Hallo Leute, meine Freude über den kürzlich eingetroffenen Programmierer AVR ISP mkII währte leider nur kurz. Der Aufruf von avrdude -p t13 -P usb1 -vv -c avrisp2 -U flash:w:/home/rafa/bin/init.hex:i liefert folgende Ausgabe: avrdude: Version 5.10, compiled on Feb 19 2010 at 17:31:30 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch System wide configuration file is "/etc/avrdude.conf" User configuration file is "/root/.avrduderc" User configuration file does not exist or is not a regular file, skipping Using Port : usb Using Programmer : avrisp2 avrdude: usbdev_open(): Found AVRISP mkII, serno: 0000B0039035 avrdude: usbdev_open(): using read endpoint 0x82 AVR Part : ATtiny13 Chip Erase delay : 4000 us PAGEL : P00 BS2 : P00 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 5 4 0 no 64 4 0 4000 4000 0xff 0xff flash 65 6 32 0 yes 1024 32 32 4500 4500 0xff 0xff signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00 lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 Programmer Type : STK500V2 Description : Atmel AVR ISP mkII Programmer Model: AVRISP mkII Hardware Version: 1 Firmware Version Master : 1.10 Vtarget : 5.4 V SCK period : 953.29 us avrdude: stk500v2_command(): command failed avrdude: stk500v2_command(): unknown status 0xc9 avrdude: stk500v2_program_enable(): cannot get connection status avrdude: initialization failed, rc=-1 Double check connections and try again, or use -F to override this check. avrdude done. Thank you. Gibt es irgendwelche Ideen ? Vielen Dank, Rafa
Hallo, kannst du mehr Details geben? was wird programiert, Board etc. was passiert mit dem LED'S von Proger bzw. wie leuchten? Ralf K. schrieb: > avrdude: stk500v2_command(): command failed > avrdude: stk500v2_command(): unknown status 0xc9 > avrdude: stk500v2_program_enable(): cannot get connection status > avrdude: initialization failed, rc=-1 > Double check connections and try again, or use -F to override > this check. kommt zB. auch wenn "kein Board" angeschlossen ist, wenn der AVRISPmkII kein verbindung mit dem Microkontroller hat, deswegen: > Double check connections and try again, or use -F to override > this check. Martin
das bekam ich beim stk500v2 (fast) immer bis ich ein '-B 2' (inzwischen
auch ein -B 1.1') eingefügt hab - obwohls eigentlich nicht nötig sein
sollte.
HTH
Using Port : usb Using Programmer : avrisp2 avrdude: usbdev_open(): Found AVRISP mkII, serno: 0000B0039035 avrdude: usbdev_open(): using read endpoint 0x82 .... und .... Programmer Type : STK500V2 Description : Atmel AVR ISP mkII Programmer Model: AVRISP mkII Hardware Version: 1 Firmware Version Master : 1.10 Vtarget : 5.4 V SCK period : 953.29 us deuten dass der Programmer ok ist!
Hallo Martin, das hatte ich so auch vermutet, irgendwie gehts danach aber nicht weiter zum Controller, mal sehen... Hallo g457, wird gleich ausprobiert und hier dokumentiert. Hallo Alejandro, Also: Es ist ein ATtiny13 der sich in folgender Schaltung befindet: http://www.b-kainka.de/lpmikros.htm (ganz nach unten scrollen) Den Anschluss über das 6-Pin-ISP-Kabel des Programmers habe ich über die freien Steckpins unterhalb des ATtiny in die selbe Konsole gesteckt. Dabei habe ich natürlich die Datenblätter des Programmers und des ATtiny befolgt (Pin-Zuordnung). Hier dürfte also alles OK sein (mehrfach gecheckt): Programmer Tiny MISO (Pin1) PB1 (Pin6) VCC (Pin2) VCC (Pin8) SCK (Pin3) PB2 (Pin7) MOSI (Pin4) PB0 (Pin5) RES (Pin5) RES (Pin1) GND (Pin6) GND (Pin6) Zusätzlich hängt an VCC und GND noch eine externe Spannungsquelle (5.4V). Diese wird auch vom Programmer durch eine leuchtende grüne LED erkannt. So gesehen ist die gesamte Schaltung eigentlich inaktiv, weil ich mit jedem Anschluss (seitens ISP und VCC) direkt an Tinys Füßchen hänge. Bei der Befehlsausführung wechselt die LED in Dauer-Rot (oder Orange ?) und danach wieder zurück zu grün. Die Target-seitige LED blinkt dabei nicht, die Programmer-seitige blinkt am Ende des Prozesses ein paarmal, sonst ist sie ständig grün (2-3 mal). Hoffentlich habe ich nichts vergessen.. die Option -F ändert nichts am ergebnis. -D auch nicht. Gruss, Ralf
Stoooooooooopp Warum auch immer, ohne irgendwas an der Schaltung oder an der Befehlzeile geändert zu haben, gehts auf einmal. Keine Ahnung was da los war... Wahrscheinlich war der Pumuckl in der Schaltung. Liebe Leute: Für euch alle eine virtuelle Kiste feinsten deutschen Bieres. Auf dieses Forum und alle fleißigen Helfer... PROSCHT Liebe Grüsse und Danke, Ralf
PROSCHT :-) ABER einen kleinen Unterschied gibt es doch beim Befehlsaufruf, daran kann es aber nicht gelegen haben: statt usb1 habe ich jetzt versehntlich nur usb angegeben, also ohne die 1. (Kommandozeilen-Befehls-Wiederholungs-Funktions-Hektik) Liebe Grüsse und Danke, Ralf
