Hallo allesamt, welchen Zustand haben eigentlich die Portpins wenn der MSP430F169 resetet wird. Sind die Portpins während der Resetzeit hochohmig, intern auf pull up oder pull down gelegt? Auf welcher Datenblattseite findet man da Informationen? Danke und Gruß Dieter
2.1.3 Device Initial Conditions After System Reset After a POR, the initial MSP430 conditions are: The RST/NMI pin is configured in the reset mode. I/O pins are switched to input mode as described in the Digital I/O chapter. Other peripheral modules and registers are initialized as described in their respective chapters in this manual. Status register (SR) is reset. The watchdog timer powers up active in watchdog mode. Program counter (PC) is loaded with address contained at reset vector location (0FFFEh). CPU execution begins at that address. Steht alles in User Guide, slau049f.pdf bei TI. MfG Falk
