handler */
309 | FIQ_Handler: B FIQ_Handler
310 |
311 | .size __Vectors, . - __Vectors
312 |
313 |
314 |
315 | .arm
316 | .section .init, "ax"
317 |
318 | .if (VECTREMAPPED)
319 | /* mthomas: Dummy used during startup when remapping is enabled
320 | - mind the nops since the flash-utility will overwrite the
321 | "reserved vector"-address with the checksum */
322 | B Reset_Handler
323 | NOP
324 | NOP
325 | NOP
326 | NOP
327 | NOP /* Reserved Address */
328 | NOP
329 | NOP
330 | .endif
331 |
332 | .arm
333 | .section .init, "ax"
334 | .global __startup
335 | .func __startup
336 | __startup:
337 |
338 | Reset_Handler:
339 |
340 | // .if (VPBDIV_SETUP != 0)
341 | .if (VPBDIV_SETUP)
342 | LDR R0, =VPBDIV
343 | LDR R1, =VPBDIV_Val
344 | STR R1, [R0]
345 | .endif
346 |
347 |
348 | //.if (PLL_SETUP != 0)
349 | // .if (PLL_SETUP)
350 | LDR R0, =PLL_BASE
351 | MOV R1, #0xAA
352 | MOV R2, #0x55
353 |
354 | // Configure and Enable PLL
355 | MOV R3, #PLLCFG_Val
356 | STR R3, [R0, #PLLCFG_OFS]
357 | MOV R3, #PLLCON_PLLE
358 | STR R3, [R0, #PLLCON_OFS]
359 | STR R1, [R0, #PLLFEED_OFS]
360 | STR R2, [R0, #PLLFEED_OFS]
361 |
362 | // Wait until PLL Locked
363 | //PLL_Loop: LDR R3, [R0, #PLLSTAT_OFS]
364 | // ANDS R3, R3, #PLLSTAT_PLOCK
365 | // BEQ PLL_Loop
366 |
367 | // Switch to PLL Clock
368 | MOV R3, #(PLLCON_PLLE | PLLCON_PLLC)
369 | STR R3, [R0, #PLLCON_OFS]
370 | STR R1, [R0, #PLLFEED_OFS]
371 | STR R2, [R0, #PLLFEED_OFS]
372 | // .endif
373 |
374 |
375 | //.if (MAM_SETUP != 0)
376 | .if (MAM_SETUP)
377 | LDR R0, =MAM_BASE
378 | MOV R1, #MAMTIM_Val
379 | STR R1, [R0, #MAMTIM_OFS]
380 | MOV R1, #MAMCR_Val
381 | STR R1, [R0, #MAMCR_OFS]
382 | .endif
383 |
384 |
385 | // Memory Mapping
386 | .set MEMMAP, 0xE01FC040 /* Memory Mapping Control */
387 |
388 | .if (REMAP)
389 | LDR R0, =MEMMAP
390 | .if (EXTMEM_MODE)
391 | MOV R1, #3
392 | .elseif (RAM_MODE) || (VECTREMAPPED)
393 | .print "MEMMAP to 2 on init"
394 | MOV R1, #2
395 | .else
396 | MOV R1, #1
397 | .endif
398 | STR R1, [R0]
399 | .endif
400 |
401 | // Setup Stack for each mode
402 | LDR R0, =Top_Stack
403 |
404 | // Enter Undefined Instruction Mode and set its Stack Pointer
405 | MSR CPSR_c, #Mode_UND|I_Bit|F_Bit
406 | MOV SP, R0
407 | SUB R0, R0, #UND_Stack_Size
408 |
409 | // Enter Abort Mode and set its Stack Pointer
410 | MSR CPSR_c, #Mode_ABT|I_Bit|F_Bit
411 | MOV SP, R0
412 | SUB R0, R0, #ABT_Stack_Size
413 |
414 | // Enter FIQ Mode and set its Stack Pointer
415 | MSR CPSR_c, #Mode_FIQ|I_Bit|F_Bit
416 | MOV SP, R0
417 | SUB R0, R0, #FIQ_Stack_Size
418 |
419 | // Enter IRQ Mode and set its Stack Pointer
420 | MSR CPSR_c, #Mode_IRQ|I_Bit|F_Bit
421 | MOV SP, R0
422 | SUB R0, R0, #IRQ_Stack_Size
423 |
424 | // Enter Supervisor Mode and set its Stack Pointer
425 | MSR CPSR_c, #Mode_SVC|I_Bit|F_Bit
426 | MOV SP, R0
427 | SUB R0, R0, #SVC_Stack_Size
428 |
429 | // Enter User Mode and set its Stack Pointer
430 | MSR CPSR_c, #Mode_USR /* Interrupts enabled */
431 | // MSR CPSR_c, #Mode_USR|I_Bit|F_Bit /* Interrupts disabled */
