ich möchte vom ARM-LPC2xxx-Mikrocontroller an LCD-Display über ein
I2C-Bus Daten schicken, also "Bilder auf LCD-Display übertragen" und
habe ein Beispiel für Datenübertrageung über ein I2C-Bus, aber nicht für
LCD, bei NXP gefunden:
1 | #include"LPC210x.h"
2 | void Initialize(void);
3 | /* I2C ISR */
4 | __irq void I2C _ISR(void);
5 | /* Master Transmitter states */
6 | void ISR_8(void);
7 | void ISR_18(void);
8 | void ISR_28(void);
9 | /*************************** MAIN ************************/
10 | int main(){
11 | /* Initialize system */
12 | Initialize ();
13 | /* Send start bit */
14 | I2C ONSET=0x60;
15 | /* Do forever */
16 | while(1)
17 | { IOCLR=0x40;
18 | IOSET=0x40; }
19 | }
20 | /*************** System Initialization ***************/
21 | void Initialize()
22 | {
23 | /* Remap interrupt vectors to SRAM */
24 | MEMMAP=0x2;
25 | /* Initialize GPIO ports to be used as indicators */
26 | IODIR=0xF0;
27 | IOSET=0xF0;
28 | /* Initialize Pin Connect Block */
29 | PINSEL0=0x50;
30 | /* Initialize I2C */
31 | I2CONCLR=0x6c;/* clearing all flags */
32 | I2CONSET=0x40; /* enabling I2C */
33 | I2SCLH=0xC; /* 100 KHz */
34 | I2SCLL=0xD;
35 | /* Initialize VIC for I2C use */
36 | VICINTSEL=0x0; /* selecting IRQ */
37 | VICINTEN= 0x200; /* enabling I2C */
38 | VICCNTL0= 0x29; /* highest priority and enabled */
39 | VICVADDR0=(unsigned long) I2C_ISR;
40 | /* ISR address written to the respective address register*/
41 | }
42 | /********************** I2C ISR **************************/
43 | __irq void I2C_ISR()
44 | {
45 | int temp=0;
46 | temp=I2STAT;
47 | switch(temp)
48 | {
49 | case 8:
50 | ISR_8();
51 | break;
52 | case 24:
53 | ISR_18();
54 | break;
55 | case 40:
56 | ISR_28();
57 | break;
58 | default :
59 | break;
60 | }
61 | VICVADDR=0xFF;
62 | }
63 | /* I2C states*/
64 | /* Start condition transmitted */
65 | void ISR_8()
66 | {
67 | /* Port Indicator */
68 | IOCLR=0x10;
69 | /* Slave address + write */
70 | I2DAT=0x74;
71 | /* Clear SI and Start flag */
72 | I2CONCLR=0x28;
73 | /* Port Indicator */
74 | IOSET=0x10;
75 | }
76 | /* Acknowledgement received from slave for slave address */
77 | void ISR_18()
78 | {
79 | /* Port Indicator */
80 | IOCLR=0x20;
81 | /* Data to be transmitted */
82 | I2DAT=0x55;
83 | /* clear SI */
84 | I2CONCLR=0x8;
85 | /* Port Indicator */
86 | IOSET=0x20;
87 | }
88 | /* Acknowledgement received from slave for byte transmitted from master. Stopcondition is transmitted in this state signaling the end of transmission */
89 | void ISR_28()
90 | {
91 | /* Port Indicator */
92 | IOCLR=0x80;
93 | /* Transmit stop condition */
94 | I2CONSET=0x10;
95 | /* clear SI */
96 | I2CONCLR=0x8;
97 | /* Port Indicator */
98 | IOSET=0x80;
99 | }
Ich bin ein Anfänger und meine Frage wäre: findet die vollstendige
Datenübertragung(Startbit, Slaveadresse+W,Daten,Stopbit) nur ein mal
statt oder die wiederholt sich regelmasig? Ich habe ein
Versändnisproblemm und weiß nicht wie Interupt bei Datenübertragung in
Hardware funktionirt :(
Danke im voraus.
