Forum: FPGA, VHDL & Co. ISE 11.4 unter win7/XP mode MAP-Problem
von alexey (Gast)
hallo zusammen,
vorher hab ich benutz ISE10.10.1.03 unter Win7/XP Mode, es gibt kein
problem damit.
Und jetzt hab ich grad ISE 11.4 installiert und NICHT die alte
ISE10.1.03 deinstalliert.
Ich bekomme dann die MAP-Fehler:
ERROR:Security:9 - No 'ISE' nor 'WebPack' feature was available for part
'xc3s700a'.
Cannot checkout an uncounted license within a Windows Terminal Services
guest
session.
Feature:       WebPack
License path:
C:/.Xilinx\webpack.lic;C:\Xilinx\11.1\ISE/data\*.lic;C:\Xilinx\11.1\ISE/
coregen/
core_licenses\can_v1_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_licenses
\can_v2_
flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_licenses\cpri_v2_flexlm.lic;C
:\Xilinx
\11.1\ISE/coregen/core_licenses\ethernet_statistics_v2_flexlm.lic;C:\Xil
inx\11.1
\ISE/coregen/core_licenses\ethernet_statistics_v3_flexlm.lic;C:\Xilinx\1
1.1\ISE/
coregen/core_licenses\eth_avb_endpoint_v1_flexlm.lic;C:\Xilinx\11.1\ISE/
coregen/
core_licenses\fibre_channel_v3_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/cor
e_licens
es\gfp_v1_3_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_licenses\gfp_v2_f
lexlm.li
c;C:\Xilinx\11.1\ISE/coregen/core_licenses\gig_eth_mac_v8_flexlm.lic;C:\
Xilinx\1
1.1\ISE/coregen/core_licenses\gig_eth_pcs_pma_v10_flexlm.lic;C:\Xilinx\1
1.1\ISE/
coregen/core_licenses\gig_eth_pcs_pma_v9_flexlm.lic;C:\Xilinx\11.1\ISE/c
oregen/c
ore_licenses\obsai_v3_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_license
s\pci32_
v4_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_licenses\pci64_v4_flexlm.l
ic;C:\Xi
linx\11.1\ISE/coregen/core_licenses\pcie_blk_plus_v1_flexlm.lic;C:\Xilin
x\11.1\I
SE/coregen/core_licenses\pcie_pipe_v1_flexlm.lic;C:\Xilinx\11.1\ISE/core
gen/core
_licenses\pcix_v6_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_licenses\pc
i_expres
s_v3_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_licenses\pktq_v2_flexlm.
lic;C:\X
ilinx\11.1\ISE/coregen/core_licenses\pl4_lite_v4_flexlm.lic;C:\Xilinx\11
.1\ISE/c
oregen/core_licenses\pl4_v8_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_l
icenses\
pl4_v9_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_licenses\rio_log_io_v4
_flexlm.
lic;C:\Xilinx\11.1\ISE/coregen/core_licenses\rio_log_io_v5_flexlm.lic;C:
\Xilinx\
11.1\ISE/coregen/core_licenses\spi3_link_v5_flexlm.lic;C:\Xilinx\11.1\IS
E/corege
n/core_licenses\spi3_phy_v5_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_l
icenses\
srio_phy_v4_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_licenses\srio_phy
_v5_flex
lm.lic;C:\Xilinx\11.1\ISE/coregen/core_licenses\ten_gig_eth_mac_v8_flexl
m.lic;C:
\Xilinx\11.1\ISE/coregen/core_licenses\ten_gig_eth_mac_v9_flexlm.lic;C:\
Xilinx\1
1.1\ISE/coregen/core_licenses\tri_mode_eth_mac_v3_flexlm.lic;C:\Xilinx\1
1.1\ISE/
coregen/core_licenses\tri_mode_eth_mac_v4_flexlm.lic;C:\Xilinx\11.1\ISE/
coregen/
core_licenses\vlynq_v1_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_licens
es\v_ccm
_v1_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_licenses\v_cfa_v1_flexlm.
lic;C:\X
ilinx\11.1\ISE/coregen/core_licenses\v_gamma_v1_flexlm.lic;C:\Xilinx\11.
1\ISE/co
regen/core_licenses\v_ipipe_v1_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/cor
e_licens
es\v_rgb2ycrcb_v2_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_licenses\v_
spc_v1_f
lexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_licenses\v_ycrcb2rgb_v2_flexlm
.lic;C:\
Xilinx\11.1\ISE/coregen/core_licenses\xaui_v7_flexlm.lic;C:\Xilinx\11.1\
ISE/core
gen/core_licenses\xaui_v8_flexlm.lic;C:\Xilinx\11.1\ISE/coregen/core_lic
enses\Xi
linx.lic;C:\Xilinx\11.1\ISE/coregen/core_licenses\XilinxFree.lic;
FLEXnet Licensing error:-103,577.  System Error: 2 ""
For further information, refer to the FLEXnet Licensing documentation,
available at "www.acresso.com".No such feature exists.
Feature:       ISE
License path:
coregen/
\can_v2_
:\Xilinx
inx\11.1
1.1\ISE/
coregen/
e_licens
lexlm.li
Xilinx\1
1.1\ISE/
coregen/co
ERROR:Map:258 - A problem was encountered attempting to get the license
for this
   architecture.
