1 | /* Timer von 1-999 Sekunden
2 |
3 | * 3 7-Segment LEDs werden im Multiplexbetrieb angesteuert
4 |
5 | #include <inttypes.h> // uint8_t usw.
6 | //#include <avr/io.h>
7 | #include <avr/interrupt.h> // Interrupts
8 | #include <avr/signal.h> // Interruptbehandlungsroutinen SIGNAL
9 | #include <avr/delay.h> // definiert _delay_ms und _delay_loop_2
10 | #include <avr/eeprom.h> // EEPROM Zugriffe
11 |
12 | #define delay_us(us) _delay_loop_2 (((F_CPU/4000)*us)/1000) // wartet µs
13 | #define EEPROM __attribute__ ((section (".eeprom"))) // für EEPROM-Zugriffe
14 |
15 | /*
16 | Aufbau 7-Segment
17 |
18 | // Welcher Port an welchem Segement:
19 | #define segm_a PD0
20 | #define segm_b PD1
21 | #define segm_c PD2
22 | #define segm_d PD3
23 | #define segm_e PD4
24 | #define segm_f PD5
25 | #define segm_g PD6
26 |
27 | // Welcher Port an welcher Digit:
28 | #define digit1 PC3 // Einer
29 | #define digit2 PC4 // Zehner
30 | #define digit3 PC5 // Hunderter
31 |
32 | // An welchem Port sind Taster
33 | #define btn_up PB0
34 | #define btn_down PB1
35 | #define btn_start PB2
36 |
37 | // An welchem Port hängt Relais
38 | //#define relais PD7
39 |
40 | // Ports definieren
41 | #define port_segment PORTD
42 | #define port_digit PORTC
43 | #define port_keys PORTB
44 | #define dir_segment DDRD
45 | #define dir_digit DDRC
46 | #define dir_keys DDRB
47 | #define pin_keys PINB
48 |
49 | // Definiert, welche Segmente für die einzelnen Zahlenwerte aufleuchten sollen. HIGH-Aktiv
50 | #define sign0 (1 << segm_a) | (1 << segm_b) | (1 << segm_c) | (1 << segm_d) | (1 << segm_e) | (1 << segm_f)
51 | #define sign1 (1 << segm_b) | (1 << segm_c)
52 | #define sign2 (1 << segm_a) | (1 << segm_b) | (1 << segm_g) | (1 << segm_e) | (1 << segm_d)
53 | #define sign3 (1 << segm_a) | (1 << segm_b) | (1 << segm_g) | (1 << segm_c) | (1 << segm_d)
54 | #define sign4 (1 << segm_f) | (1 << segm_g) | (1 << segm_b) | (1 << segm_c)
55 | #define sign5 (1 << segm_a) | (1 << segm_f) | (1 << segm_g) | (1 << segm_c) | (1 << segm_d)
56 | #define sign6 (1 << segm_a) | (1 << segm_f) | (1 << segm_g) | (1 << segm_e) | (1 << segm_d) | (1 << segm_c)
57 | #define sign7 (1 << segm_a) | (1 << segm_b) | (1 << segm_c)
58 | #define sign8 (1 << segm_a) | (1 << segm_b) | (1 << segm_c) | (1 << segm_d) | (1 << segm_e) | (1 << segm_f) | (1 << segm_g)
59 | #define sign9 (1 << segm_a) | (1 << segm_b) | (1 << segm_c) | (1 << segm_d) | (1 << segm_g) | (1 << segm_f)
60 |
61 | uint8_t num[] = { sign0, sign1, sign2, sign3, sign4, sign5, sign6, sign7, sign8, sign9 };
62 | uint16_t startwert EEPROM; // Speicherplatz für letzten Startwert im EEPROM
63 | volatile uint16_t display_value=0; // Startwert.
