1 | CPU: ADSP BF537 Rev.: 0.3
2 | Board: ADI BF537 stamp board
3 | Support: http://blackfin.uclinux.org/
4 | Clock: VCO: 442 MHz, Core: 442 MHz, System: 88 MHz
5 | SDRAM: 32 MB
6 | FLASH: 4 MB
7 | In: serial
8 | Out: serial
9 | Err: serial
10 | Net: ADI BF537 EMAC
11 | I2C: ready
12 | Hit any key to stop autoboot: 1 0
13 |
14 | EEPROM @0x0 read: addr 01000000 off 30000 count 2646053 ... ........................................done
15 |
16 | ## Booting image at 01000000 ...
17 |
18 | Image Name: uClinux Kernel and ext2
19 | Created: 2010-06-01 6:29:11 UTC
20 | Image Type: Blackfin Linux Kernel Image (gzip compressed)
21 | Data Size: 2645989 Bytes = 2.5 MB
22 | Load Address: 00400000
23 | Entry Point: 0052c2e0
24 | Verifying Checksum ... OK
25 | Uncompressing Kernel Image ... OK
26 | Starting Kernel at = 52c2e0
27 |
28 | Linux version 2.6.28.10-ADI-2009R1 (robi-wan@Robolab) (gcc version 4.1.2 (ADI svn)) #44 Tue Jun 1 08:28:22 CEST 2010
29 | Board Memory: 32MB
30 | Kernel Managed Memory: 32MB
31 | Memory map:
32 | fixedcode = 0x00000400-0x00000490
33 | text = 0x00400000-0x004bc270
34 | rodata = 0x004bc270-0x00501da4
35 | bss = 0x00502000-0x0051bb00
36 | data = 0x0051bb00-0x0052a000
37 | stack = 0x00528000-0x0052a000
38 | init = 0x0052a000-0x0053a000
39 | available = 0x0053a000-0x01600000
40 | rootfs = 0x01600000-0x02000000
41 | Hardware Trace Off and Disabled
42 | Boot Mode: 3
43 | Blackfin support (C) 2004-2009 Analog Devices, Inc.
44 | Compiled for ADSP-BF537 Rev 0.3
45 | Blackfin Linux support by http://blackfin.uclinux.org/
46 | Processor Speed: 442 MHz core clock and 88 MHz System Clock
47 | MPU: setting up cplb tables with memory protection
48 | Instruction Cache Enabled for CPU0
49 | Data Cache Enabled for CPU0 (write-back)
50 | Built 1 zonelists in Zone order, mobility grouping off. Total pages: 5588
51 | Kernel command line: root=/dev/mmcblk0p1 rw rootdelay=2 earlyprintk=serial,uart0,115200 console=ttyBF0,115200 mem=32M
52 | Configuring Blackfin Priority Driven Interrupts
53 | PID hash table entries: 128 (order: 7, 512 bytes)
54 | console [ttyBF0] enabled
55 | Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
56 | Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
57 | Memory available: 14048k/32768k RAM, (64k init code, 752k kernel code, 440k data, 0k dma, 7224k reserved)
58 | Calibrating delay loop... 882.68 BogoMIPS (lpj=1765376)
59 | Security Framework initialized
60 | Mount-cache hash table entries: 512
61 | Blackfin Scratchpad data SRAM: 4 KB
62 | Blackfin L1 Data A SRAM: 16 KB (10 KB free)
63 | Blackfin L1 Data B SRAM: 32 KB (32 KB free)
64 | Blackfin L1 Instruction SRAM: 48 KB (38 KB free)
65 | Blackfin DMA Controller
66 | stamp_init(): registering device resources
67 | msgmni has been set to 27
68 | io scheduler noop registered
69 | io scheduler anticipatory registered (default)
70 | io scheduler cfq registered
71 | bfin-dma: initialized
72 | Serial: Blackfin serial driver
73 | bfin-uart.1: ttyBF0 at MMIO 0xffc00400 (irq = 18) is a BFIN-UART
74 | Linux video capture interface: v2.00
75 | OV9655: i2c driver ready
76 | uclinux[mtd]: RAM probe address=0x1600000 size=0xa00000
77 | Creating 1 MTD partitions on "RAM":
78 | 0x00000000-0x00a00000 : "ROMfs"
79 | bfin-spi bfin-spi.0: Blackfin on-chip SPI Controller Driver, Version 1.0, regs_base@ffc00500, dma channel@7
80 | i2c /dev entries driver
81 | i2c-bfin-twi i2c-bfin-twi.0: Blackfin BF5xx on-chip I2C TWI Contoller, regs_base@ffc01400
82 | mmc_spi spi0.2: ASSUMING 3.2-3.4 V slot power
83 | mmc_spi spi0.2: SD/MMC host mmc0, no DMA, no WP, no poweroff
84 | Waiting 2sec before mounting root device...
85 | mmc_spi spi0.2: requested mode not fully supported
86 | mmc_spi spi0.2: can't change chip-select polarity
87 | mmc0: host does not support reading read-only switch. assuming write-enable.
88 | mmc0: new SD card on SPI
89 | mmcblk0: mmc0:0000 SD064 59.5 MiB
90 | mmcblk0: p1
91 | EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
92 | VFS: Mounted root (ext2 filesystem).
93 | No usable address families found.
94 | socket: Function not implemented
95 | modprobe: Module blackfin_cam not found.
96 |
97 | Welcome to:
98 | _________ _____ ____ _ _____
99 | __ __/ ____/ (_)___ __ ___ __ / ___// __ \ | / < /
100 | / / / / / / / / __ \/ / / / |/_/_____\__ \/ /_/ / | / // /
101 | / /_/ / /___/ / / / / / /_/ /> </_____/__/ / _, _/| |/ // /
102 | \__,_/\____/_/_/_/ /_/\__,_/_/|_| /____/_/ |_| |___//_/
103 |
104 | For further information see:
105 | http://www.surveyor.com/
106 |
107 |
108 | BusyBox v1.13.4 (2010-06-01 08:27:05 CEST) built-in shell (msh)
109 | Enter 'help' for a list of built-in commands.
110 |
111 | # cat /proc/meminfo
112 | cat /proc/meminfo
113 |
114 | MemTotal: 14048 kB
115 | MemFree: 11532 kB
116 | Buffers: 72 kB
117 | Cached: 476 kB
118 | SwapCached: 0 kB
119 | Active: 380 kB
120 | Inactive: 124 kB
121 | Active(anon): 0 kB
122 | Inactive(anon): 0 kB
123 | Active(file): 380 kB
124 | Inactive(file): 124 kB
125 | SwapTotal: 0 kB
126 | SwapFree: 0 kB
127 | Dirty: 4 kB
128 | Writeback: 0 kB
129 | AnonPages: 0 kB
130 | Mapped: 0 kB
131 | Slab: 516 kB
132 | SReclaimable: 160 kB
133 | SUnreclaim: 356 kB
134 | PageTables: 0 kB
135 | NFS_Unstable: 0 kB
136 | Bounce: 0 kB
137 | WritebackTmp: 0 kB
138 | CommitLimit: 7024 kB
139 | Committed_AS: 0 kB
140 | VmallocTotal: 0 kB
141 | VmallocUsed: 0 kB
142 | VmallocChunk: 0 kB
143 | # #