432 | MOV SP, R0 #######################################
433 | #######################################
434 |
435 | .if (RAM_MODE==0)
436 | /* Relocate .data section (Copy from ROM to RAM) */
437 | LDR R1, =_etext
438 | LDR R2, =_data
439 | LDR R3, =_edata
440 | CMP R2, R3
441 | BEQ DataIsEmpty
442 | LoopRel: CMP R2, R3
443 | LDRLO R0, [R1], #4
444 | STRLO R0, [R2], #4
445 | BLO LoopRel
446 | DataIsEmpty:
447 | .endif
448 |
449 | /* Clear .bss section (Zero init) */
450 | MOV R0, #0
451 | LDR R1, =__bss_start__
452 | LDR R2, =__bss_end__
453 | CMP R1,R2
454 | BEQ BSSIsEmpty
455 | LoopZI: CMP R1, R2
456 | STRLO R0, [R1], #4
457 | BLO LoopZI
458 | BSSIsEmpty:
459 |
460 |
461 | // call C++ constructors of global objects
462 | LDR r0, =__ctors_start__
463 | LDR r1, =__ctors_end__
464 | ctor_loop:
465 | CMP r0, r1
466 | BEQ ctor_end
467 | LDR r2, [r0], #4
468 | STMFD sp!, {r0-r1}
469 | MOV lr, pc
470 | MOV pc, r2
471 | LDMFD sp!, {r0-r1}
472 | B ctor_loop
473 | ctor_end:
474 |
475 | // Enter the C code
476 | //LDR R0,=INIT
477 | LDR R0,=main
478 | TST R0,#1 // Bit-0 set: main is Thumb
479 | LDREQ LR,=__exit_ARM // ARM Mode
480 | LDRNE LR,=__exit_THUMB // Thumb Mode
481 | BX R0
482 |
483 | .size __startup, . - __startup
484 | .endfunc
485 |
486 | .arm
487 | .global __exit_ARM
488 | .func __exit_ARM
489 | __exit_ARM:
490 | B __exit_ARM
491 | .size __exit_ARM, . - __exit_ARM
492 | .endfunc
493 |
494 | .thumb
495 | .global __exit_THUMB
496 | .func __exit_THUMB
497 | .thumb_func
498 | __exit_THUMB:
499 | B __exit_THUMB
500 | .size __exit_THUMB, . - __exit_THUMB
501 | .endfunc
502 |
503 |
504 | /* mthomas: the following code is inspired by various examples and
505 | documents from ARM, Atmel, Anglia Designs and others */
506 |
507 |
508 | .text
509 | .arm
510 |
511 | .if (VECTREMAPPED)
512 | .print "Handlers in section .vectmapped -> .data"
513 | .section .vectmapped, "ax"
514 | .else
515 | .print "Handlers in section .vectorg -> .code/.text"
516 | .section .vectorg, "ax"
517 | .endif
518 |
519 | .set VIC_base_addr, 0xFFFFF000
520 | .set VIC_vect_offs, 0x30
521 |
522 | .arm
523 | .global __IRQ_Wrapper
524 | .func __IRQ_Wrapper
525 | __IRQ_Wrapper:
526 | /*- Manage Exception Entry */
527 | /*- Adjust and save LR_irq in IRQ stack */
528 | sub lr, lr, #4
529 | stmfd sp!, {lr}
530 |
531 | /*- Save SPSR need to be saved for nested interrupt */
532 | mrs r14, SPSR
533 | stmfd sp!, {r14}
534 |
535 | /*- Save and r0 in IRQ stack */
536 | stmfd sp!, {r0}
537 |
538 | /*- Write in the IVR to support Protect Mode */
539 | /*- No effect in Normal Mode */
540 | /*- De-assert the NIRQ and clear the source in Protect Mode */
541 | /* R14 = LR */
542 | ldr r14, =VIC_base_addr
543 | ldr r0 , [r14, #VIC_vect_offs]
544 | /*str r14, [r14, #VIC_vect_offs]*/
545 |
546 | /*- Enable Interrupt and Switch in Supervisor Mode */
547 | msr CPSR_c, #Mode_SVC
548 |
549 | /*- Save scratch/used registers and LR in User Stack */
550 | /*stmfd sp!, { r1-r3, r12, r14}*/
551 | stmfd sp!, { r1-r12, r14 }
552 |