64 | volatile uint8_t run=0; // =0 Counter Stop; =1 Counter läuft
65 | volatile uint8_t relais=0; // =0 Relais off, =1 Relais on
66 | volatile uint8_t key_up=0, // Puffer für Tastendrücke
67 | key_down=0,
68 | key_start=0;
69 |
70 | /**
71 | @brief Gibt Zahlenwert auf 7 Segment Display aus
72 | @param zahl
73 | @return none
74 | */
75 | void ausgabe (uint16_t zahl)
76 | {
77 | uint16_t output = zahl;
78 | uint16_t warten = 500; // Enable Zeit für einzelnes Segment. Zeit in der LED leuchten
79 |
80 | // Hunderter-Dezimalstelle
81 | if (zahl >= 100)
82 | {
83 | port_segment = relais | num[output/100]; // Zahlenwert darstellen zzgl. Zustand für PB7
84 | port_digit = (1 << digit3); // 3. Digit HIGH
85 | delay_us(warten); // LEDs müssen gewisse Zeit leuchten
86 | port_digit = 0; // 3. Digit HIGH
87 | }
88 | output = output % 100;
89 |
90 | // Zehner-Dezimalstelle
91 | if (zahl >= 10)
92 | {
93 | port_segment = relais | num[output/10]; // Zahlenwert darstellen zzgl. Zustand für PB7
94 | port_digit = (1 << digit2); // 2. Digit HIGH
95 | delay_us(warten); // LEDs müssen gewisse Zeit leuchten
96 | port_digit = 0; // 2. Digit HIGH
97 | }
98 | output = output % 10;
99 |
100 | // einer Dezimalstelle
101 | port_segment = relais | num[output]; // Zahlenwert darstellen zzgl. Zustand für PB7
102 | port_digit = (1 << digit1); // 1. Digit HIGH
103 | delay_us(warten); // LEDs müssen gewisse Zeit leuchten
104 | port_digit = 0; // 1. Digit HIGH
105 |
106 | sei(); // Interrupts zulassen
107 | }
108 |
109 | /**
110 | @brief Interruptbehandlung für Timer zum Displayrefresh
111 | @param none
112 | @return none
113 | */
114 | SIGNAL (SIG_OVERFLOW0)
115 | {
116 | cli(); // Interrupts nicht zulassen
117 | ausgabe (display_value); // Zahl darstellen
118 | }
119 |
120 | /**
121 | @brief Interruptbehandlung für Timer zur Tastenabfrage.
122 | Für jede Taste erxistiert eine Variable, die inkrementiert wird, wenn Interrupt ausgelöst wird und Taste gedrückt ist
123 | Sind x Tastenimpulse zusammen, wird im Hauptprogramm die Taste als gedrückt angesehen
124 | @param none
125 | @return none
126 | */
127 | SIGNAL (SIG_OVERFLOW2)
128 | {
129 | cli(); // Interrupts nicht zulassen
130 |
131 | if (pin_keys & (1 << btn_up)) // Up-Taste gedrückt
132 | key_up++;
133 |
134 | if (pin_keys & (1 << btn_down)) // Down-Taste gedrückt
135 | key_down++;
136 |
137 | if (pin_keys & (1 << btn_start)) // Start-Taste gedrückt
138 | key_start++;
139 |
140 | sei(); // Interrupts zulassen
141 | }
142 |
143 | /**
144 | @brief Interruptbehandlung für Timer für Sekundentakt bei gestartetem Counter
145 | Wird jede Sekunde einmal ausgelöst und dekrementiert den Zähler
146 | @param none
147 | @return none
148 | */
149 | SIGNAL (SIG_OUTPUT_COMPARE1A)
150 | {
151 | cli(); // Interrupts nicht zulassen
152 | TCNT1H=0; // Timerstand zurücksetzen
153 | TCNT1L=0;
154 |
155 | display_value -= run;
156 | }
157 |
158 | int main(void)
159 | {
160 |