Ich hab nach den Fehler gesucht, aber irgendwie fehlerbehebung ist nicht
für 'xc3s700a'.
Kann jemand mir helfen?
danke euch
LG
von alexey (Gast)
niemand hat idee oder niemand hat das selbe problem?:-(
von Thi L. (flothi)
Den Fehler genau nicht, aber der Kollege hinter mir versucht auch mit
ISE 11.4 und Windows 7 zu arbeiten - mit mäßigem Erfolg (ich hab noch
WinXP laufen).
Aussage von Xilinx: Windows 7 is not a supported operating system -
soviel dazu
VG
von Christian R. (supachris)
Hm, also die System Edition 11.4 läuft bei mir einwandfrei unter Win 7
Pro x64. Zwar ohne EDK und SDK, aber die Logik läuft komplett durch.
von alexey (Gast)
vielen dank erstmal für eure antwort!
Wie hast du so gemacht, unter win7 ise zu installieren, mit ganz
normalen Schritten oder wie?
Ich hab ise 10.1.03 vorher auch unter win7 installiert, aber irgendwie
hab ich den fehlermeldung oder sowas gekriegt, dass nicht unterstützt...
Deswegen habe ich versucht mit win7/xpmode und es geht einwandfrei bis
jetzt, also noch ise 10.1.03.
Jetzt will ich die ise 10.1.03 auf 11.4 unter win7/xpmode updaten. Ich
hab erstmal die ise 10.1.03 deinstalliert, und die 11.1 vom
mitgelieferten DVD installiert, und dann auf 11.4 updaten. Dazwischen
bekamm ich eine Meldung dass wenn es updatet würde, würde einige tools
mit altem license nicht mehr laufen. Trotzdem hab "ok" gedrückt (keine
andere möglichkeit oder?). Tja dann hab ich diesen MAP-Problemm...
DVD von 11.1 rein und installiert. Fertig. Lizenz natürlich über den
Lizenz-Generator auf der Homepage erstellt. Dann das Update für Win x64
runter geladen und installiert. Ging ohne Probleme. Der XP Modus ist
nicht nötig. Das ganze läuft sogar in nativ 64 Bit, dazu ist der Ordner
C:\Xilinx\ISE\bin\nt64 auf der Platte. Mit der 10er Lizenz wirds da
sicherlich Probleme geben, da gabs ja die Aufteilung in System/Logic usw
noch nicht.
von ugly_dugly (Gast)
Ich vermute du lässt ISE auf einem virtuellen PC laufen oder über eine
Remote Desktop Verbindung. Das wird vom Webpack 11 nicht mehr
standardmäßig unterstützt und führt zu genau dieser Fehlermeldung. Wenn
man sich an den Xilinx Support wendet bekommt man eine für Remotedesktop
funktionsfähige Lizens zugeschickt.
von Updater (Gast)
Mir geht es genauso.
Erst der Umstieg von XP nach Windows7
- na klar, es musste die 64bit-Ultimate Version sein -
und dann die ständigen Updates von XILINX..., bin fix und fertig.
Ich komme vor lauter Updates gar nicht mehr dazu, etwas sinnvolles mit
ISE zu programmieren, weil ich glaube, es geht nur mit o.a.
Konstellation.
Ständige Updates? Pro Jahr gibts eine Major Release (2009 war das die
11.1) und dann max. 3 Updates (bis 11.4 im Dez. 2009). Unter XP Modus
hab ich gar nicht probiert, das wird ja nur noch viel langsamer dann.
von alexey (Gast)
vielen dank für eure antwort!
> noch nicht.
Muss ich erst auf win 64 bit noch updaten? ich hab win7.32bit
Morgen werde ich versuchen nochmals unter win7 die ise 11 auf dem dvd zu
installieren.
> oder über eine
d.h. genau mein fall, ich muss ise auf virtuellem pc laufen lassen.
gute nacht für alle^^
> installieren.
Nee, natürlich nicht. Das bezog sich auf die Frage nach Win7 x64....ist
wohl bissl durchnander geraten hier.
von Andreas (Gast)
@ Christain R(supachris),
>Ständige Updates? Pro Jahr gibts eine Major Release (2009 war das die 11.1) und
so wie es aussieht, durchbricht Xilinx Ihre eigene Vorgabe, lt. einigen
Answerrecords unter xilinx.com wird Xilinx noch mindestens eine 11.5
nachschieben...
Achje. Hab ich noch gar nicht gelesen. Ich hatte gehofft, die 12.1 kommt
demnächst. Mit der Hoffnung auf eine SVN- oder wenigstens
CVS-Anbindung...aber irgendwie scheinen die ja überhaupt gar nix von
Versionskontrolle zu halten. Naja, mal schauen.
von Anfänger (Gast)
Andreas schrieb:
> einigen
> nachschieben...Beitrag melden | Bearbeiten | Löschen |
bin gerade auf dem weg mit 11.5 updated, hoffentlich läuft dies mals
unter win7...
Update: 11.5 läuft unter Win 7 x64 genauso nativ ohne XP Modus, wie 11.1
und 11.4 sowohl in der 32Bit als auch in der 64 Bit Version aus dem
/nt64 Ordner.
