Forum: Mikrocontroller und Digitale Elektronik Fehlermeldung eclipse
von Knut (Gast)
nach dem Übertragen der Software meldet Eclipse folgenden Code in der
Console:
Launching C:\WinAVR-20100110\bin\avrdude -pm128 -cstk500v2 -Pcom9 -u
-Uflash:w:MTS200.hex:a -Ulfuse:w:0x3f:m -Uhfuse:w:0xd9:m
-Uefuse:w:0xff:m -Ulock:w:0xf3:m
Output:
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100%
0.02s
avrdude: Device signature = 0x1e9702
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be
performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "MTS200.hex"
avrdude: input file MTS200.hex auto detected as Intel Hex
avrdude: writing flash (266 bytes):
Writing | ################################################## | 100%
0.14s
avrdude: 266 bytes of flash written
avrdude: verifying flash memory against MTS200.hex:
avrdude: load data flash data from input file MTS200.hex:
avrdude: input file MTS200.hex contains 266 bytes
avrdude: reading on-chip flash data:
0.09s
avrdude: verifying ...
avrdude: 266 bytes of flash verified
avrdude: reading input file "0x3f"
avrdude: writing lfuse (1 bytes):
0.02s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0x3f:
avrdude: load data lfuse data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
avrdude: reading on-chip lfuse data:
0.00s
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0xd9"
avrdude: writing hfuse (1 bytes):
0.00s
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xd9:
avrdude: load data hfuse data from input file 0xd9:
avrdude: input file 0xd9 contains 1 bytes
avrdude: reading on-chip hfuse data:
0.02s
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xff"
avrdude: writing efuse (1 bytes):
0.00s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xff:
avrdude: load data efuse data from input file 0xff:
avrdude: input file 0xff contains 1 bytes
avrdude: reading on-chip efuse data:
0.00s
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xf3"
avrdude: writing lock (1 bytes):
Writing |  ***failed;
################################################## | 100% 0.11s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0xf3:
avrdude: load data lock data from input file 0xf3:
avrdude: input file 0xf3 contains 1 bytes
avrdude: reading on-chip lock data:
0.00s
avrdude: verification error, first mismatch at byte 0x0000
         0xf3 != 0x33
avrdude: verification error; content mismatch
avrdude done.  Thank you.
avrdude finished
Das Programm funktioniert, jedoch mach mich der letzte Absatz etwas
stuzig
Warum gibt es beim verifying einen Fehler bzw. was sagt dieser Fehler
aus?
Gruß Knut
von Daniel V. (danvet)
Ich kenn mich jetzt nicht mit dem Eclipse-Brenner aus, aber wenn das
LOCK-Bit geschrieben/gesetzt wurde, dann ist nix mehr mit lesen.
Deswegen wohl der Lesefehler. Ist  jetzt nur ne Vermutung.