161 | dir_digit = (1 << digit1) | (1 << digit2) | (1 << digit3); // Ausgänge, für Digits
162 | dir_segment = 0xFF; // alles Ausgänge, für Segmente
163 | dir_keys &= ~(1 << btn_up) & ~(1 << btn_down) & ~(1 << btn_start); // Eingänge für Tasten
164 |
165 | // Timer für Displayrefresh
166 | // TCCR0 |= (1<<CS01); //8-Bit Timer, Timer clock = system clock/8
167 | TCCR0 |= (1<<CS01) | (1<<CS00); //8-Bit Timer, Timer clock = system clock/64
168 | // TCCR0 |= (1<<CS02); //8-Bit Timer, Timer clock = system clock/256
169 | // TCCR0 |= (1<<CS02) | (1<<CS00); //8-Bit Timer, Timer clock = system clock/1024
170 | TIFR |= (1<<TOV0); //Clear TOV0 Timer/Counter Overflow Flag. clear pending interrupts
171 | TIMSK |= (1<<TOIE0); //Enable Timer0 Overflow Interrupt
172 |
173 | // Timer für Tastenabfrage
174 | TCCR2 |= (1<<CS22) | (1<<CS20); //8-Bit Timer, Timer clock = system clock/1024
175 | TIFR |= (1<<TOV2); //Clear TOV2 Timer/Counter Overflow Flag. clear pending interrupts
176 | TIMSK |= (1<<TOIE2); //Enable Timer2 Overflow Interrupt
177 |
178 | // Timer für Sekundentakt
179 | OCR1AH = 0x1E; // 16Bit Timer Takt= 8MHz => 8.000.000/1024 = 7812,5 => 7,8125 Zählerschritte pro ms
180 | OCR1AL = 0x83; // Vergleichswert laden: 1 Sekunde
181 | TIMSK |= (1<<OCIE1A); // Interrupt wenn Timer Vergleichswert erreicht
182 |
183 | sei(); // Interrupts zulassen
184 |
185 | while (1)
186 | {
187 | if (key_up >= 50) // Up-Taste gedrückt
188 | {
189 | display_value++; // Wert +1
190 | if (display_value > 999) // Wenn Überlauf => Wert=0
191 | display_value = 1;
192 | key_up = 0; // Tastencounter leeren
193 | }
194 | if (key_down >= 50) // Down-Taste gedrückt
195 | {
196 | if (display_value <= 1) // Wenn Unterlauf => Wert=999
197 | display_value = 1000;
198 | display_value--; // Wert -1
199 | key_down = 0; // Tastencounter leeren
200 | }
201 |
202 | if (key_start >= 100) // Start-Taste gedrückt
203 | {
204 | key_start = 0; // Tastencounter leeren
205 | if (display_value == 0) // wenn angezeigter Wert = 0 und Start gedrückt => ermittler zuletzt verwendeten Startwert und setze diesen
206 | {
207 | display_value = eeprom_read_word(&startwert);
208 | }
209 | else
210 | {
211 | run ^= 1; // Wert XOR 1; => Start/Stop
212 | if (run) // Wenn Counter gestartet wird
213 | {
214 | if (display_value != eeprom_read_word(&startwert)) // wenn Start gedrückt und aktueller Startwert != letzter Startwert
215 | eeprom_write_word(&startwert, display_value); // dann speichere neuen Startwert
216 |
217 | TCNT1H=0; // Timerstand zurücksetzen, damit ab jetzt eine Sekunde zählt
218 | TCNT1L=0;
219 | TCCR1B = (1<<CS10)|(1<<CS12); // Timer mit Div 1024 starten
220 | relais = 0x80; // zusätzlich Relais HIGH
221 | }
222 | else // Counter angehalten
223 | {
224 | TCCR1B = 0; // Timer Stop
225 | relais = 0x0; // Relais LOW
226 | }
227 | }
228 | }
229 |
230 | if (display_value == 0) // Timer abgelaufen
231 | {
232 | run = 0; // Stop
233 | relais = 0x0; // Relais LOW
234 | }
235 | }
236 | }
