Hallo, ich komme nicht auf das Rätsels Lösung. Bei Eingabe des Befehls "make gcc elf2flt gdb-host" kommt eine Fehlermeldung michael@linux-8k6s:~/nios2-linux> which gcc /usr/bin/gcc michael@linux-8k6s:~/nios2-linux> gcc --version gcc (SUSE Linux) 4.3.2 [gcc-4_3-branch revision 141291] Copyright (C) 2008 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. michael@linux-8k6s:~/nios2-linux> which cc /usr/bin/cc michael@linux-8k6s:~/nios2-linux> cc --version cc (SUSE Linux) 4.3.2 [gcc-4_3-branch revision 141291] Copyright (C) 2008 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. michael@linux-8k6s:~/nios2-linux> cd toolchain-build michael@linux-8k6s:~/nios2-linux/toolchain-build> ls config gdb.mk Makefile release_top u-boot.mk michael@linux-8k6s:~/nios2-linux/toolchain-build> gcc --version gcc (SUSE Linux) 4.3.2 [gcc-4_3-branch revision 141291] Copyright (C) 2008 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. michael@linux-8k6s:~/nios2-linux/toolchain-build> git clean -f -x -d michael@linux-8k6s:~/nios2-linux/toolchain-build> make gcc elf2flt gdb-host /home/michael/nios2-linux/toolchain-build/u-boot.mk:11: Board not defined! Using EP1S10 as default. mkdir -p /home/michael/nios2-linux/toolchain-build/build/linux make -C /home/michael/nios2-linux/toolchain-build/../linux-2.6 ARCH=nios2 CC=gcc INSTALL_HDR_PATH=/home/michael/nios2-linux/toolchain-build/build/linux headers_install make[1]: Entering directory `/home/michael/nios2-linux/linux-2.6' CHK include/linux/version.h HOSTCC scripts/basic/fixdep In file included from /usr/include/bits/posix1_lim.h:153, from /usr/include/limits.h:145, from /usr/lib/gcc/i586-suse-linux/4.3/include-fixed/limits.h:122, from /usr/lib/gcc/i586-suse-linux/4.3/include-fixed/syslimits.h:7, from /usr/lib/gcc/i586-suse-linux/4.3/include-fixed/limits.h:11, from scripts/basic/fixdep.c:115: /usr/include/bits/local_lim.h:39:26: error: linux/limits.h: Datei oder Verzeichnis nicht gefunden In file included from /usr/include/sys/socket.h:40, from /usr/include/netinet/in.h:25, from /usr/include/arpa/inet.h:23, from scripts/basic/fixdep.c:117: /usr/include/bits/socket.h:334:24: error: asm/socket.h: Datei oder Verzeichnis nicht gefunden scripts/basic/fixdep.c: In function ‘use_config’: scripts/basic/fixdep.c:206: error: ‘PATH_MAX’ undeclared (first use in this function) scripts/basic/fixdep.c:206: error: (Each undeclared identifier is reported only once scripts/basic/fixdep.c:206: error: for each function it appears in.) scripts/basic/fixdep.c:206: warning: unused variable ‘s’ scripts/basic/fixdep.c: In function ‘parse_dep_file’: scripts/basic/fixdep.c:306: error: ‘PATH_MAX’ undeclared (first use in this function) scripts/basic/fixdep.c:306: warning: unused variable ‘s’ make[2]: *** [scripts/basic/fixdep] Fehler 1 make[1]: *** [scripts_basic] Fehler 2 make[1]: Leaving directory `/home/michael/nios2-linux/linux-2.6' make: *** [/home/michael/nios2-linux/toolchain-build/build/linux/.configured] Fehler 2 michael@linux-8k6s:~/nios2-linux/toolchain-build> Ich nutze openSuse 11.1 (VitualBox) und gehe nach der Anleitung unter: http://www.nioswiki.com/InstallNios2Linux vor. Habe schon ein paar Anläufe versucht, aber es geht nicht. Kann mir einer eine Hilfestellung geben? Danke