553 | /*- Branch to the routine pointed by the VIC-Vector-Address */
554 | mov r14, pc
555 | bx r0
556 | /*- Restore scratch/used registers and LR from User Stack*/
557 | /* ldmia sp!, { r1-r3, r12, r14} */
558 | ldmia sp!, { r1-r12, r14 }
559 |
560 | /*- Disable Interrupt and switch back in IRQ mode */
561 | msr CPSR_c, #I_Bit | Mode_IRQ
562 |
563 | #if 0
564 | /* VICVectAddr=0 is already done in the ISRs of the Philips-Examples
565 | so commented out here */
566 | /*- Mark the End of Interrupt on the VIC */
567 | ldr r14, =VIC_base_addr
568 | str r14, [r14, #VIC_vect_offs]
569 | #endif
570 |
571 | /*- Restore SPSR_irq and r0 from IRQ stack */
572 | ldmia sp!, {r0}
573 |
574 | /*- Restore SPSR_irq and r0 from IRQ stack */
575 | ldmia sp!, {r14}
576 | msr SPSR_cxsf, r14
577 |
578 | /*- Restore adjusted LR_irq from IRQ stack directly in the PC */
579 | ldmia sp!, {pc}^
580 |
581 | .size __IRQ_Wrapper, . - __IRQ_Wrapper
582 | .endfunc
583 |
584 |
585 | #if 0
586 | /* mthomas:
587 | Wrapper to call a C swi-Function declared with
588 | void SWI_Handler(int swi_num, int *regs)
589 | Inspired by Anglia Designs example
590 | -- not used here - see swi_handler.S
591 | */
592 | .arm
593 | .global __SWI_Wrapper
594 | .func __SWI_Wrapper
595 | __SWI_Wrapper: /* r0 holds swi number */
596 | STMFD sp!,{r0-r12,lr} /* Save The workspace plus the current return */
597 | /* address lr_ mode into the stack */
598 | MRS r1, spsr /* Save the spsr_mode into r1 */
599 | STMFD sp!, {r1} /* Save spsr */
600 | MOV r1, sp /* load regs */
601 | LDR r0,=SWI_Handler
602 | MOV lr, pc
603 | BX r0 /* call the C-funcktion */
604 | LDMFD sp!, {r1} /* Restore the saved spsr_mode into r1 */
605 | MSR spsr_cxsf, r1 /* Restore spsr_mode */
606 | LDMFD sp!, {r0-r12,pc} /* Return to the instruction following */
607 | /* the exception interrupt */
608 | .size __SWI_Wrapper, . - __SWI_Wrapper
609 | .endfunc
610 | #endif
611 |
612 | #if 0
613 | /* mthomas: not used here - reminder for future tests */
614 | .arm
615 | .global __IRQ_Wrapper
616 | .func __IRQ_Wrapper
617 | __IRQ_Wrapper:
618 | SUB lr, lr, #4 /* Update the link register */
619 | STMFD sp!,{r0-r12,lr} /* Save The workspace plus the current return */
620 | /* address lr_ mode into the stack */
621 | MRS r1, spsr /* Save the spsr_mode into r1 */
622 | STMFD sp!, {r1} /* Save spsr */
623 | LDR lr, =ReturnAddress /* Read the return address. */
624 | LDR r0, =VIC_base_addr /* Load VIC Base-Address */
625 | LDR r1, [r0, #VIC_vect_offs] /* Load ISR-Address from VICVectAddr */
626 | bx r1 /* Branch to the IRQ handler. */
627 | ReturnAddress:
628 | LDR r2, =VIC_base_addr /* clear Interrupt */
629 | MOV r3, #0
630 | STR R3, [R2, #VIC_vect_offs] /* by writing to VICVectAddr */
631 | LDMFD sp!, {r1} /* Restore the saved spsr_mode into r1 */
632 | MSR spsr_cxsf, r1 /* Restore spsr_mode */
633 | LDMFD sp!, {r0-r12,pc}^ /* Return to the instruction following */
634 | /* the exception interrupt */
635 | .size __IRQ_Wrapper, . - __IRQ_Wrapper
636 | .endfunc
637 | #endif
638 |
639 | .end
